dr_spock Posted May 8, 2017 Posted May 8, 2017 You can also hack your own train controllers and receivers fairly cheaply such as using a $3 Arduino board. You can program it to send PF IR commands to the PF IR receiver in the train engine. You can add sensors to detect the train location, LED lights for signals, motorized crossing gates, etc. Quote
Trekkie99 Posted May 9, 2017 Posted May 9, 2017 9 hours ago, DEAD1974 said: OK you convinced me PF is the choice, my only issue with it is the plastic look of tracks...but as I have seen on videos LEGO train builder use the 9V style trucks with PF trains. So probably I will try to make that mix too. Keep in mind that most 9V track comes in old dark grey, with some being made in dark bley before Lego discontinued 9V. But of course, 9V and pf track are compatible with each other. Quote
Boettner Builds Posted May 9, 2017 Posted May 9, 2017 I have a question for anyone who has built a "B" unit for their trains. Did you power the "B" unit or does it just roll behind your engine? Thanks! Quote
Capparezza Posted May 9, 2017 Posted May 9, 2017 Hm, the PF train motor is still out of stock, been checking it now for a couple of weeks: https://shop.lego.com/de-AT/LEGO-Power-Functions-Zugmotor-88002. I suppose it is out of stock for all countries, can I order it through LEGO elsewhere? Quote
justinwebb Posted May 9, 2017 Posted May 9, 2017 Its been in stock in the US for almost a month, i ordered 5 a few weeks ago and it still shows in stock Quote
Capparezza Posted May 9, 2017 Posted May 9, 2017 Interesting. What the hell is going on here??? I can order from Austria or Germany, and it is unavailable in both countries... Quote
davidzq Posted May 9, 2017 Posted May 9, 2017 7 hours ago, Boettner Builds said: I have a question for anyone who has built a "B" unit for their trains. Did you power the "B" unit or does it just roll behind your engine? Thanks! It depends on the train and how well it runs. If you have a long train, you'll most likely need some extra pulling power, and if two motors in the A unit isn't enough, the B can hold two more. I even have a powered NPCU on my cascades, as the train is very heavy. Keep inmind that if you are using the 9v system, a single stock speed regulator can only handle two or three motors. But power functions is pretty much limitless, with more batteries and receivers. Quote
DEAD1974 Posted May 10, 2017 Posted May 10, 2017 On 08/05/2017 at 9:19 PM, Daedalus304 said: Oh right, I knew I was forgetting something. I've added a couple links and short write-ups in my last post just to keep the 3rd party stuff all together. Now that I've gone through all of this stuff it's actually amazing just how many 3rd party options there are now for us train guys. What a time to come into the hobby! Lucky you, I am form EU so it will be a bit harder to get those toys... Quote
Boettner Builds Posted May 11, 2017 Posted May 11, 2017 On 5/9/2017 at 7:41 AM, davidzq said: It depends on the train and how well it runs. If you have a long train, you'll most likely need some extra pulling power, and if two motors in the A unit isn't enough, the B can hold two more. I even have a powered NPCU on my cascades, as the train is very heavy. Keep inmind that if you are using the 9v system, a single stock speed regulator can only handle two or three motors. But power functions is pretty much limitless, with more batteries and receivers. Thanks for the reply! I'm working with power functions so that's good to know! I think I'll leave the "B" unit powerless until the need arises. Quote
legoboy3998 Posted May 15, 2017 Posted May 15, 2017 I am looking for a source for "flex tube". I know some builders have mentioned finding non LEGO sources, but can't find any reference to where now. Any help would be appreciated. Thanks, Sal WFB, WI Quote
davidzq Posted May 15, 2017 Posted May 15, 2017 Just now, legoboy3998 said: I am looking for a source for "flex tube". I know some builders have mentioned finding non LEGO sources, but can't find any reference to where now. Any help would be appreciated. Thanks, Sal WFB, WI You can get it on Bricklink. "Flex tube" is what many AFOL's refer to it as, but it's BL name is Hose, Rigid 3mm D., and has it's own category in the parts catelog, organized by length. The Lego Group calls it "Outer Cable" for reference. Quote
Blast Posted June 26, 2017 Posted June 26, 2017 What is the lowest price I can realistically expect the Cargo set to drop to? Quote
Stefaneris Posted June 27, 2017 Posted June 27, 2017 I don't know where you live but here in Switzerland I would say 20-30%. That's because the big retailer here have a regular discount on toys during the summer and again in the winter. To get a bigger discount you would need some good luck and/or contacts. Maybe your local toy store puts 50% on items on clearance or has some other sales. You could ask someone who works there if there is a chance for such a discount. Quote
