MangaNOID Posted November 7, 2019 Posted November 7, 2019 On 11/5/2019 at 3:13 AM, twoofive said: Did some work on the defender:-) ..... It now has a 2 speed gear box through the shifters on the center console. a few more photos to show off the interior changes would be great! I think 2 speed gearbox is sufficient for a great technic model as long as its in the right place (?) as putting a gearbox through almost the whole chassis teaches no one anything about how cars work. sure its very technical to have 8 speed gearboxes n stuff, but.... so nice mods indeed Quote
alecmo99 Posted November 7, 2019 Posted November 7, 2019 Thanks for the addition of the PF lights. Can’t wait to add them to my copy! Quote
nerdsforprez Posted November 8, 2019 Posted November 8, 2019 On 11/6/2019 at 5:58 AM, SimonCK said: Hi Everyone I've built my defender to the stage where I can add the wheels to test the gearbox/engine before I start adding the bodywork. It is suffering badly from the tension problem that others have experienced. My question - I saw a comment in another thread about changing the gear ratio from the differentials from 8t-24t to 16t-16t. Does this meaning changing two sets of 8t-24t gears? There is one set in the middle of the car just behind the gear selector and another set right at the back behind the rear differential? Also how would this help, does it reduce tension by equalising the ratios. I guess it would speed up the engine too which would be a good thing because it turns very slowly. Thanks, Simon For anyone still having cracking issues I recommend they follow the advice from @racingbrick's youtube video (already posted). Works terrifically. Quote
Tonyst4rk80 Posted November 8, 2019 Posted November 8, 2019 Hi Waiting to receive this model, I'm looking at a few modifications including a main : integration of a 6-cylinder V engine (according Twoofive's idea) For that, I use Studio+2.0, but I didn't have more details than the Twoofive photos, I had to find a solution by myself... The integration of the motor + transmission is 100% completed, the problem is the modification of the direction axis. According to my idea, this one is composed of 4 U-joint, but in reality I'm afraid it doesn't work properly in the state... So I send you my file > https://www.mediafire.com/file/fc4wd0hah7l3agy/42110v6_Copy.io/file in the hope that you have a better idea to share. Twoofive's help would also be appreciated Thanks for all Quote
piterx Posted November 8, 2019 Posted November 8, 2019 hi there everyone! this model just got me back from a second dark age but i will be back soon :D How's everyone? gettin back on topic: did I mount something wrongly or the gearbox of this model goes extremely slowly and the fake engine barely moves when i push it on my desk? Quote
DataNinja Posted November 9, 2019 Posted November 9, 2019 (edited) My 2nd favorite(*) community-developed feature on 42056 Porsche 911 GT3 RS was the lift-off body mod (Credit to @Jetro but later modified by @Didumos69 and @jb70). Made the innards much more fun to see! So in their honor I had to make an attempt here. I present an early version of a lift-off body mod for the Defender: https://bricksafe.com/pages/dataninja/42110-liftoff-body-mod My goal was to keep the looks and functions of the vehicle identical, so I ended up sacrificing a little structural support. I don't think this holds together yet as well as the original model, so could use some additional reinforcement. This 1st version doesn't use many additional parts, only a few black 2L friction pins and a dozen red 3L pin+bush. In the .io file I grouped the pieces into 2 steps, hoping to make it easy to hide the top and see the bottom, or other way around. Still to work on/improve: - Not happy with the way the seats attach to the lower body, front or back... - Create a PDF showing specific steps - Add structural reinforcement to make it as sturdy as the original Thanks for @BrickWild for the Stud.io file I tweaked with necessary mods. (*) You didn't ask, but my absolute favorite feature was Didumos69 's 90-degree limiter / shift block. Such an elegant solution, and made the model much more fun than the original. Lego must agree, Milan put a similar function in the Defender! Edited November 13, 2019 by DataNinja Miscredited another designer for jb70's Pump up my Porsche mod. Sorry! Quote
