efferman Posted October 10, 2019 Posted October 10, 2019 For all the Backhoe Fans, would this be ok? Quote
suffocation Posted October 10, 2019 Posted October 10, 2019 Looks great to me Michael, any plans to redesign the side panels of the tracks? Quote
Aleh Posted October 10, 2019 Posted October 10, 2019 8 hours ago, suffocation said: NEWS FLASH: It depends on how you want to use the model. Mine's going to be kidhandled on all sorts of terrain by my nephews and they also appreciate a certain speed, so four XLs with a 5:1 reduction is the way to go, as I learnt from seeing them playing with my telescopic crawler crane. In that case you need separate buwizz for the chassis and second for the uppercarrage, imo :) Quote
suffocation Posted October 10, 2019 Posted October 10, 2019 (edited) 23 minutes ago, Aleh said: In that case you need separate buwizz for the chassis and second for the uppercarrage, imo :) Edited October 10, 2019 by suffocation Quote
Ngoc Nguyen Posted October 10, 2019 Posted October 10, 2019 (edited) 6 hours ago, efferman said: For all the Backhoe Fans, would this be ok? Dude, your current actions pose a great danger of second purchase for backhoe configuration for me and my wallet and thus could severly jeopardize my financial stability... Edited October 10, 2019 by Ngoc Nguyen Quote
rekreK Posted October 10, 2019 Posted October 10, 2019 7 hours ago, efferman said: For all the Backhoe Fans, would this be ok? That is what I was imagining. I think the harder part will be getting the bucket to curl and it behaving acceptably in the app... Quote
JGW3000 Posted October 10, 2019 Posted October 10, 2019 41 minutes ago, rekreK said: I think the harder part will be getting the bucket to curl and it behaving acceptably in the app You could hold the phone upside down Quote
efferman Posted October 10, 2019 Posted October 10, 2019 46 minutes ago, rekreK said: getting the bucket to curl and it behaving acceptably in the app The bigger problem is what to do with the bucket opening motor without confusing the app. Quote
Zerobricks Posted October 10, 2019 Posted October 10, 2019 5 minutes ago, efferman said: The bigger problem is what to do with the bucket opening motor without confusing the app. Just leave it spinning with nothing connected to it. Or use a third party app. Quote
jorgeopesi Posted October 10, 2019 Posted October 10, 2019 8 hours ago, efferman said: For all the Backhoe Fans, would this be ok? It is a great bucket from that side. I do not like very much those specific parts so I will try to do my buckets with pieces, may be that the next specific part will be a bed for a mining truck. Quote
rekreK Posted October 10, 2019 Posted October 10, 2019 1 hour ago, efferman said: The bigger problem is what to do with the bucket opening motor without confusing the app. It has to be left connected, might as well use it, how about ladder lowering function? Quote
efferman Posted October 11, 2019 Posted October 11, 2019 (edited) 17 hours ago, Zerobricks said: nothing connected to it For Calibration every Motor needs a endstop 15 hours ago, rekreK said: how about ladder lowering function? That is a possibility, but it needs changes on the uppercarriage edit: free instruction is comming soon Edited October 11, 2019 by efferman Quote
efferman Posted October 12, 2019 Posted October 12, 2019 (edited) The first Version of the Instruction is done. please let me know if there is a bug. https://rebrickable.com/mocs/MOC-30260/efferman/modified-face-shovel-boom-for-42100-r-9800/#bi Edited October 12, 2019 by efferman Quote
suffocation Posted October 12, 2019 Posted October 12, 2019 Thank you, Efferman! Wil try it as soon as my B&P and/or set arrive. Meanwhile I thought I'd see if the carrier was any good for a dual track mod. Seems it is, aside from the odd headache to keep the tracks stiff enough. Quote
1gor Posted October 12, 2019 Posted October 12, 2019 @suffocation it looks like undercarriage for Saturn V transporter which has 4 tracks... Quote
suffocation Posted October 13, 2019 Posted October 13, 2019 Running more tests on the carrier while I wait for my parts to be delivered. Since I expect to make the superstructure lighter, too, I switched to 4 L motors (geared down 9:1), used more frames and fewer beams and managed to shave off another hectogram ( ). I was able to move the front and back panels back one stud and added a ladder. And just for laughs, this is what the carrier would look like in black and with dual tracks Quote
efferman Posted October 13, 2019 Posted October 13, 2019 When you want to hold the look you cant save much weight. There is much air inside. two Pictures to compare the standard with my modified boom Quote
suffocation Posted October 13, 2019 Posted October 13, 2019 (edited) Any boom weight comparison pre and post mod? I'm pretty sure that simply switching from Control+ to BuWizz/PF will save a few hundred grams in the superstructure, just like it has in my carrier. Edited October 13, 2019 by suffocation Quote
efferman Posted October 13, 2019 Posted October 13, 2019 (edited) difference are 150 parts. edit: to be clear, there are 150 parts more in the modified boom than in the set boom. This means not there are not in total 150 extra parts needed Edited October 13, 2019 by efferman Quote
SNIPE Posted October 13, 2019 Author Posted October 13, 2019 10 minutes ago, efferman said: difference are 150 parts. Thanks for the mod, How about replacing the CV and UV joints with the new CV joints where possible.and 16 tooth - 16 tooth gear trains with knob wheels The new CV joints are not so hard to build around: Regards, SNIPE Quote
suffocation Posted October 13, 2019 Posted October 13, 2019 A basic idea to make the side panels a little less blocky Quote
suffocation Posted October 18, 2019 Posted October 18, 2019 (edited) Got my B&P order at last and was able to finish the carrier. Features 4 L motors geared down 8.34:1 as well as 1 M motor for slewing. All motors are driven by 1 BuWizz unit. The chassis has been redesigned to be two studs narrower front to back (in addition to getting rid of that unsightly hub sticking out of its rectal passage), lighter and much stiffer. It now weighs 1092 g and can effortlessly carry 3 kg of ballast while moving at least twice as fast as the unmodded version (haven't tried fast mode and can't try ludicrous mode as the BuWizz is ver. 1). Even with 3 kg on top, the carrier shows no flex whatsoever, which is to be expected when you cram 4 L motors and 16 5x7 frames into so little space. Once mounted, the superstructure can be removed by simply sliding out the BuWizz unit and the four red pins keeping the turntable in place. The side panels have been modded to look smoother. Edited October 18, 2019 by suffocation Quote
1gor Posted October 19, 2019 Posted October 19, 2019 I could envy you in DBG sprotckets. It looks great You are using 4 L-motors in there? Quote
suffocation Posted October 19, 2019 Posted October 19, 2019 Hi Igor, I got the DBG sprockets from Bricks&Pieces for €1.24 each. Each sprocket is driven by 1 L motor geared down 8.34:1 (12->20, 8->24, 24->40). Quite frankly I don't think I'm going to finish the model. I started building the superstructure with my spares (plus the only two XL actuators I could afford from B&P) and found it so dreadfully boring - probably the most tedious, unchallenging and uninspiring build I've ever come across. I studied the rest of the instructions and it doesn't seem to get any better, save maybe for the arm. Anyway, I got this far and it's as far as I'm willing to go. Quote
