DBG and Orange.
129.99 EUR.
The four functions are switched manually.
Special features and new parts:
- New rotor blades
- New panels 3x13 left and right that suit perfectly Panel Curved 3x13 (18944)
- Control+ battery box
- 1 motor
Functions
- Driven rotors
- Tlting the rotors
- Retractable undercarriage
- Open and close chopping flap
Go nuts
Edited by Ngoc Nguyen
  • Replies 781
An V-22? That one is a military-only aircraft. Even if the designers remove all references to military service, it's still a first for TLG to release a set of a current military vehicle. Also, this is a possible paint scheme in black and orange (minus the Marines inscriptions, of course):
Spoiler
Also, could it be an AW609? It's a civillian aircraft similar to the V-22, and was partly developed by Bell (Although Bell is no longer involved). It's reasonable to mistake the two, although I don't think that they would market it as a Bell.
Spoiler
Finally, a Bell license opens the door for other Textron Aviation licenses, such as Cessna, Hawker and Beechcraft.
Edited by Kaanere
Not quite - remember the Blue Power Jet (Creator 3-in-1, 31309, 2015) and the Air Race Jet (Technic, 2017).  This Bell-licensed tiltrotor will probably resemble the V-22 about as closely as those two sets resembled the F-35.
6 minutes ago, Kaanere said:
A Bell license opens the door for other Textron Aviation licenses, such as Cessna, Hawker and Beechcraft.
A licensed Cessna product would be a dream come true.
Similar but without military marks/symbols
They really clearly reassembled the Osprey
Edited by jrx
I have forgotten to measure :ugh: I think they are half lenght of the blades used in the Technic helicopters
2 minutes ago, Jeroen Ottens said:
What are these new panels you mention that fit to the 3x13 curved panels?
And I assume they come in DBG?
I’ll post a sketch later today. And yes dbg
15 minutes ago, Akbalder said:
How big is it?
Is it realy a control+ set or is it used as the old motors?
it's control+
PF is history.
<quote>
Control+ battery box and 1 motor
</quote>
The mentioned functions need 4 motors.
Or 5 if the rotors have a motor each
Edited by JaBaCaDaBra
40 minutes ago, Akbalder said:
How big is it?
It’s long but diameter is smaller than former transport plane - if I remember it right
It is C+ or PoweredUp - but I think only one motor
31 minutes ago, JaBaCaDaBra said:
it's control+
PF is history.
<quote>
</quote>
Only one motor as far as I was able to spot. Different functions are managed by gear box.
21 minutes ago, kbalage said:
@jrx did you manage to check the hub used? The Technic hub seems to be a total overkill for 1 motor, is it the AAA hub or a "dumb" PU battery box maybe?
It was nit possible ti check as the plane was glued to the ground and had glued bricks
With four gearbox-controlled functions, it looks like this will be the most interesting set of the wave (or even of the year) from a mechanical standpoint.
I did a very ugly sketch. Hope you can guess what I meant – I think I'm better with building than with drawing :D
(btw: why do I can't upload a small picture like this to EB???)
37 minutes ago, Flecktyphus said:
This set sounds very interesting, I'd love an approximation of its dimensions..
Hard to guess. There wasn't enough time to count the exact dimensions. Very rough guess: 40 to 50 cm long, around 50 cm wide and 10 to 15 cm height.
So they are like the 3x13 curved panel but taper to one side?
That doesn't sound logic,
the idea of control+ is remote control by smartphone
or will it be something like 8043 with gearbox control by motor?
