Hello there!
Recently I've become a lucky owner of almost all LEGO Life on Mars Martian sets, and I want to make reviews of them some day. Previously I owned only Aero Tube Hangar and Recon-Mech RP, but published only the review of the first set here. Now it's time to show you the second one.
- A meteorite is detected south of the hangar. It is probably rich in biodium. Antares, bring it to the base.
- Acknowledged, General Riegel. Pneumo pump, destination point - Recon-Mech RP bay.
49167243541_ae43daa096_b.jpgAntares in Aero Tube Hangar by Farseer Eldar, on Flickr
49167244246_ce94d269ba_b.jpgRecon Mech RP Parked by Farseer Eldar, on Flickr
49167476887_5094908a30_b.jpgAntares near the Cockpit by Farseer Eldar, on Flickr
- Full speed ahead!
49166766088_714a193e8e_b.jpgMech Deployed by Farseer Eldar, on Flickr
Set Name: Recon-Mech RP
Set Number: 7314
Year of Release: 2001
Number of Pieces: 194
Number of Minifigures: 1 (Martian)
Price: $ 20.00 ($ 0.10 per brick)
Recon-Mech RP (the acronym probably stands for Red Planet) is made for scouting and meteorite gathering. It cannot take as much meteorites as Excavation Searcher (7316, now I own this one too!), but is more mobile and has a burner for ore extraction. Life on Mars is the first LEGO series that contains walking mechs, so it can be seen as a predecessor of Exo-Force.
Box
The box is rather usual, without any special features. It has a set name, a pieces count and a reminder that it is a building toy but not a cauliflower soup. This means that I got an American variation of the set (meanwhile, my Aero Tube Hangar was European one and did not contain writings on the box).
49167477612_7f7e64f66b_b.jpgRecon Mech RP Box by Farseer Eldar, on Flickr
On the back side, the transformation process is shown (I will demonstrate it later):
49167244111_b51b66ceb3_b.jpgRecon Mech RP Box Back by Farseer Eldar, on Flickr
Instruction Booklet
The instruction is small and bears the same image as the box does:
49167477512_22ed319bb6_c.jpgRecon Mech RP Instruction Front by Farseer Eldar, on Flickr
The first pages:
49167477487_16fea328aa_b.jpgRecon Mech RP Instruction First Page by Farseer Eldar, on Flickr
The end of the assembly:
49166765888_1228f0ef6e_b.jpgRecon Mech RP Instruction Assembly Completed by Farseer Eldar, on Flickr
Then the transformation is shown in steps:
The last pages contain the combinations of different sets, and one of them is a hybrid between Martian and human technology:
49167244031_3efbbb8069_b.jpgRecon Mech RP Instruction Combination by Farseer Eldar, on Flickr
On the back cover all LoM line in boxes is depicted:
49167477407_a629ddd991_c.jpgRecon Mech RP Instruction LoM Ad by Farseer Eldar, on Flickr
Minifigure
This set contains only one minifigure, and this is Antares the Martian:
49167243991_e0f600bace_b.jpgAntares the Martian by Farseer Eldar, on Flickr
As the others of his kind, he is named after a star. Antares is a healer. He also likes to invent and created the Aero Tube Hangar. His favorite food is vegetable cubes (I don't know which vegetables do they have on Mars, but still).
Antares has large, clever and slightly tired eyes. He wears some kind of cap on his head.
This figure is unique for this set.
Model
The Recon-Mech RP looks cute and has pleasant colors:
49167243986_c43a207b44_b.jpgRecon Mech RP by Farseer Eldar, on Flickr
Why do not LEGO produce sand red parts now?
The mech with its little brother from Aero Tube Hangar:
49166765488_8e02c12deb_b.jpgRecon Mech RP with Aero Tube Hangar Mech by Farseer Eldar, on Flickr
The pilot sits in the cockpit with transparent windscreen:
49166765273_d62e618ce8_b.jpgRecon Mech RP Cockpit by Farseer Eldar, on Flickr
The windscreen can be lifted off:
49167243971_a4458a83fd_b.jpgRecon Mech RP Cockpit Windscreen Open by Farseer Eldar, on Flickr
Antares holds the handles on the control panel:
49166765758_200da7a4c9_b.jpgAntares Acrobatics by Farseer Eldar, on Flickr
Although it is rather difficult to seat him properly, this is the best way to fix a Martian (or battle droid) minifigure in the cockpit.
The left and right flashlights are a bit different:
49167243896_2d27e75527_b.jpgRecon Mech RP Pilot by Farseer Eldar, on Flickr
It should also be noted that the Mech's arms have the same symbol as on the red/pink Hangar bay.
