LegoJalex Posted December 11, 2019 Posted December 11, 2019 (edited) I´m going to make instructions of a simple MOC I made in LDD, and for one part of the MOC I need a 1x2 tile to slide along a "1x1 brick with stud on one side" like in the second image below. But in LDD and Studio it seems to only be possible to place the tile in three positions on the stud which means I can´t place it the way I need to. So I wonder if anyone has a solution for this? Is it possible to set the exact coordinates manually for the tile in some way? (I should add that I´m fairly new to Studio so perhaps I have missed how I can do it there) Edited December 11, 2019 by LegoJalex Quote
samlr Posted December 11, 2019 Posted December 11, 2019 You can do it by tricking LDD : Step 2 : add the tiles Step 3 : remove the modified brick and one tile Step 4 : add modified brick Step 5 : copy/paste tile and modified brick Step 6 : replace 1x1 modified brick by 1x2 modified brick Quote
LegoJalex Posted December 11, 2019 Author Posted December 11, 2019 Just now, samlr said: You can do it by tricking LDD : Step 2 : add the tiles Step 3 : remove the modified brick and one tile Step 4 : add modified brick Step 5 : copy/paste tile and modified brick Step 6 : replace 1x1 modified brick by 1x2 modified brick Ah yes that works. Thanks a lot! Quote
Vincent Kessels Posted December 12, 2019 Posted December 12, 2019 In stud.io you can switch off snapping and move bricks with the keyboard. See the preferences for the keyboard mapping. Quote