bradaz11 Posted June 28, 2017 Posted June 28, 2017 I'm still only just scratching the surface on the wealth of knowledge and posts on here, but I've searched a bit, and not found anything.... the main gripe I see for PF trains is the size of the battery box. Does no one make up their own 7.4v lipo packs? I would have thought that if you found the huge boxes to be a drawback, then wiring up a loose battery to a PF brick lead to power the IR and in turn the motor would have been a fairly standard practice, but I'm struggling to have seen anyone else mentioning this. have I just missed the post or is this deemed to be impure lego'ing, even though it is only a battery? or is it down to preference as the weight of the 6 aaa's can obviously aid traction on the train. Quote
Stash2Sixx Posted June 28, 2017 Posted June 28, 2017 We use the LEGO rechargeable battery boxes in our trains (NILTC) and they work well. They run for about 2 hours, then auto shut off. Turn 'em back on, and then get another 2 hours. It powers off, so then we run it for another 2 hours. Of course, it shuts off again and at this point we just turn it back on to drain the battery. Then we recharge them. So overall, if you take care of it, we get about 6 hours of runtime off one battery. Multiple motors and train length/weight play into that but we've found they work great. Otherwise, if you want to work your own battery solution...GO FOR IT! It's your LEGO, do what you want. Quote
davidzq Posted June 28, 2017 Posted June 28, 2017 2 hours ago, bradaz11 said: Does no one make up their own 7.4v lipo packs? I would have thought that if you found the huge boxes to be a drawback, then wiring up a loose battery to a PF brick lead to power the IR and in turn the motor would have been a fairly standard practice, but I'm struggling to have seen anyone else mentioning this. have I just missed the post or is this deemed to be impure lego'ing, even though it is only a battery? It has been done several times, by many builders. Most common I've seen is using standard AA or AAA batteries, but stacked end to end to create a long narrow battery pack, which better fits in narrow locomotives. I've also seen an example of a RC car battery used. Quote
bradaz11 Posted June 28, 2017 Posted June 28, 2017 Just now, davidzq said: It has been done several times, by many builders. Most common I've seen is using standard AA or AAA batteries, but stacked end to end to create a long narrow battery pack, which better fits in narrow locomotives. I've also seen an example of a RC car battery used. i was thinking something like this Specification: Length - 44mm Width - 26mm Depth - 10mm Weight - 25g Battery Capacity - 350mAh Discharge Rate - 40C Constant Chemistry - LiPo Power Pack Cells - 2S Voltage - 7.4v Watt Hours - 2.59Wh I've used similar little 2 cell lipo's in an airsoft gun mod, this pack should be about 4 plates deep, by 5 bricks long, by 3 bricks. obviously a lot smaller than 4 bricks deep, 8 bricks long and 4 bricks wide. if the lego soloution is 1100mah, and lasts 6 hours of running, i would think you should easily get 2 hrs out of the above lipo unless i've got something wrong and talking out my bottom Quote
Younge Posted June 28, 2017 Posted June 28, 2017 54 minutes ago, bradaz11 said: i was thinking something like this Specification: Length - 44mm Width - 26mm Depth - 10mm Weight - 25g Battery Capacity - 350mAh Discharge Rate - 40C Constant Chemistry - LiPo Power Pack Cells - 2S Voltage - 7.4v Watt Hours - 2.59Wh I've used similar little 2 cell lipo's in an airsoft gun mod, this pack should be about 4 plates deep, by 5 bricks long, by 3 bricks. obviously a lot smaller than 4 bricks deep, 8 bricks long and 4 bricks wide. if the lego soloution is 1100mah, and lasts 6 hours of running, i would think you should easily get 2 hrs out of the above lipo unless i've got something wrong and talking out my bottom If you come up with a working solution, it would be nice to see some kind of tutorial on how you did it. I think a lot of people would like to play with a non-Lego battery solution for narrow trains, but just don't know what they are doing (me included!) with electronics and gadgets. Quote
dr_spock Posted July 3, 2017 Posted July 3, 2017 On 6/27/2017 at 9:00 PM, bradaz11 said: I'm still only just scratching the surface on the wealth of knowledge and posts on here, but I've searched a bit, and not found anything.... the main gripe I see for PF trains is the size of the battery box. Does no one make up their own 7.4v lipo packs? I would have thought that if you found the huge boxes to be a drawback, then wiring up a loose battery to a PF brick lead to power the IR and in turn the motor would have been a fairly standard practice, but I'm struggling to have seen anyone else mentioning this. have I just missed the post or is this deemed to be impure lego'ing, even though it is only a battery? or is it down to preference as the weight of the 6 aaa's can obviously aid traction on the train. You can use 7.4V LiPo packs if you so desire. You can connect a drone alarm board in between to warn you when the voltage drops close to 3V so you can turn off the train and avoid damaging the batteries. 6 AAA's can provide weight for traction but you can also use LEGO boat weights. Recharging LiPo packs do need extra care and due dliigence than NiMH. LiPo packs maybe not be a good solution for everyone without a good home fire insurance policy. Quote
