Posted March 11, 20205 yr Hello everyone, I was looking over the forum whether same question has been already posted somewhere, but couldn't find it, so I hope I am not doubling the topic: Q1: Is there a possibility to extend or shorten the technic linear actuators (92693c01, 61927c01 and 40918c01) in stud.io? Are there at least parts made of those in shortest and longest state and where can they be found? Q2: Is there a tool or a trick to align two i.e. liftarms, each with its own fixed pivot point to a position where those two cross (like two circles crossing each other) - is it possible to find that exact crossing in stud.io? I am putting most of my hopes into @efferman, @Zerobricks and @M_longer as I've seen quite a lot of great digital stuff coming from them. I would really appreciate any help from any other who might know something about it as well. I thank you in advance, Best regards, Miha Edited March 13, 20204 yr by MajklSpajkl
March 12, 20205 yr For the actuators: just “breaking” them in their components/subparts should allow any position in Studio. For the angles: you need a pencil, a sheet of paper, a rule and a compass, or a geometry software.
March 12, 20205 yr Author I thank you both for your suggestions. I never liked LDD too much, but I guess I'll have to deal with it :-) Best regards.
March 13, 20204 yr On 3/12/2020 at 12:24 AM, MajklSpajkl said: as I've seen quite a lot of great digital stuff coming from them I am using LDraw to make pump/actuator/shock absorber. To create specific part from subparts and import it into Stud.io. Here's the example filehttps://bricksafe.com/files/M_longer/misc/pumps/6Lpumps.io Edited March 13, 20204 yr by M_longer
March 13, 20204 yr Author 1 hour ago, M_longer said: Here's the example file Thx, I'll try out that as well and see which method I find easiest and quickest. Best regards.
March 13, 20204 yr Author Using MLCad as @M_longer suggested + some geometry in AutoCAD to get the correct angles in Studio worked like a charm. I hope Studio gets updated in the future to make these extensions and alignments even easier. Thank you all for suggestions and best regards. Miha
March 13, 20204 yr 2 hours ago, MajklSpajkl said: Using MLCad as @M_longer suggested + some geometry in AutoCAD to get the correct angles in Studio worked like a charm. I hope Studio gets updated in the future to make these extensions and alignments even easier. You could do it in one go in my LDCad editor (ldraw). See the "Shock absorbers" section of: http://www.melkert.net/LDCad/docs/advEdit
