syclone Posted September 3, 2021 Posted September 3, 2021 (edited) 3 hours ago, advent_chyld said: Sorry if it's wrong place to post but I am having trouble with my defender I finished building. The rear wheels don't roll forward together , they are rolling in the opposite directions. I've tried double checking things from the manual but haven't found a solution yet 1. Do you mean the front wheels and the rear wheels roll in opposite directions? Then one of the differentials is installed the wrong way. 2. But if it's the same axle (if you rotate the right wheel forward and left wheel is rolling the opposite direction) then it's normal - that's how a differential works. Nonetheless if you take both rear wheels and rotate them together and the front wheels rotate the opposite direction - the differential gear is the wrong way. Refer to this picture by Jim from his review - Both differentials should have the gear on the same side. Edited September 3, 2021 by syclone Quote
nerdsforprez Posted September 3, 2021 Posted September 3, 2021 (edited) 9 hours ago, Polarlicht said: Painted whe wheels white a while ago. Yes. Big fan. Edited September 3, 2021 by Milan Do not quote the whole block of pictures, please. Quote
romashkaman Posted September 3, 2021 Posted September 3, 2021 8 hours ago, Polarlicht said: But now ordered new ones and tried this. Quite like this better. Looks awesome! Is it possible to describe how to paint them with such accuracy? Quote
advent_chyld Posted September 3, 2021 Posted September 3, 2021 9 hours ago, noahtheb said: I'm not an expert at technic, but maybe check the rear differential? It could be facing the wrong way or the gears may be messed up. Thanks for replying. think I have checked that (not home right now) but i have recorded a video if it helps. (Sorry it's on tiktok) https://vm.tiktok.com/ZSJTMM2c3/ Quote
noahtheb Posted September 3, 2021 Posted September 3, 2021 Sorry, I can't go on tiktok, but if it's a youtube vid I should be able to watch it. Quote
syclone Posted September 3, 2021 Posted September 3, 2021 (edited) 12 minutes ago, advent_chyld said: Thanks for replying. think I have checked that (not home right now) but i have recorded a video if it helps. (Sorry it's on tiktok) https://vm.tiktok.com/ZSJTMM2c3/ m8.... that's a differential's normal function. The inner spur gears allow the wheels to have different speeds. https://en.wikipedia.org/wiki/Differential_(mechanical_device) However please check if you built your gearbox correctly - as it seems that is the issue from your video since the red central differential doesn't move. Edited September 3, 2021 by syclone Quote
Polarlicht Posted September 3, 2021 Posted September 3, 2021 3 hours ago, romashkaman said: Looks awesome! Is it possible to describe how to paint them with such accuracy? With a toothpick, to have the tiniest paint drop on the tip. Quote
romashkaman Posted September 3, 2021 Posted September 3, 2021 1 hour ago, Polarlicht said: With a toothpick, to have the tiniest paint drop on the tip. Thanks! Will try it. Quote
advent_chyld Posted September 3, 2021 Posted September 3, 2021 10 hours ago, syclone said: 1. Do you mean the front wheels and the rear wheels roll in opposite directions? Then one of the differentials is installed the wrong way. 2. But if it's the same axle (if you rotate the right wheel forward and left wheel is rolling the opposite direction) then it's normal - that's how a differential works. Nonetheless if you take both rear wheels and rotate them together and the front wheels rotate the opposite direction - the differential gear is the wrong way. Refer to this picture by Jim from his review - Both differentials should have the gear on the same side. Not sure but I will have a look. I should be able to see the problem with that picture, thanks! Quote
Logui Posted September 4, 2021 Posted September 4, 2021 Hi everyone, for those who would like to customize the rear of their Defender, here are : the .io file to reproduce rear bumper, hitch and exhaust pipes by @harrygee the corresponding bricklink .XML file inventory Quote
BrickWild Posted November 13, 2021 Author Posted November 13, 2021 It is now possible to get light bluish grey rims (49294) for 42110 Land Rover Defender! (they originally come in the new 75313 AT-AT).https://www.bricklink.com/v2/catalog/catalogitem.page?P=49294&C=86#T=C&C=11 I might order five of these and see what they look like! Quote