twoofive Posted November 9, 2019 Posted November 9, 2019 On 11/6/2019 at 12:58 PM, SimonCK said: Hi Everyone I've built my defender to the stage where I can add the wheels to test the gearbox/engine before I start adding the bodywork. It is suffering badly from the tension problem that others have experienced. My question - I saw a comment in another thread about changing the gear ratio from the differentials from 8t-24t to 16t-16t. Does this meaning changing two sets of 8t-24t gears? There is one set in the middle of the car just behind the gear selector and another set right at the back behind the rear differential? Also how would this help, does it reduce tension by equalising the ratios. I guess it would speed up the engine too which would be a good thing because it turns very slowly. Thanks, Simon It is indeed just to speed up the engine, and both pairs need to be replaced:-) 14 hours ago, Tonyst4rk80 said: Hi Waiting to receive this model, I'm looking at a few modifications including a main : integration of a 6-cylinder V engine (according Twoofive's idea) For that, I use Studio+2.0, but I didn't have more details than the Twoofive photos, I had to find a solution by myself... The integration of the motor + transmission is 100% completed, the problem is the modification of the direction axis. According to my idea, this one is composed of 4 U-joint, but in reality I'm afraid it doesn't work properly in the state... So I send you my file > https://www.mediafire.com/file/fc4wd0hah7l3agy/42110v6_Copy.io/file in the hope that you have a better idea to share. Twoofive's help would also be appreciated Thanks for all Hey, nice work you did there:-) i tried to rebiuld the steering to the steering wheel, and it worked, but then came the moment that i ambraced the v8 instead of v6. Its just the same as the v6, but without the engine mount bracket things. Steering wheel adaptation to inner vehicle is not possible anymore now. But why ? You cant use the wheel, so in my honest opinion not a must:-) I see some of you ask me to provide instructions of my mods? If you want more pictures to build it please ask, and i will make photos. Not planning to make ' instructions' because i wouldnt know how:-( Quote
Bricktrain Posted November 10, 2019 Posted November 10, 2019 On 10/29/2019 at 9:35 PM, romashkaman said: @Bricktrain could you make the video of the test of your configuration?) I guess the performance should be quite the same as 42099's, correct me if I'm wrong (in case there is no additional gear reduction or whatever else) This one I built for a friend, I hope to build my own in the next week or so. Quote
Tonyst4rk80 Posted November 10, 2019 Posted November 10, 2019 (edited) I improved the steering axis with some internal changes, now this one consists of 3 U-joints instead of 4. It's better, but I still have a doubt about the reliability, because everything goes to millimeter and considering the number of joints, I miss a support axis to prevent it from moving during rotations ... I also made some changes seen on eurobrick : On the front, replacement of the lights stickers with real lights + addition of a shield On the doors, addition of a locking system On the transmission, replacement of two axes of 4 and 8 by a single of 12 Some pics : .io file >> http://www.mediafire.com/file/6msidvehp5l9y18/42110v6.io/file Edited November 10, 2019 by Tonyst4rk80 Quote
JunkstyleGio Posted November 11, 2019 Posted November 11, 2019 @Tonyst4rk80 I took your big Boo-bar and made some attachment- and light changes. Looks good on the Landy! Did it in metalized Silver to show how beautifull it looks. In black it is still awesome! Quote
twoofive Posted November 11, 2019 Posted November 11, 2019 Nice build, those renders, what program is used and can i also use it? Quote
JunkstyleGio Posted November 11, 2019 Posted November 11, 2019 (edited) Models made in LDD and Stud.io. Renders made in Stud.io Works in real life too. (only two parts missing...) Edited November 11, 2019 by JunkstyleGio Quote
