CannonballCO Posted July 17, 2020 Posted July 17, 2020 Shelter-in-place has its benefits... with nowhere to go I just went ahead I figured out a complete solution based on @alademann's photo, bought the parts today (diff'd from @jb70's mod) and will test out the physical build. If it works, I'll post the io for anyone who is interested. Quote
Cumulonimbus Posted July 19, 2020 Posted July 19, 2020 I finally decided to bite the bullet and try to build the technic Defender I want. I bought a second hand 42110 as the basis for my MOD/MOC and started work a couple of weeks ago. The hardest part will be the adjustable suspension, which will require a completely new chassis. I have figured out a geometry which gives me the necessary range and stability and will be compact enough to fit inside the 42110 body. The image below is a quick snapshot of my testmule which gave me the confidence to post this first update. A lot of unknowns at the moment and it will undoubtedly be slow progress, we'll see where this ends. More updates will follow ... Quote
Cumulonimbus Posted July 24, 2020 Posted July 24, 2020 I managed to fit the necessary mechanisms inside the 42110 body and the image below shows the range of movement: Quote
thekoRngear Posted August 3, 2020 Posted August 3, 2020 (edited) Hello guys, I have decided to change my 42110. I call it Lego Technic 42110- Lite Version. This version is basically for those who don't have enough parts or are unable to find/buy new parts to build the JB70 Pimped up version. Dont have enough resources/currently unable to RC it either. The Pimped up 42110 is a fantastic MOC. However, as it is mentioned above I dont have options to add or buy required parts and, I personally do not like a vehicle whose front seats and rear seats basically floats above a sea of gears right from the front to the very back. It looks weird, at least to me. Changes: 1. Removed the rear gearbox completely. As a result, the infamous (or the victims of the infamous rear gearbox) u-joints are also removed. They are now used on the frame of the main doors (and they are not aligned lol) 2. Modified the front gearbox with a 4 speed one. The front gearbox has two structures- one on the front and another one in the back. I have modified them to fit in the not so symmetric drivetrain of Defender. The black beam which sits right beneath the front gearbox has now simplified installation. The gears have noticeable speed difference with Engine piston movements when being hand moved. 3. Changed the position of the front and rear diffs. The crowns are now facing opposite to each other 4. Changed the position of centre differential Other changes to match my personal taste: i. removed the winch ii. Added a hood stand (from Grohl's Unofficial B model) iii. Modified the front grey shock absorbers by stiffening them using the little parts iv. replaced the blue pins with black pins for each of the four fenders. The blue pins among the Defender Olive Green is an eye-sore for me. Total 8 black pins were needed v. Used a long rod to connect the rear door (with the tyre) down to one of the holes of the upper bottom beam because when you open and close the rear door (may or may not happen to you) the door with the tyre has considerable amount of force causing the connecting parts get out a bit of their place. vi. From my observation, I have seen behind the steering wheel the dashboard's bottom part gets loose/looks like it is hanged if removed later. That black pin connecting all the parts was not doing a great job. I have replaced that with a blue pin. vii. The back red lights are flimsy. I have replaced the upper part smaller pins with a long blue pin. They are now sturdy. viii. Changed the inner side of the main doors mechanism. ix. Lots of small visual changes This mod is from someone who is a noob, knows not so much about gears, just want to have a vehicle for when he moves it does not crack with simplified gearing. It is not geartastic, but it's nice. Edited September 10, 2020 by thekoRngear Updated the Mod Quote
Mike08 Posted August 14, 2020 Posted August 14, 2020 Hello, Thought I'd share what I'm working on, inspired by a Defender 110 MOC. I'm creating my own 110 as closely accurate to real sizing as possible. The rear doors are difficult as the real ones are part of the rear mudguard. The black roof and hood are accurate as the Defender has this livery as well. This is my very first time using Studio so lot of trial and error before it is complete. And seeing all these mods, I will be implementing a lot when I start building mine. Quote
CannonballCO Posted August 14, 2020 Posted August 14, 2020 1 hour ago, Mike08 said: Hello, Thought I'd share what I'm working on, inspired by a Defender 110 MOC. I'm creating my own 110 as closely accurate to real sizing as possible. The rear doors are difficult as the real ones are part of the rear mudguard. The black roof and hood are accurate as the Defender has this livery as well. [...] Wow 4-door version! Nice! Following! Quote
DrJimbo Posted August 15, 2020 Posted August 15, 2020 Recently finished this, it was a nice build. I went with the Pimp up my... version from the get go (thanks @jb70 and all involved). A few simple, mostly cosmetic mods: went for the V6 engine using traditional blocks involved a slight change to the steering linkage and I think a slightly higher engine speed stiffer suspension bullbars & lights at front extended roofrack and lights added the full set of jerry cans from 42069 snorkel lockable doors Quote
