mark6399 Posted May 9, 2020 Posted May 9, 2020 Hi all, I've recently come out of my dark ages and decided to get back into Lego trains! One thing I've always found fascinating is mountain railroading. I remember looking for the old railroad grades in the mountains on family trips to Colorado, and I enjoy reading about how they were constructed through the mountains. (The Denver, Northwestern & Pacific's standard gauge line over Rollins Pass is pretty incredible). This project takes inspiration from a Denver and Rio Grande Western Line between Buena Vista and Leadville, CO as well as the Yosemite Valley railroad in California. I'm planning on creating five sections for this. The railroad will pass over the river at some point (still playing with a couple ideas!). It won't be a full loop, but I enjoy making dioramas. With the space I have available, I can add a lot more detail to a diorama display. Two questions for you guys: 1) Getting the slopes to line up is pretty tricky. What's really tough is making the supports line up to brace the upper mountainside. Has anyone made any references for these kinds of things? I was thinking of making some basic models to really figure out how to line things up. I was hoping to avoid going into calculating LDU's and such, but with all the angles, it might be necessary. 2) Has anyone made wide radius curve L-draw files (R56, R72, R88)? I searched the forum and found links for the ME-models library and R104 Bricktracks on Lgauge.org, but I found the ME models ones to be kinda finicky. Let me know what you think! I played with a couple different methods for detailing and attaching the trees and grass, etc so I'm open to feedback and to other ideas as well! I plan on updating this thread as I finish the other modules. Thanks! River_Canyon1_3 by Mark, on Flickr River_Canyon1_2 by Mark, on Flickr River_Canyon1_1 by Mark, on Flickr River_Canyon1_5 by Mark, on Flickr Quote
Pdaitabird Posted May 9, 2020 Posted May 9, 2020 Great progress so far! I would recommend looking into MILS modules...it seems to be a good way to standardize sections of terrain. Here's a link: http://l-gauge.org/wiki/index.php/Modular_Standards It would also be useful if you ever wanted to integrate your modules into a group layout. I look forward to seeing your progress! Quote
mark6399 Posted May 10, 2020 Author Posted May 10, 2020 Thanks! That's a great resource. I'll take a look at modifying the base. Quote
Coal Fired Bricks Posted May 10, 2020 Posted May 10, 2020 (edited) Looks Good. May be a bit pricy- bricks wise. To lower cost I would take the grey end caps off and only use them on a corner or when needed. Also as a suggestion you could put transparent tiles over the water to get a more shiny/water effect. -Coal Fired Edited May 10, 2020 by Coal Fired Bricks Quote
mark6399 Posted May 11, 2020 Author Posted May 11, 2020 Thanks! Yeah, the dark grey bricks on the ends were added mostly just for aesthetics for rendering the pictures. I'd go through and try to cut down on total brick-age before building it in real life. The transparent tiles do give water a good look. I wanted to see what it looked like without them in this build because the amount needed for this project would be pricey. Hopefully I can find them on a PaB wall when the stores open up. I'm lucky enough to have 3 within an hour radius of me so fingers crossed. Quote
SteamSewnEmpire Posted May 11, 2020 Posted May 11, 2020 It's cool, but that is an enormous number of bricks for such a small section of track. Quote
baard Posted May 11, 2020 Posted May 11, 2020 I like it. The trees are small, but that may be the intention. As you have already found out, mountains require tons of bricks. Adding a rail road to it increases rather than diminish the need for bricks. I am speaking from experience, as one of my childhood dreams was to build a mountain of Lego. I completed one a few years back (see below), and to be honest, much of the understructure had to be made from wood supports, special shelves as well as a couple of tables. However, the croud loves such displays at shows, the headache begins only in transporting it to and from the event as well as the tedious setup. Good luck on your module development. Let us see the finished product Quote
