Ngoc Nguyen Posted December 11, 2019 Posted December 11, 2019 1 hour ago, Meatman said: Yeah, the gear connects to the housing How exactly does the red gear connect to the housing? Does the housing have pins that snap into pinholes in the gear? Quote
Rudivdk Posted December 12, 2019 Posted December 12, 2019 10 hours ago, Ngoc Nguyen said: How exactly does the red gear connect to the housing? I haven't seen it, but I would guess something similar to turntables or wheel hubs... which would mean the red gear is useless for anything else but the diff... Quote
1gor Posted December 12, 2019 Posted December 12, 2019 1 hour ago, Rudivdk said: I haven't seen it, but I would guess something similar to turntables or wheel hubs... which would mean the red gear is useless for anything else but the diff... Perhaps it could be used similar as 20 or 16 tooth gear with clutch only without driving ring; just my guess... Quote
Zerobricks Posted December 12, 2019 Posted December 12, 2019 (edited) 7 hours ago, I_Igor said: Perhaps it could be used similar as 20 or 16 tooth gear with clutch only without driving ring; just my guess... I'm pretty sure that's the case and that it will also be used in the gearbox of the upcoming supercar - probably as a reverse gear or such. Edited December 12, 2019 by Zerobricks Quote
Meatman Posted December 12, 2019 Posted December 12, 2019 19 hours ago, Ngoc Nguyen said: How exactly does the red gear connect to the housing? Does the housing have pins that snap into pinholes in the gear? If I remember correctly, there are 3 clips on the housing that snap into the gear. What I don't know is if the gear can easily be removed or not. 8 hours ago, I_Igor said: Perhaps it could be used similar as 20 or 16 tooth gear with clutch only without driving ring; just my guess... I could be wrong, but from the brief bit that I had seen, it didn't appear that this gear had any clutch capabilities like the 20 and 16 tooth gears have. At least one side of it doesn't. Quote
1gor Posted December 12, 2019 Posted December 12, 2019 (edited) 13 minutes ago, Meatman said: I could be wrong, but from the brief bit that I had seen, it didn't appear that this gear had any clutch capabilities like the 20 and 16 tooth gears have. At least one side of it doesn't. I was thinking without clutch capabilities...only to spin on axle but without possibility to be "locked" with driving ring Regards Edited December 12, 2019 by I_Igor Quote
HorcikDesigns Posted December 13, 2019 Posted December 13, 2019 At first sight I was hoping for the clutch gear-style type of connection, but then I realized, that every clutch gear is loose on the driving ring. I do not want backlash on diff, so I hope for better differential-specific solution, however new clutch gear would be also good addition.. Quote
Homersapien Posted December 13, 2019 Posted December 13, 2019 The top gear car is on the lego online shop for some days now, nobody got it yet?! Quote
Toastie Posted December 13, 2019 Posted December 13, 2019 Impossible - Santa bought all of them to give it on Christmas eve to the Technic Gurus ... Best Thorsten Quote
kbalage Posted December 13, 2019 Posted December 13, 2019 49 minutes ago, Homersapien said: The top gear car is on the lego online shop for some days now, nobody got it yet?! It's there since the announcement but the shipping date is still the 26th, when the reviews will go online. Quote
Permo Posted December 13, 2019 Posted December 13, 2019 I'll just buy the diff when it shows up in the store... Quote
Ngoc Nguyen Posted December 17, 2019 Posted December 17, 2019 Who would have thought this set contains TWO 7x11 white frames Quote
Gray Gear Posted December 17, 2019 Posted December 17, 2019 5 minutes ago, Ngoc Nguyen said: Who would have thought this set contains TWO 7x11 white frames Not me. 7x11 Frames are very useful, and I need more. Why in white tho? I bet they arn't visible at all, so black would have been better. But eh. Quote
1gor Posted December 17, 2019 Posted December 17, 2019 16 minutes ago, Gray Gear said: Not me. 7x11 Frames are very useful, and I need more. Why in white tho? I bet they arn't visible at all, so black would have been better. But eh. That is what crossed my mind; at the first it looked like there are light bluish gray frames and now I see they are black...they are visible from bottom and front is visible if you open front hood... Quote
mahjqa Posted December 17, 2019 Posted December 17, 2019 (edited) So, diff is 2 parts, a gear and a housing. Also, there's 5 tan 12z gears in the set, I bet they all go inside the diff. It's got 120 degrees rotational symmetry, so that would fit just right. Edited December 17, 2019 by mahjqa I spel gud Quote
Cardboy Posted December 17, 2019 Posted December 17, 2019 looking at the new dif do we think that the wide end on the right engages the new 28 gea? (as that has a different moulding to the current idle gears) and the left hand can accept the current gears? Be nice to see it in more detail. Quote
Zerobricks Posted December 17, 2019 Posted December 17, 2019 (edited) The new red gear seems to have the axle hole only half the width, which would make sense, since it has to accomodate the 12 tooth gear. I'm afraid it can't be engaged and used in gearboxes... Edited December 17, 2019 by Zerobricks Quote
mahjqa Posted December 17, 2019 Posted December 17, 2019 On the other hand, the LBG gear housing does look like it would accept a clutch. Quote
Gray Gear Posted December 17, 2019 Posted December 17, 2019 1 hour ago, Zerobricks said: The new red gear seems to have the axle hole only half the width, which would make sense, since it has to accomodate the 12 tooth gear. I'm afraid it can't be engaged and used in gearboxes... Yes, and the diff can't work without the gear, so it is inferior to the old diff in a center diff application. Danm. Quote
Maaboo the Witch Posted December 17, 2019 Posted December 17, 2019 7 minutes ago, Gray Gear said: Yes, and the diff can't work without the gear, so it is inferior to the old diff in a center diff application. Danm. Who designed that?! Quote
Ngoc Nguyen Posted December 17, 2019 Posted December 17, 2019 That video doesnt have parts review, speed build, or at least examination of the new diff. What a disappointment... Quote
Zerobricks Posted December 17, 2019 Posted December 17, 2019 Lol, it seems to crawl up a higer grade than 42099... Quote
Meatman Posted December 17, 2019 Posted December 17, 2019 (edited) What keeps the rear axles from pulling out? Just friction? Probably bushings on them between liftarms. Edited December 17, 2019 by Meatman Quote
mahjqa Posted December 17, 2019 Posted December 17, 2019 Called it; 5 12z gears inside the diff. Sadly, Lego's own Control+ app doesn't seem to be available for this model just yet. Quote