The cockpit without the pilot:
49167243931_6defc79bdf_b.jpgRecon Mech RP Cockpit Without Antares by Farseer Eldar, on Flickr
The arms are very flexible. The tubes are fixed well and do not constrain the movement.
The right arm wields a burner for ore extraction from meteorites. It can also be used as a flamethrower:
49167243456_c339165648_b.jpgRecon Mech RP Burner by Farseer Eldar, on Flickr
Here a rather unpleasant construction defect can be seen: the red pipe is not fixed properly and freely moves on the dark gray axle, and the burner jet is not connected firmly and can fall off easily:
49167243866_43a02ecea5_b.jpgRecon Mech RP Burner by Farseer Eldar, on Flickr
The left hand is equipped with a claw for meteorite gathering:
49167477287_0d30c3cb6c_b.jpgRecon Mech RP Claw by Farseer Eldar, on Flickr
Meteorites are very important for Martian civilization, since they contain energy-rich biodium ore.
The claw is as iconic Life on Mars part as transparent futuristic cockpits. Two parts of it are pulled together by a rubber band:
49167243836_a31e5b69b3_b.jpgRecon Mech RP Claw by Farseer Eldar, on Flickr
Its shape is perfectly suited for meteorites (the meteorite not included and taken from 7317):
49167477222_2b4fc74615_b.jpgRecon Mech RP Claw with Meteorite by Farseer Eldar, on Flickr
The legs are movable too, though they do not bend in knees:
49167477207_c33b61c287_b.jpgRecon Mech RP Legs by Farseer Eldar, on Flickr
Two holes are designed to connect the mech to the Hangar bay. The feet have prints, not stickers.
An interesting design - the hips have ladders for the pilot to climb:
49167477172_a527e29e17_b.jpgRecon Mech RP Leg Joints by Farseer Eldar, on Flickr
Behind the cockpit there is something like a fuel tank with signal lights (again, its roof is a print):
49167243721_ab285d24e9_b.jpgRecon Mech RP Back by Farseer Eldar, on Flickr
The mech body can rotate in any direction:
49166765218_9b77a28491_b.jpgRecon Mech RP Turning Body by Farseer Eldar, on Flickr
Despite the legs being flexible, it is hard to pose the mech without falling down. However, the next photo illustrates its capabilities.
OP, OP, OP! OPPAN GANGNAM STYLE!!!
49166765563_dd18171c59_b.jpgRecon Mech RP GANGNAM STYLE by Farseer Eldar, on Flickr
Now let's talk about transformation. The mech can be disassembled into these huge parts:
49167477097_2b89156c5a_b.jpgRecon Mech RP Disassembled by Farseer Eldar, on Flickr
Combining these blocks a bit differently, you can get this weird flying machine:
49167243676_a9e255eb56_b.jpgRecon Mech RP Flying Mode by Farseer Eldar, on Flickr
To be honest, I'm a bit disappointed, because this is not proper transformation like in 2005 Alpha Team sets and requires some reassembly.
There are no extra parts, except for some additional rubber bands and a black Technic part of unknown purpose:
49167243611_7efa2b4afd_b.jpgRecon Mech RP Extra Parts by Farseer Eldar, on Flickr
Pros/Cons
Pros:
+ Style and color scheme
+ High mobility
+ Interesting and non-standard parts
+ NO STICKERS!
Cons:
- Burner construction
- Legs do not bend in knees and are hard to pose
- Transformation requires disassembly and rearrangement of parts
- No meteorites
Bonus
- General, I have found the meteorite.
49167243596_43bf8cec6f_b.jpgRecon Mech RP and Meteorite by Farseer Eldar, on Flickr
Antares tries to grab it with the claw, but suddenly...
- CAW!!!
49166765373_fb39139f17_b.jpgSomeone Steals the Meteorite by Farseer Eldar, on Flickr
- Oh no! I thought it has CHI energy, not biodium!
49167243341_49bf228924_b.jpgCAW! by Farseer Eldar, on Flickr
(It is ironic that the set with Razcal was new when I filmed this set. Now it is a rarity too - not so rare as Life on Mars, but still.)
Thank you for reading and watching! And what can you say about this set?
Edited by Farseer Petriel
Thank you for this review!
I can feel the old school of this set and that's great! I love the colours of it (especially and red (or pink) like Gilderoy Lockhart's clothes)
Looking forward to reading new Life on Mars from you =D
ShishOK, thank you very much for your comment!
I like the old school feel of this set and sand red color too.
And I hope that my reviews will be made soon!