zephyr1934 Posted May 11, 2020 Posted May 11, 2020 On 5/9/2020 at 1:46 PM, mark6399 said: It won't be a full loop, but I enjoy making dioramas. With the space I have available, I can add a lot more detail to a diorama display. That looks REALLY nice. And one thing to think about would be making an open-loop layout, with a bit of switching on either end of the line so you could still operate and play with it. On 5/9/2020 at 1:46 PM, mark6399 said: 1) Getting the slopes to line up is pretty tricky. What's really tough is making the supports line up to brace the upper mountainside. Has anyone made any references for these kinds of things? I was thinking of making some basic models to really figure out how to line things up. I was hoping to avoid going into calculating LDU's and such, but with all the angles, it might be necessary. You already answered your own question in terms of making it work. Using the slanted plates not only makes it more interesting to look at than a pure slope build, it also saves on part count. As others have said, using non-lego behind the scenes would save you a lot of money. You could use duplo or quatro, but they don't have good clutch. 11 hours ago, mark6399 said: Thanks! Yeah, the dark grey bricks on the ends were added mostly just for aesthetics for rendering the pictures. I'd go through and try to cut down on total brick-age before building it in real life. The transparent tiles do give water a good look. I wanted to see what it looked like without them in this build because the amount needed for this project would be pricey. Hopefully I can find them on a PaB wall when the stores open up. I'm lucky enough to have 3 within an hour radius of me so fingers crossed. Ha ha, if you want to save money don't attempt the hills. If this is a multi-year project you could also join your local LUG (if you have 3 lego stores within an hour's drive you probably have at least one LUG in that same radius) and aim for next year's LUGBULK. In this program Lego gives a deep discount to the LUG on up to ~80 different parts. If you need a few thousand of something it is hard to beat LUGBULK. Unfotunately LUGBULK comes but once a year, with the cycle starting in December and delivery roughly the following summer. So if you want this built before next summer LUGBULK is not an option for you. Quote
Coal Fired Bricks Posted May 11, 2020 Posted May 11, 2020 (edited) On 5/9/2020 at 1:46 PM, mark6399 said: It won't be a full loop, but I enjoy making dioramas. With the space I have available, I can add a lot more detail to a diorama display. You could put a loop in that is 1/2 scenic by having the track go into tunnels then behind the diorama then to the front again. On 5/9/2020 at 1:46 PM, mark6399 said: Yosemite Valley railroad in California This may be some inspiration. It is a model of the railroad town for town, building for building. 1 hour ago, zephyr1934 said: You already answered your own question in terms of making it work. Using the slanted plates not only makes it more interesting to look at than a pure slope build, it also saves on part count. As others have said, using non-lego behind the scenes would save you a lot of money. You could use duplo or quatro, but they don't have good clutch. Same, it looks great the way it is. On 5/9/2020 at 1:46 PM, mark6399 said: Has anyone made wide radius curve L-draw files (R56, R72, R88)? I searched the forum and found links for the ME-models library and R104 Bricktracks on Lgauge.org, but I found the ME models ones to be kinda finicky. For track planning, you could use BlueBrick but it is only for PC. . -Coal Fired Edited May 11, 2020 by Coal Fired Bricks Quote
