Gimmick Posted January 31, 2020 Posted January 31, 2020 3 hours ago, Bartybum said: So I've been investigating the suspension of the real A60H, and it turns out the rear axles don't seem to be sprung, but pendular, which I find surprising. I can't find any information about the front axle, but I feel it would make sense for the real thing to have it sprung. Front axle has hydraulic suspension, rear axle: 0:14 Quote
Bartybum Posted January 31, 2020 Posted January 31, 2020 @Gimmick yeah I figured the front would also be suspended Quote
andythenorth Posted January 31, 2020 Posted January 31, 2020 10 hours ago, Maaboo35 said: It's pretty consistent with what's on the box. I tend to agree, I just find it weird as there's no rationale for producing something so ugly. The simpler explanation really would be assembly error, rather than assuming a bad design no? Or is this just now standard AFOL opinion on Lego? Pretty much everything Lego produce is now hated here. Anyway, the 42030 B model had a much more sophisticated cab shape, with the correct backwards-sloping rake to the windshield. Quote
suffocation Posted January 31, 2020 Posted January 31, 2020 Looks a jolly sight better than anything I could ever come up with. Quote
Bartybum Posted January 31, 2020 Posted January 31, 2020 Just now, suffocation said: Looks a jolly sight better than anything I could ever come up with. Same. I've been saying it and I'll say it again, aside from the weird proportions, the designer's done a fantastic job creating a model with clean aesthetics Quote
TeamThrifty Posted January 31, 2020 Posted January 31, 2020 7 hours ago, Bartybum said: So I've been investigating the suspension of the real A60H, and it turns out the rear axles don't seem to be sprung, but pendular, which I find surprising. Theres a youtube video dedicated to the suspension, i posted it previously and someone else has also posted it since.. if you've not seen it, its worth a watch. There's some additional links between the back axles. Really hope they're replicated it.. Quote
Bartybum Posted January 31, 2020 Posted January 31, 2020 14 minutes ago, TeamThrifty said: Theres a youtube video dedicated to the suspension, i posted it previously and someone else has also posted it since.. if you've not seen it, its worth a watch. There's some additional links between the back axles. Really hope they're replicated it.. I can't find the video you linked. Could you link it again? Quote
Bartybum Posted January 31, 2020 Posted January 31, 2020 Ah yes, I remember that. I do hope they include the panhard rods, that'd be really nice. I really doubt we'll see sprung/hydro suspension since the A60H doesn't have it Quote
Zerobricks Posted January 31, 2020 Posted January 31, 2020 1 hour ago, TeamThrifty said: Reminds me of Unimog suspension a bit. Could be a good way to reintroduce the ball joints. Quote
1gor Posted January 31, 2020 Posted January 31, 2020 4 minutes ago, Zerobricks said: Reminds me of Unimog suspension a bit. Could be a good way to reintroduce the ball joints. Yes, that will be best and simplest solution for such vehicle, at lest for front axle Quote
andythenorth Posted January 31, 2020 Posted January 31, 2020 (edited) 3 hours ago, Bartybum said: I've been saying it and I'll say it again, aside from the weird proportions, the designer's done a fantastic job creating a model with clean aesthetics The rest of it looks rad to me. Just the windscreen rake is so weirdly wrong. Anyway, it's not causing the sky to fall imho, Lego is changeable. Just weird. Unrelated, did I miss the introduction of a new stronger universal joint somewhere? Or is there a stronger CV now? There'll be at least one carrying drivetrain through the center articulation joint. Standard universal won't last long, even if the hub reduction is high. Edited January 31, 2020 by andythenorth Quote
suffocation Posted January 31, 2020 Posted January 31, 2020 41 minutes ago, andythenorth said: Unrelated, did I miss the introduction of a new stronger universal joint somewhere? Or is there a stronger CV now? 42099 came with a new CV joint that handles higher torque and tighter angles. Quote
Rudivdk Posted January 31, 2020 Posted January 31, 2020 4 hours ago, Bartybum said: I've been saying it and I'll say it again, aside from the weird proportions, the designer's done a fantastic job creating a model with clean aesthetics I think the shape (height) of the cab is mostly defined by what appears to be the smart hub inside. So a delibarate design choice in favor of playability IMHO. Quote
Ngoc Nguyen Posted January 31, 2020 Author Posted January 31, 2020 Just now, kamsohal said: I found this on youtube. That's just the same picture slowly zoomed in and frozen for 2 minutes. Nothing new people. You may want to delete it as it mislead people into thinking there is sth worth watching in there.... Quote
1gor Posted January 31, 2020 Posted January 31, 2020 But it looks (on my mobile phone) that tires are smaller than Unimog tires or mudguards are a bit bigger than ones from Land Rover defender? Quote
1gor Posted January 31, 2020 Posted January 31, 2020 On laptop it looks like Unimog tire, so ignore my previous post Quote
Timorzelorzworz Posted January 31, 2020 Posted January 31, 2020 It's the fourth flagship with those tires, but the first one that uses six of them Quote
1gor Posted January 31, 2020 Posted January 31, 2020 1 minute ago, Timorzelorzworz said: It's the fourth flagship with those tires, but the first one that uses six of them You just read my mind Quote
msk6003 Posted January 31, 2020 Posted January 31, 2020 2 hours ago, Timorzelorzworz said: It's the fourth flagship with those tires, but the first one that uses six of them And also first model in technic(maybe?) use large sprocket but don't include any track piece. Quote
mpj Posted January 31, 2020 Posted January 31, 2020 Rims should be black with inner yellow sprockets, so the look could be improved (in real model the rims are much smaller compared to the tyre size) Quote
KLF Posted February 3, 2020 Posted February 3, 2020 On 1/29/2020 at 7:48 AM, Jundis said: If we get a B-model, we may get the Dumb Truck: Exactly! I also hope for R100E as the B-model. I guess there are all components for this model except of so many orange handles. Quote
Timorzelorzworz Posted February 3, 2020 Posted February 3, 2020 'cause it is Control+, there is no B-model for this set. We are lucky if 42112 and 42113 has one... Quote
jorgeopesi Posted February 3, 2020 Posted February 3, 2020 Just now, Timorzelorzworz said: 'cause it is Control+, there is no B-model for this set. We are lucky if 42112 and 42113 has one... It will be B-model when we konw the inventory because somebody will do it, with so many pieces I think it would be easy and more than one version. Quote
