efferman Posted November 28, 2019 Posted November 28, 2019 (edited) Thank you very much for this information: I will give it a Try edit: A basic Fake Part for the bucket instruction Edited November 28, 2019 by efferman Quote
efferman Posted November 29, 2019 Posted November 29, 2019 iam a little bit angry about myself! made the actuators and i realized the wrong length of the light bluish grey actuator part. Quote
Philo Posted November 29, 2019 Posted November 29, 2019 On 11/28/2019 at 11:56 AM, efferman said: A basic Fake Part for the bucket instruction You know that the "real thing" is available on PT with all gory details, don't you? https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/46891.dat (actually all 42100 parts are available). Quote
efferman Posted November 29, 2019 Posted November 29, 2019 Really? Could please someone make an .io with all the parts? does the ldraw actuator has a movable piston? https://bricksafe.com/files/efferman/stud.io-parts/lego xl actuator.io Quote
Philo Posted November 29, 2019 Posted November 29, 2019 52 minutes ago, efferman said: Really? Could please someone make an .io with all the parts? Did that (https://drive.google.com/open?id=1n7vUdkB4xFNDfEslgqdk-qAfXiQjP--b) but when I try to open it after removing my custom parts folder it doesn't load. Did you do something special for your LA file (which opens fine)? Quote
efferman Posted November 29, 2019 Posted November 29, 2019 (edited) Thanks 17 minutes ago, Philo said: Did you do something special for your LA file (which opens fine)? No, i only exported my parts with the partdesigner into stud.io and made the .io. As far as i know other people can use the parts which have loaded the file. Edited November 29, 2019 by efferman Quote
Philo Posted November 29, 2019 Posted November 29, 2019 25 minutes ago, efferman said: As far as i know other people can use the parts which have loaded the file. Dunno what's wrong with my file, when I open it as a zip I see the custom folder with parts inside, like in yours. Anyway... other method that I know to work fine, here is the custom parts folder containing the 42100 parts (and a few recent other ones you could find useful...). https://drive.google.com/open?id=1BY2kstW74rRNR5g5gWL1syaIEgePtIMl Add the contents to your CustomParts folder (located in C:\Users\<your user name>\AppData\Local\Stud.io) I haven't tried to add connectivity on these parts, but you seem to know how to do that Quote
efferman Posted November 29, 2019 Posted November 29, 2019 (edited) Thanks edit: all of the parts does have massive graphic bugs after exporting from part designer to stud.io. in designer the parts are looking good Edited November 29, 2019 by efferman Quote
Philo Posted November 29, 2019 Posted November 29, 2019 Yeah, already had this issue, part designer completely botches the parts. After adding connectivity, overwrite the parts with the untouched LDraw parts from the archive. Quote
Philo Posted November 29, 2019 Posted November 29, 2019 Simply copy again the folders of the archive in the same place as you did first. Connectivity is stored in another folder so no risk of losing it. Quote
efferman Posted November 30, 2019 Posted November 30, 2019 (edited) The boom is divided and i have reached roundabout step 600. edit: hires version Edited December 1, 2019 by efferman Quote
efferman Posted December 1, 2019 Posted December 1, 2019 (edited) Iam through with Dividing. 859 Steps overall. edit: Virtual Turntable Edited December 1, 2019 by efferman Quote
The Southern Brickfan Posted December 1, 2019 Posted December 1, 2019 This looks awesome!!! Thank you very much for all your hard work, and that of others who have their input. Fabulous ? Quote
Bartybum Posted December 2, 2019 Posted December 2, 2019 Mmmm Any chance of releasing an .STL of that bucket for those of us who'd like to try modify it for FDM 3D printing? Quote
efferman Posted December 2, 2019 Posted December 2, 2019 (edited) sure, the bucket was actually printed with success on a filament printer. https://www.dropbox.com/s/ing63jvogq8afwk/42100 backhoe bucket.stl?dl=0 edit: A last Gif Spoiler Edited December 2, 2019 by efferman Quote
The Southern Brickfan Posted December 4, 2019 Posted December 4, 2019 On 12/2/2019 at 6:32 PM, efferman said: sure, the bucket was actually printed with success on a filament printer. https://www.dropbox.com/s/ing63jvogq8afwk/42100 backhoe bucket.stl?dl=0 edit: A last Gif Reveal hidden contents What software would you recommend to design my own 3d stuff (as you have), and to view and print this? Or will it work with any 3d printer? Quote
efferman Posted December 4, 2019 Posted December 4, 2019 Experience i only have on Autodesk inventor and this is a proffessional CAD Program. To view an stl file you can use an actual Windows 10. it has an stl viewer inside. Not every file will work on every printer. My XL actuator for example only works on a SLS printer. Quote
Richombx Posted December 4, 2019 Posted December 4, 2019 So my bucket has turned up from shapeways, can’t wait to get a parr’s list so I can order the bits to start. Quote
The Southern Brickfan Posted December 4, 2019 Posted December 4, 2019 10 hours ago, efferman said: Experience i only have on Autodesk inventor and this is a proffessional CAD Program. To view an stl file you can use an actual Windows 10. it has an stl viewer inside. Not every file will work on every printer. My XL actuator for example only works on a SLS printer. Cool, thanks for that. I have a friend who has a 3d printer, will check to see if it will work etc. Quote
marini Posted December 5, 2019 Posted December 5, 2019 (edited) 149/5000 Bonjour Efferman, Votre moc a beaucoup de succès, existe-t-il une liste des pièces pour commencer à les acheter en attendant les instructions? Cordialement Edited December 5, 2019 by marini Quote
efferman Posted December 6, 2019 Posted December 6, 2019 I have a preliminary Part list for the 42100 Backhoe. The Partlist can be different to the final Partlist. So please dont complain if you cant wait. https://rebrickable.com/sets/compare/slow/?1-set=MOC-32297&1-inv=43247&1-user_list=&2-set=42100-1&2-inv=37842&2-user_list= Quote
Richombx Posted December 11, 2019 Posted December 11, 2019 On 12/6/2019 at 10:45 PM, efferman said: I have a preliminary Part list for the 42100 Backhoe. The Partlist can be different to the final Partlist. So please dont complain if you cant wait. https://rebrickable.com/sets/compare/slow/?1-set=MOC-32297&1-inv=43247&1-user_list=&2-set=42100-1&2-inv=37842&2-user_list= Hi efferman, I’m trying to use the store in rebrickable to buy the parts but I’m having trouble, when I compare sets it says I’m missing 650 parts but when I go to buy parts and add the standard 42100 kit to the list it says I only need 479. Kepes bricks is only missing 2 pieces 1x 24116 and 1x 98585 ( this seems to be very rare in white ). Quote
TeamThrifty Posted December 11, 2019 Posted December 11, 2019 Out of interest, what will the cost be to buy the extra parts? I got the set for £279, but i wanted the Control+ motors and hubs, so more than happy with the price i paid.. presumably the intention is to use the old motors etc? Quote