Polarlicht Posted November 13, 2021 Posted November 13, 2021 (edited) Really? I actually want them in grey as well. LR offers them in black or grey IRL too! Ordered 5 black new ones from Lego the other day. Couldn't you tell me earlier? Asked them if they could take it out of the order, when its still in warehouse. Currently selling my white and black/silver ones. Iam dreaming about those rims in LBG for some time. Edited November 13, 2021 by Polarlicht Quote
2GodBDGlory Posted December 7, 2021 Posted December 7, 2021 Wow, that's very distinctive! It's cool to see the white, the four-door conversion is interesting, and the rarer shocks are cool too. Also, I'm excited to finally see a car built with the wide motorcycle tires! I can't say this is the style of Defender I'd want in real life, though... Quote
Zerobricks Posted December 7, 2021 Posted December 7, 2021 Did you use only one rim to hold the tyre? Quote
Scoar Sonander Posted December 7, 2021 Posted December 7, 2021 What 3rd party shocks are those? Quote
kenkwong Posted December 7, 2021 Posted December 7, 2021 1 hour ago, 2GodBDGlory said: Wow, that's very distinctive! It's cool to see the white, the four-door conversion is interesting, and the rarer shocks are cool too. Also, I'm excited to finally see a car built with the wide motorcycle tires! I can't say this is the style of Defender I'd want in real life, though... Thanks mate, let's just think of it as a performance road version of the model 27 minutes ago, Zerobricks said: Did you use only one rim to hold the tyre? One rim and a 77107 support piece 19 minutes ago, Scoar Sonander said: What 3rd party shocks are those? It's the shocks from 8369 Quote
SNIPE Posted December 8, 2021 Posted December 8, 2021 10 hours ago, kenkwong said: Giving my defender a new look Fabulous parts usage. I have done the same trick with those harley davidson rear tyres for a modern 8462 set im working on. How did you make room to fit those huge rare lego shock absorbers in? Quote
kenkwong Posted December 8, 2021 Posted December 8, 2021 2 hours ago, SNIPE said: Fabulous parts usage. I have done the same trick with those harley davidson rear tyres for a modern 8462 set im working on. How did you make room to fit those huge rare lego shock absorbers in? I had to offset the ball joint to the side to make room for the shocks which is a stud wider than the original design. Unfortunately, none of the car rims would fit because of that (probably 8448 wheels would but it doesn't look as good). Btw I believe there is enough room to fit diff locks to the front and rear axle if anyone wants to explore it further Quote
Zerobricks Posted December 8, 2021 Posted December 8, 2021 Brillinat idea with the 77107 to hold the tyre. Unfortunately the old gearbox ring does not fit into the new differential. Quote
SNIPE Posted December 8, 2021 Posted December 8, 2021 32 minutes ago, kenkwong said: I had to offset the ball joint to the side to make room for the shocks which is a stud wider than the original design. Unfortunately, none of the car rims would fit because of that (probably 8448 wheels would but it doesn't look as good). Btw I believe there is enough room to fit diff locks to the front and rear axle if anyone wants to explore it furthet The old 2L drive ring does not work with the new differential like that unfortunatley Heres one way to do it: LDR file You might want to clamp down the shifter ring more and maybe have 3 planes of gears instead of just 28 to 20 (two planes) I even managed to fit in the gear rack, engine and winch: I just used an 8 tooth gear as a dial to move the orange changeover catch but you could probably fit in a bevel gear pair instead. Quote
kenkwong Posted December 8, 2021 Posted December 8, 2021 16 minutes ago, Zerobricks said: Brillinat idea with the 77107 to hold the tyre. Unfortunately the old gearbox ring does not fit into the new differential. Another drawback of using studio.io hah thanks buddy 13 minutes ago, SNIPE said: The old 2L drive ring does not work with the new differential like that unfortunatley Heres one way to do it... Sounds like a plan! well done mate Quote
thekoRngear Posted December 10, 2021 Posted December 10, 2021 That's an eye-pleaser. The wheels are from AT-AT? Quote
