Just now, Ghosty627 said:
I can't upload file anymore ... can I send a private message ?
Sure, or you a website like Bricksafe to host your photos like I do.
  • Replies 55
Here is a dropbox link just for 3 minutes ...
Edited by Ghosty627
1 minute ago, Ghosty627 said:
I removed the beam ... https://www.dropbox.com/sh/vz41befzq0864nc/AAB-_R-bQqwXRdbJFbhDFafka?dl=0
I add 2 new photos 10 and 11
The angle is the same ...
Something is blocking your steering rack from moving all the way. Check what the hubs are bumping into.
Wait. You are using 3L axles with studs to hold the steering arms? They are blocking the travel, because they are going through the rack and bumping the triangle brick behind it. Pull the axles holding the steering arms out by half a stud.
YES !!! That was the issue !!! Much thx for your great support !!!
36 minutes ago, Zerobricks said:
No problem, glad to help :grin: Have fun with the beast!
This 6x6 offroad vehicle is realy a beast. He clims a gradient of 53 degree :cry_happy:
  • 4 months later...
  • 2 months later...
On 11/30/2019 at 9:43 PM, Zerobricks said:
Sure, as long as you credit the original designer :wink:
I've jumped on this bandwagon too, but don't have the budget for the buggy motors so a different system will be going in, along with a colour change.
  • 2 months later...
First mock-up done, only has the 2 speed gearbox and 2x L motors at the moment.
Embarrassingly, I didn't realise till most of the body was done that it was the same colour scheme as the 42070 6x6 tow truck.
Have also built it as a quick remove body for now, may not be feasible longer term.
Edited by AussieBrett
Looking good!
  • 9 months later...
I'd like first, to thank you for this post and sharing the instructions. The Tiger is my favourite out of all my toys. ❤
I'm also here to share my very simple modification to change the rear universal joints to the new, much stronger ones.
https://imgur.com/gallery/E5WONxz
Edited by Maniac42099
That'll work! However, while those joints won't snap, they do wear out after a while.
Metal joints would work better.
  • 2 months later...
Hey, I built this monster about six months ago. From the beginning, I had a problem with shifting gears. Until now it has operated in ldcr mode, now it does not change at all. I thought the problem was the M motor but changed to a new one out of the box and it's the same. Anyone have an idea where the bug might be? I checked all the gears during the engine swap and they seem to run smoothly ...
Edited by nervousman
Hmm, interesting. Make sure both geraboxes are properly synchronized.
  • 1 year later...
18 hours ago, CooolWollf said:
I'm trying to build my own version of this but can't for the life of me figure out how to get the shock absorber in to the build, have someone tips for me?
Here is my version so far in to the build
https://drive.google.com/drive/folders/1gxrk8a2PHI1X9OsuOKcgWSjcGv0x-CV7?usp=drive_link
Which shock absorbers are you referring to? Also, you posted a private Google Drive link.