Bartybum Posted August 16, 2020 Posted August 16, 2020 8 hours ago, DrJimbo said: *snip* Looking good. In future, you can upload to to an external image hosting site and copy the link to it in your comment, and it'll automatically embed it. That way you can share high-res images. I highly recommend doing it via Imgur, because it's super quick and doesn't require an account Quote
DrJimbo Posted August 16, 2020 Posted August 16, 2020 (edited) 18 hours ago, Bartybum said: Looking good. In future, you can upload to to an external image hosting site and copy the link to it in your comment, and it'll automatically embed it. That way you can share high-res images. I highly recommend doing it via Imgur, because it's super quick and doesn't require an account Thanks. Here is the landrover in all it's glory Edited August 16, 2020 by DrJimbo link update x3 Quote
onzenuub Posted August 16, 2020 Posted August 16, 2020 (edited) 6 minutes ago, DrJimbo said: Thanks. Here is the landrover in all it's glory https://imgur.com/a/zzthJbu Edited August 16, 2020 by onzenuub Quote
DrJimbo Posted August 16, 2020 Posted August 16, 2020 Ok, and now the bit I'm most pleased with: the half unit offset for the doors allowed this simple locking mechanism: Locked door Unlocked door: Locking mechanism: There is a perfectly positioned gap to receive the 5L beam: Quote
SimonCK Posted August 24, 2020 Posted August 24, 2020 thanks Dr Jimbo for sharing the door lock pictures, I've copied it and it works nicely. Quote
DrJimbo Posted August 25, 2020 Posted August 25, 2020 Glad you liked it! I am ridiculously pleased with how this ~10 part construction worked out. Quote
JaBaCaDaBra Posted August 25, 2020 Posted August 25, 2020 (edited) 2 hours ago, DrJimbo said: Glad you liked it! I am ridiculously pleased with how this ~10 part construction worked out. Simplicity marks the genius. Whooha, this is real good. Edited August 25, 2020 by JaBaCaDaBra Quote
chlego Posted August 27, 2020 Posted August 27, 2020 On 8/14/2020 at 6:36 PM, Mike08 said: Hello, Thought I'd share what I'm working on, inspired by a Defender 110 MOC. I'm creating my own 110 as closely accurate to real sizing as possible. The rear doors are difficult as the real ones are part of the rear mudguard. The black roof and hood are accurate as the Defender has this livery as well. This is my very first time using Studio so lot of trial and error before it is complete. And seeing all these mods, I will be implementing a lot when I start building mine. Whoah this is amazing! I love the contrasting black color, which you placed also on the bonnet. I think that really is a key design feature of the real thing. I also like the way you aligned the rear mudguard and the door. Quote
Some Belgian LEGO Fan Posted August 28, 2020 Posted August 28, 2020 On 8/16/2020 at 9:57 PM, DrJimbo said: Ok, and now the bit I'm most pleased with: the half unit offset for the doors allowed this simple locking mechanism: Locked door Unlocked door: Locking mechanism: There is a perfectly positioned gap to receive the 5L beam: Nicce and simple solution! It works better than my previous design of a door lock. Allow me to improve only a little bit on this design: This way, the door handle can't be turned upwards that far. Quote
Mike08 Posted August 31, 2020 Posted August 31, 2020 On 8/27/2020 at 5:52 PM, chlego said: Whoah this is amazing! I love the contrasting black color, which you placed also on the bonnet. I think that really is a key design feature of the real thing. I also like the way you aligned the rear mudguard and the door. Thanks, I really like the combination too! On 8/14/2020 at 7:42 PM, CannonballCO said: Wow 4-door version! Nice! Following! Thanks! I have started on the chassis and based it on JB70's pimp my land rover mainly for the gearbox. I redesigned the front section to get Ackermann steering with these wheels. I've lengthened the chassis by 7 studs for the rear doors. Next step is to find a way to connect the steering wheel, I changed the steering gears to get 360* rotation in both directions but haven't been able to connect it yet. Quote
DrJimbo Posted August 31, 2020 Posted August 31, 2020 On 8/28/2020 at 10:46 PM, Some Belgian LEGO Fan said: Nicce and simple solution! It works better than my previous design of a door lock. Allow me to improve only a little bit on this design: This way, the door handle can't be turned upwards that far. Thanks, this is a nice improvement. Quote
barbanera Posted November 9, 2020 Posted November 9, 2020 (edited) On 8/31/2020 at 12:48 PM, Mike08 said: Thanks, I really like the combination too! Thanks! I have started on the chassis and based it on JB70's pimp my land rover mainly for the gearbox. I redesigned the front section to get Ackermann steering with these wheels. I've lengthened the chassis by 7 studs for the rear doors. Next step is to find a way to connect the steering wheel, I changed the steering gears to get 360* rotation in both directions but haven't been able to connect it yet. Hi congratulations, nice work. I have too decided to rebuild my defender in 110 version Edited November 28, 2020 by barbanera Quote
Gregdabrat Posted November 9, 2020 Posted November 9, 2020 On 11/9/2019 at 1:51 AM, twoofive said: Maybe these help:-) Woah! Can you do a tutorial on that? I hate that extra gearbox in the back! Quote
Gregdabrat Posted November 12, 2020 Posted November 12, 2020 I made a cyber truck Land Rover: PXL_20201112_045902600 by Gregdabrat Nunya, on Flickr PXL_20201112_045907489 by Gregdabrat Nunya, on Flickr Quote
Bartybum Posted November 17, 2020 Posted November 17, 2020 Keen to see how that turns out @barbanera. I've seen a bunch of extension mods to the set and they all just clone the front door, making it look ridiculous, so a brand new rear door is definitely interesting to see Quote