mark6399 Posted May 12, 2020 Author Posted May 12, 2020 (edited) @SteamSewnEmpire Haha, yeah, its a bunch. ~2000 for that section. That's including the Dark bley 2x4 end caps. It's a lot, but fairly reasonable, I think, for what it is. I'm not sure if I'll ever make it ABS, but I'm keeping in mind how I would cut down on bricks if I ever do. @baard Thanks! Yeah, I saw the tree technique somewhere on Flickr, I think. I liked that it was light on parts and decided to try it out initially. Thanks for the tips on the wood structure. That's a great idea. That mountain is incredible by the way! I've had it faved on Flickr for inspiration, haha. @zephyr1934 Thank you! Thanks for the suggestions. I'll have to play with the switch idea. I've been able to do pretty well with the PaB wall in the past, but I doubt I've done anywhere close to the value you can get through LUGBULK! I'll have to look into local groups. @Coal Fired Bricks Thanks for the link! That's an impressive layout. Haha, Bluebrick is great! I found the TrixBrix files for that software, but haven't come across any R72 files for Studio 2.0. @Brandon Pea Thanks! Edited May 12, 2020 by mark6399 Quote
Coal Fired Bricks Posted May 12, 2020 Posted May 12, 2020 11 hours ago, mark6399 said: Haha, yeah, its a bunch. ~2000 for that section. That's including the Dark bley 2x4 end caps. It's a lot, but fairly reasonable, I think, for what it is. I'm not sure if I'll ever make it ABS, but I'm keeping in mind how I would cut down on bricks if I ever do. You could put a base plate that is cut down on the sloped section, that could cut down on some of the bricks on the sloped section and a need for fewer supports. Also if you go on BL and find the cheapest part that you want is in the wrong color there is always a can of spray paint at Home Depot ready for some recoloring. Bye Bye Everybody, Coal Fired Quote
Roadmonkeytj Posted May 12, 2020 Posted May 12, 2020 I might of missed it but you can create alot if under structure with duplo ... A quick Google search will show you how to connect them to system bricks. This can save you alot of weight and brick under the mountain ... If your like me and buy friends sets for the parts there is alot of pink and purple to be used under a mountain. Quote
Pdaitabird Posted May 21, 2020 Posted May 21, 2020 On May 9, 2020 at 1:46 PM, mark6399 said: I played with a couple different methods for detailing and attaching the trees and grass, etc so I'm open to feedback and to other ideas as well! I meant to take these pictures when I first read that, but just now got around to it! Hopefully this csn give you some inspiration for small conifer trees. Looking forward to seeing more of your awesome layout! Quote
mark6399 Posted May 21, 2020 Author Posted May 21, 2020 Thanks for the suggestion @Pdaitabird! That's a nice design, I'll have to try it out! I'm hoping to have the next section done in two weeks or so. It has been a lot trickier than I expected to make plates line up to make smooth hillsides and interesting gradients. Quote
mark6399 Posted June 25, 2020 Author Posted June 25, 2020 Update time! Sections 1 and 2 are now complete (4 more to go!). This second section had quite a few challenging areas. It took a while to figure out how to get things to line up building the ravine on the mountain side. That curved slope by the trestle bent was also pretty tricky. I'm really pleased with how the trestle bent turned out and am excited to build out more of the bridge. Thanks for the inspiration for the trees @Pdaitabird! I expanded the idea a little bit to add some bigger trees to the mountain. They attach kind of sloppily at the base, but I'll fix that in later updates. I'm really enjoying this build. Each module presents new challenges that are fun and rewarding to solve. River_Canyon2_7 by Mark, on Flickr River_Canyon2_6 by Mark, on Flickr River_Canyon2_3 by Mark, on Flickr River_Canyon2_0 by Mark, on Flickr River_Canyon2_5 by Mark, on Flickr Quote
Vilhelm22 Posted June 25, 2020 Posted June 25, 2020 Awesome! The six final modules together will look fantastic - I’m looking forward to it! Quote
Andy Glascott Posted June 25, 2020 Posted June 25, 2020 That’s looking really good, great progress. Looking forward to seeing more. Quote
zephyr1934 Posted June 29, 2020 Posted June 29, 2020 Great work, so is the track starting a curve here, and if so, is it just crossing the river or doing a 90° bend? Quote
mark6399 Posted June 30, 2020 Author Posted June 30, 2020 @zephyr1934 Thanks! It is going to do a 90 deg bend over the river. The river will curve 90 deg following the track just beyond the bridge. @Matt Dawson Thanks! Yeah, it's pretty tedious to build, but I like the realism and the challenge of getting the slopes to align correctly. Quote
