Posted September 26, 20195 yr In my searching I have found several conveyors using the large treads, but none using the small ones. I have made several incorporated in builds but need one which can be modular so I can move it between various locations in the diorama. I was thinking of a hopper and conveyors of fixed length(s) and used together with the conveyor unloading into the next ones hopper. Power connection would be by chain drives. Any links? or examples? Thanx
September 26, 20195 yr I had one with small treads working the bunny slope last year. https://youtu.be/69gqsvKHfv0
September 26, 20195 yr I own this Lego set 62022 that haves a small ramp loader for the Lego city Airport and it haves a slot for an axle to slide through ... You should check it out!! Edited September 26, 20195 yr by sirslayer
September 27, 20195 yr I am building the famous "GBC Ball Factory" and this also uses several conveyor belts. At the right side + at the back of the model the belts are used to transport the baskets after being picked up. Links for this model at Rebrickable = https://rebrickable.com/mocs/MOC-24605/Berthil/akiyuki-ball-factory-new-style-v3/ https://rebrickable.com/mocs/MOC-2828/TheRebricker/ball-factory/ https://rebrickable.com/mocs/MOC-2459/TheRebricker/ball-factory-part-7-bucket-unloader-and-conveyor-system/
September 27, 20195 yr I searched Brickowl for conveyors and three came up but all seem to be quite rare & expensive. LEGO Conveyor 4 x 12 x 2.5 (58080) LEGO Conveyor Belt ( Shortcut)LEGO Beam The most usefull is:- 4 x 16 for Conveyer Belt Assembly (92712), I have three of these and have used them for GBC builds. Edited September 27, 20195 yr by Doug72
