In this video, i would like to show you the details between the setting which you found in Bricklink Studio 2.0 animation renderer section. I will covered most of the commonly use settings (for animation), and do a side by side comparison of those settings. Wish this video will help you to clear up some confusion between the setting differences which you found under the animation renderer. Hence, you may able to directly choose and use the setting that fit you the most. Hope you found this video is useful!
