dgeehot Posted September 23, 2019 Posted September 23, 2019 This question is for folks that set-up GBC modules at events. Do you have an emergency/breakdown/set-up kit that you take to events? If so what do you have in your kit? I did my first event this past weekend and would like to make sure that I am better equipped for the next event which will be in October. Thanks, Daniel Quote
doug72 Posted September 23, 2019 Posted September 23, 2019 (edited) See https://www.greatballpit.com where he describes his Convention Kit. Scroll down to Week 39. Edited September 23, 2019 by Doug72 Quote
dgeehot Posted September 23, 2019 Author Posted September 23, 2019 What about power cables/extensions switches Quote
Berthil Posted September 23, 2019 Posted September 23, 2019 Basicly spares for essential components you have used in your modules including some plates to level out modules when tables are not even. And of course a ball picker. Quote
dr_spock Posted September 23, 2019 Posted September 23, 2019 4 hours ago, dgeehot said: This question is for folks that set-up GBC modules at events. Do you have an emergency/breakdown/set-up kit that you take to events? If so what do you have in your kit? I did my first event this past weekend and would like to make sure that I am better equipped for the next event which will be in October. Thanks, Daniel What issues did you run into? My "kit" is geared towards outdoor picnics where I normally run my GBCs. 12V lead acid batteries extension cords level shims for leveling tables on the grass extra balls chopsticks for poking and picking up balls spare modules food, water, umbrella I don't carry my own spare parts since I lug the LUG's play bricks around. In an emergency I can find something in there. I run my most reliable modules and don't have much problems. Quote
JBrost Posted September 24, 2019 Posted September 24, 2019 I take a fishing tackle box full of LEGO pieces for spares/changes/improvements. I don't need them often, but I hate the thought of not having them just in case. Those pieces are sometimes used as spacers for uneven tables too. I also take a large assortment of parts for "infrastructure", i.e. things to make a functional GBC. That includes extension cords & power strips, 9v LEGO train controllers & power adapters, PF to 9v adapters, NXT wires/battery packs/power adapters, PF switches, GBC balls, etc. I also usually try to pack at least a few snacks & drinks as well. Many of the GBC organizers I display with have terrycloth tablecloths and pieces they use for fencing to keep loose balls from falling off the tables & rolling everywhere. I don't have any myself, but it is something I'm considering adding to my collection. And if you're displaying on a concrete floor, some anti-fatigue mats to stand on are awesome. At the larger shows there may be someone who has all the necessary wires & adapters and would rather you use their stuff. But I always take my stuff just in case. Of course I drive to all the events I go to, so I rarely have to worry about an extra box or two or the extra weight involved. Quote
dgeehot Posted September 24, 2019 Author Posted September 24, 2019 (edited) Thank you Dr_Spock for your input and response. In your post you indicate that you use the most reliable modules are they of your own design or they designed by others. I set-up my first show this past weekend and had an on-going issue of my modules getting jammed up or losing balls. What would you recommend as good reliable modules Edited September 24, 2019 by dgeehot Quote
Great Ball Pit Posted September 26, 2019 Posted September 26, 2019 Good reliable modules -> https://www.greatballpit.com/p/lego-gbc-for-beginners.html On 9/24/2019 at 10:57 AM, dgeehot said: Thank you Dr_Spock for your input and response. In your post you indicate that you use the most reliable modules are they of your own design or they designed by others. I set-up my first show this past weekend and had an on-going issue of my modules getting jammed up or losing balls. What would you recommend as good reliable modules Quote
