ks6349 Posted August 10, 2019 Posted August 10, 2019 for example, will the parts like light bricks deteriorate? or will the "glow in the dark” part lose its ability to glow in the dark? Quote
DeCommander96 Posted August 10, 2019 Posted August 10, 2019 1 hour ago, ks6349 said: for example, will the parts like light bricks deteriorate? or will the "glow in the dark” part lose its ability to glow in the dark? Light bricks might need batteries replacing, depending on how old the set is. Glow in the dark will definitely lose its power, however, just hold the piece up to a light source for a minute and it will glow extremely bright Quote
Boettner Builds Posted August 10, 2019 Posted August 10, 2019 The batteries haven’t been “activated” so they’ll most likely be ok. but If the entire sets go through extreme heat and cold cycles, year after year, I’d be a little concerned. Quote
DeCommander96 Posted August 10, 2019 Posted August 10, 2019 42 minutes ago, Boettner Builds said: The batteries haven’t been “activated” so they’ll most likely be ok. Don't they stop working after about 4 years? Quote
Boettner Builds Posted August 10, 2019 Posted August 10, 2019 I don’t think it will be a problem. They have a little plastic tab that prevents them from completing the circuit. Quote
ks6349 Posted August 10, 2019 Author Posted August 10, 2019 3 hours ago, Boettner Builds said: The batteries haven’t been “activated” so they’ll most likely be ok. but If the entire sets go through extreme heat and cold cycles, year after year, I’d be a little concerned. extreme heat and cold cycle? Winter here could be below 0 degree cel. while summer could be up to 35 degree cel. and if I put the Lego in my car maybe it's 40+ degree cel. Is it extreme cycle Quote
dr_spock Posted August 11, 2019 Posted August 11, 2019 Old batteries can leak and may corrode the contacts. That may require some cleaning and battery replacement. Quote
paul_delahaye Posted August 11, 2019 Posted August 11, 2019 Crumpled sticker sheet/instructions must be high on the list! Depending on the age of the set and how they have been packaged. Quote
AmperZand Posted August 13, 2019 Posted August 13, 2019 On 8/10/2019 at 5:14 PM, ks6349 said: ...will the "glow in the dark” part lose its ability to glow in the dark? I wouldn't worry too much about that. I have had the same ghost minifigure as the one shown below in my display collection since 1993 and it still glows just fine. It takes a bit more 'charging' under bright light than the newer, scary shrouded ghost, but still works well. I expect it will still be a glowing ghost when I am one, too! Quote
ks6349 Posted August 14, 2019 Author Posted August 14, 2019 1 hour ago, AmperZand said: I wouldn't worry too much about that. I have had the same ghost minifigure as the one shown below in my display collection since 1993 and it still glows just fine. It takes a bit more 'charging' under bright light than the newer, scary shrouded ghost, but still works well. I expect it will still be a glowing ghost when I am one, too! This pic brought back a lot of memories of my childhood. Is this ghost retired already? Quote
AmperZand Posted August 14, 2019 Posted August 14, 2019 (edited) 23 hours ago, ks6349 said: This pic brought back a lot of memories of my childhood. Is this ghost retired already? Yes, since 1995, though that shroud remained in production until 2006 as a variant of the minifigure above and, I think, later as a key ring. Edited August 15, 2019 by AmperZand Quote
Still Raindrop Posted August 19, 2019 Posted August 19, 2019 On 8/10/2019 at 2:58 PM, DeCommander96 said: Don't they stop working after about 4 years? The light brick on my Winter Village Toy Shop is still lighting up, and I activated the battery 10 years ago when it first came out. Quote
Gomek Posted August 23, 2019 Posted August 23, 2019 On 8/11/2019 at 4:43 PM, paul_delahaye said: Crumpled sticker sheet/instructions must be high on the list! Depending on the age of the set and how they have been packaged. I had this happen once, though I'm not convinced it happened from either age or being transported several times. I don't often by old sealed sets, but crumpled stickers would be the first thing I'd worry about. Quote
midelburgo Posted August 26, 2019 Posted August 26, 2019 A couple of years ago I opened a 9v 4551 crocodile locomotive I had bought in 1996. The motor would not run for half an hour, then slowly started making short lengths, and finally, it worked perfectly. I suppose the engine had the lubricant congealed until it warmed up from the motor resistance itself. Quote
