ozacek Posted August 16, 2019 Posted August 16, 2019 On 8/14/2019 at 4:42 PM, johnnym said: Awesome! Exactly what I was asking for a while ago, but maybe in the wrong thread. Please create instructions when you're finished! I decided to make instructions after all. Here's the link to the first part PDF (i.e. bag #1): https://drive.google.com/file/d/1Poye9GeuJOQlV47LDOyeQYjUKx4KcopX The instructions are much more compact (I hate the current trend of oversimplified instructions) and I cleaned up the colors a bit, to be less random and more streamlined. I might take a while until I get my hands on the 3 parts I miss to make the 2nd part.. Quote
PetSild Posted August 17, 2019 Posted August 17, 2019 I made a simple non-invasive design of the adjustment of the front axle. Quote
efferman Posted August 17, 2019 Author Posted August 17, 2019 The planetary hub is made by myself too .part Quote
Philo Posted August 17, 2019 Posted August 17, 2019 38 minutes ago, efferman said: The planetary hub is made by myself too.part Nice work ;) The Ldraw part is mostly done, but I'd like to solve a part numbering issue before releasing it... Quote
efferman Posted August 17, 2019 Author Posted August 17, 2019 Looks better with the two colours Quote
johnnym Posted August 17, 2019 Posted August 17, 2019 On 8/16/2019 at 4:12 PM, ozacek said: I decided to make instructions after all. Here's the link to the first part PDF (i.e. bag #1): https://drive.google.com/file/d/1Poye9GeuJOQlV47LDOyeQYjUKx4KcopX Great! On 8/16/2019 at 4:12 PM, ozacek said: The instructions are much more compact (I hate the current trend of oversimplified instructions) and I cleaned up the colors a bit, to be less random and more streamlined. I had a look and like them as they are, good work. Though I am afraid, I'm already missing parts for the first part. Need to recheck... Quote
efferman Posted August 18, 2019 Author Posted August 18, 2019 (edited) The XLs are done and step 83 (506 parts) too edit: the chassis is mostly done Edited August 18, 2019 by efferman Quote
efferman Posted August 19, 2019 Author Posted August 19, 2019 (edited) Could you please take a look at this chassisinstruction ? Is there a need for arrows and similar? https://www.dropbox.com/s/xx5p6xj33jro9zb/stage 4.1.pdf?dl=0 Edit: new version https://www.dropbox.com/s/ervmx15acfk4klf/stage 4.1.pdf?dl=0 Edited August 19, 2019 by efferman Quote
Mechbuilds Posted August 19, 2019 Posted August 19, 2019 Has anybody done a version of the 42099 made by old parts like PF stuff and old hubs? I like the front axle design. Looks great for crawling. I wonder if it's possible to do with old parts? Perhaps smaller scale too using the smaller turn table. I'd love to have a more compact front axle using the turn table + spring combo. Quote
SNIPE Posted August 19, 2019 Posted August 19, 2019 8 minutes ago, Mechbuilds said: Has anybody done a version of the 42099 made by old parts like PF stuff and old hubs? I like the front axle design. Looks great for crawling. I wonder if it's possible to do with old parts? Perhaps smaller scale too using the smaller turn table. I'd love to have a more compact front axle using the turn table + spring combo. yes, see a few replies back. Quote
Mechbuilds Posted August 19, 2019 Posted August 19, 2019 2 minutes ago, SNIPE said: yes, see a few replies back. Now only to figure out a more compact version. :) Quote
Philo Posted August 19, 2019 Posted August 19, 2019 1 hour ago, efferman said: Is there a need for arrows and similar? With the parts highlighting, it looks clear enough! now I haven't tried to build it ;) Do you intend to publish a list of additionnal parts needed? Quote
efferman Posted August 19, 2019 Author Posted August 19, 2019 (edited) 4 hours ago, Philo said: Do you intend to publish a list of additionnal parts needed? for this i should make a stock LXF and compare it with the mocmod. in meanwhile there is not much identical edit: here is the .io Edited August 19, 2019 by efferman Quote
1gor Posted August 19, 2019 Posted August 19, 2019 @PetSild IMHO you version is the best solution what I have seen so far Quote
efferman Posted August 20, 2019 Author Posted August 20, 2019 (edited) There are some instructions for you Code Red = Standard shocks from the SetCode Yellow = Long yellow shocks at the rear axleBody = The Body which fits to Both Edited August 20, 2019 by efferman Quote
PetSild Posted August 21, 2019 Posted August 21, 2019 On 8/19/2019 at 9:14 PM, I_Igor said: @PetSild IMHO you version is the best solution what I have seen so far Thank you I am pleased I modified the rear axle, now there, too flow the more light ... Quote
Eaglefan344 Posted August 21, 2019 Posted August 21, 2019 On 8/13/2019 at 6:55 AM, rekreK said: Does anyone else’s steering center a bit to the left? I completed the efferman steering and fired it up, was a bit to the left, so went to maintenance and recalibrated, it moves and appears to test the limits, but then returns to off center Mine was veering to the right but I recalibrated again and it seems fine. Quote
efferman Posted August 21, 2019 Author Posted August 21, 2019 (edited) My 42099 code red mod is now on rebrickable. there you have the possibility to make a different part list for easy. https://rebrickable.com/mocs/MOC-28316/CustomBricks.de/ultimate-42099-moc-by-effermann/#comments Edited August 22, 2019 by efferman Quote
PetSild Posted August 22, 2019 Posted August 22, 2019 A lot of the functional improvements, great job and thanks for sharing the manual. Quote
ozacek Posted August 22, 2019 Posted August 22, 2019 On 8/16/2019 at 10:12 AM, ozacek said: I might take a while until I get my hands on the 3 parts I miss to make the 2nd part.. The second axle turned out to be much more difficult than the first to retrofit, but I think I now have solutions for most of the problems. It also turns out only two of the original five 1x3x3 connectors blocs are needed, so I'm not actually missing any parts. Quote
PetSild Posted August 23, 2019 Posted August 23, 2019 I managed to eliminate technically impractical and unsightly tooth on the bottom of the chassis. In addition, I shortened the size of the front part of the bumper, the wheels climb a vertical wall. Quote
SNIPE Posted August 23, 2019 Posted August 23, 2019 (edited) Heres a portal-planetary hub idea I made: Now to work out how to add steering Edited August 23, 2019 by SNIPE Quote