peterab Posted July 11, 2017 Posted July 11, 2017 On 28/06/2017 at 2:11 PM, bradaz11 said: i was thinking something like this Specification: Length - 44mm Width - 26mm Depth - 10mm Weight - 25g Battery Capacity - 350mAh Discharge Rate - 40C Constant Chemistry - LiPo Power Pack Cells - 2S Voltage - 7.4v Watt Hours - 2.59Wh I've used similar little 2 cell lipo's in an airsoft gun mod, this pack should be about 4 plates deep, by 5 bricks long, by 3 bricks. obviously a lot smaller than 4 bricks deep, 8 bricks long and 4 bricks wide. if the lego soloution is 1100mah, and lasts 6 hours of running, i would think you should easily get 2 hrs out of the above lipo unless i've got something wrong and talking out my bottom There are a bunch of reasons people don't use Lipos. Mine are as follows. 7.2 V means they limit the top speed of trains (not so bad for freight). Lipos need more care when charging. Their energy density isn't all that great when compared to the LEGO rechargeable battery. Yes they provide a smaller footprint but at the cost of a much smaller running time. I'd only really consider Lipo for a really small engine. I've often thought of making a custom battery pack from 8 AAA or AA rechargeable batteries in two groups of four. 9.6V is well within the tolerances of the PF receiver. Quote
DanToffel Posted November 19, 2017 Posted November 19, 2017 Hey guys, I have a question about the 88002 PF motor that I built into my winter train (10254). the motor is way to fast so that the train literally speeds through my winter village display. I want to change that but dont see why the only way to do that is to buy the IR receiver and IR remote control. so my Q is: how can I set the 88002 to the slowest setting as i would be able to with the remote? There has got to be a way without the remote right? thanks in advance!! Quote
ColletArrow Posted November 19, 2017 Posted November 19, 2017 Unfortunately, there isn't that I'm aware of. Only 2 PF parts exist that can reduced the speed; the 'IR Speed Remote Control' 8879 (connected via the receiver 8884) or the 'Rechargeable Battery Box' 8878 (it has a dial on it for some reason). As the latter costs ~£40, whilst the former is only ~£20 AND lets you control the train at a distance, well. Quote
peterab Posted November 20, 2017 Posted November 20, 2017 All the official LEGO PF batteries provide 9V which is essentially full speed for the motor. If you don't want remote control as provided by the PF receiver and remote but still want a slower speed, one solution is to provide a lower voltage. Instead of using a 9V battery you could modify a 4x AA battery holder to provide 6V to the motor. Quote
baard Posted November 20, 2017 Posted November 20, 2017 On 28.06.2017 at 6:11 AM, bradaz11 said: i was thinking something like this Specification: Length - 44mm Width - 26mm Depth - 10mm Weight - 25g Battery Capacity - 350mAh Discharge Rate - 40C Constant Chemistry - LiPo Power Pack Cells - 2S Voltage - 7.4v Watt Hours - 2.59Wh I've used similar little 2 cell lipo's in an airsoft gun mod, this pack should be about 4 plates deep, by 5 bricks long, by 3 bricks. obviously a lot smaller than 4 bricks deep, 8 bricks long and 4 bricks wide. if the lego soloution is 1100mah, and lasts 6 hours of running, i would think you should easily get 2 hrs out of the above lipo unless i've got something wrong and talking out my bottom If you want to save space and want to go for a non-Lego solution, try the Buwizz box. Battery and remote control in one box, smaller than the Lego battery pack, rechargeable and can be totally hidden into your model as it is blue tooth controlled by your smart phone. Mine ran for 4-5 hours at a show, powering 2 PF Train motors (sometimes adding light (4 PF outputs on top of the box)), hauling 18 brick dense tanker cars before I had to recharge the battery. Quote
Duq Posted November 23, 2017 Posted November 23, 2017 On 11/19/2017 at 10:35 PM, DanToffel said: Hey guys, I have a question about the 88002 PF motor that I built into my winter train (10254). the motor is way to fast so that the train literally speeds through my winter village display. I want to change that but dont see why the only way to do that is to buy the IR receiver and IR remote control. so my Q is: how can I set the 88002 to the slowest setting as i would be able to with the remote? There has got to be a way without the remote right? thanks in advance!! The alternative is buying the rechargeable battery 8878 because it has a speed control built in. It's not cheaper than receiver + remote but it'll save you batteries and it's easy to run. Quote