twoofive Posted November 11, 2019 Posted November 11, 2019 Awesome:-) rebuild my version , curved on top and added 2 lights:-) Thx, i go on search for the programs:-) Quote
nerdsforprez Posted November 11, 2019 Posted November 11, 2019 Chrome Grill looks amazing. I think I might apply it to mine. Question for the group- I know if Chrome City Bricks and Real Chrome on BL but the parts selection is so limited. I see so many with pics of a part selection much more extensive than what I see at either of these two stores. ANyone have recommendations of other stores? Quote
JunkstyleGio Posted November 12, 2019 Posted November 12, 2019 Made instructions for @Tonyst4rk80 boo-bar. Had my mod's included. Bricklink Gallery https://www.bricklink.com/v3/studio/design.page?idModel=109425 or Rebrickable https://rebrickable.com/mocs/MOC-31290/JunkstyleGio/big-boo-bar-with-lights-for-defender/#comments Happy Building! Quote
br0ken4life Posted November 12, 2019 Posted November 12, 2019 can someone help me use Studio? Im trying to use these Mods above and I have no idea what to do. I loaded the file and see the entire car, im trying to do the Body removal MOD. Thank you for any help! Quote
coinoperator Posted November 12, 2019 Posted November 12, 2019 2 hours ago, JunkstyleGio said: Made instructions for @Tonyst4rk80 boo-bar. Had my mod's included. Bricklink Gallery https://www.bricklink.com/v3/studio/design.page?idModel=109425 or Rebrickable https://rebrickable.com/mocs/MOC-31290/JunkstyleGio/big-boo-bar-with-lights-for-defender/#comments Happy Building! Link not working, picture not visible Quote
JunkstyleGio Posted November 12, 2019 Posted November 12, 2019 @coinoperator, everything seems to be working perfectly here... Quote
romashkaman Posted November 12, 2019 Posted November 12, 2019 @coinoperator yes, everything works, problems are on your side) Quote
jb70 Posted November 12, 2019 Posted November 12, 2019 (edited) IMO the original design has a big mistake: the gear sequence is wrong: If you switch to a higher gear, the engine speeds up. Everybody knows, that in real cars the engine speeds up, when you switch to a lower gear. The reverse gear had a gear ratio similar to 4th gear and did not have any impact on Hi/Lo switch. So I totally redesigned the complete gear train. And as a side effect I could get rid of the 4 universal joints to connect the gearbox. Now the gearbox is directly connected to the DNR switch with straight axles, avoiding friction and torsion in the gear train. MPD file and PDF instructions have been published on rebrickable.com: So pimp up your Landrover, if you like! Edited February 17, 2020 by jb70 Links updated Quote
blondasek Posted November 13, 2019 Posted November 13, 2019 @jb70 we already spoke about that, it was done on purpose :) If the kid will see that engine is spinning faster, he will fill that it is higher speed :) Quote
Vectormatic Posted November 13, 2019 Posted November 13, 2019 @jb70 Excellent work! Will you be keeping the Pimp up my landrover project going like with the porsche/bugatti? Ill probably build it in pimped out spec straight away when i finally get one. Quote
DataNinja Posted November 13, 2019 Posted November 13, 2019 14 hours ago, jb70 said: IMO the original design has a big mistake: the gear sequence is wrong: If you switch to a higher gear, the engine speeds up. Everybody knows, that in real cars the engine speeds up, when you switch to a lower gear. The reverse gear had a gear ratio similar to 4th gear and did not have any impact on Hi/Lo switch. So I totally redesigned the complete gear train. And as a side effect I could get rid of the 4 universal joints to connect the gearbox. Now the gearbox is directly connected to the DNR switch with straight axles, avoiding friction and torsion in the gear train. MPD file and PDF instructions have been published on rebrickable.com: So pimp up your Landrover, if you like! Nice tranny rebuild! Looks like you resolved problem I was having with a gear clicking, looked to me like it was the big gear on the red diff rubbing into the red bush right next to it. Was never a fan of the universal joints throughout the drivetrain, so very excited about trying yours out. When I get pieces in I'm going to try to combine my liftoff body mod with your PDF. Thanks for your efforts! Quote
