Fiat 125p
Specifications:
Length/width/height: 58s/23s/20s
Scale: 1:9,5
Weight: 2268 grams
Parts count: 3066
2x L motor
2x servo motor
1x sbrick
Power supply: 1x8881 BB/1x8878 BB/1xBuwizz
Features:
Driving - 2x L motor
Steering - servo motor
4-speed gearbox - I (1:2,08) II (1,67:1) III (1,25:1) IV (0,8:1)
Changing gears - servo motor
Front independent suspension
Rear floating suspensionWorking inline 4 cylinders engine
Working steering wheel
Adjustable front seats
Openable doors (front with lock)
Openable bonnet from inside
Openable trunk
Removable bodywork
Front and rear LED lights
I came up with the idea of building Fiat 125p at the beginning of this year. I started the build in the March, and after two months the model is ready.
For driving I used two L motors, which powers the fourspeed gearbox. I wanted to make it as low as possible to have enough space for interior. Apart from the gears it is 2 studs high, thanks to use the Chiron’s orange brick. The gears are changed using servo motor and a simple stepper. Gear shifting is reliable in 80% cases while driving and 100% while it's stoped. This is probably due to friction while driving. Most often second gear does not want to shift to third. This gears are on both sides of the gearbox, it probably results from that. I changed axles and lubricated the driving rings, but the effort was the same.
Gearbox ratio:
I 2,08:1
II 1,67:1
III 1,25:1
IV 0,8:1
The car drives quite smoothly. In the fourth gear it reaches 4 kph, while powering by buwizz in ludicrous mode.
For steering there is servo, which also moves the steering wheel.
What I chose as one of my goals was removable bodywork. It required a slighty different build of the chassis and completely different build of the bodywork. The most important was to route the wires correctly from the front of car (2x L motor, servo and lights) to the rear, where there is sbrick. It required using two extension wires 20cm and 50cm.
Time for manual functions. Fiat has got front doors with lock. It has similar construction as in my previous MOCs, it works thanks to a rubber. The front seats are adjustable in probably the easiest way. There are no any worms or gear racks, the adjustment works thanks to a lever, which moves the seat. It works similar to wishbones in suspension. On the passagner’s site there is a lever to open the bonnet. Unfortunately on the driver’s side there wasn’t enough space, due to the steering wheel and wires. Bonnet and trunk has got hinges to prevent it from falling down.
While building the bodywork the most important was to provide it with adequate rigidity, because it is another part. The roof gives the stiffness, which (first time in my MOC) performs the function of strengthening the body work, just like in a real car. Most of the work was with the body line. Looking from upside on Fiat, it is a bit rounded: narrows at the front and rear of the car, and widens in the middle. I solved it through not entirely legal connection: liftarm 15 at slight angle. The door frames also required a little bit of effort. I tried to use as few as possible this, because of it’s terrible price in red.
Curiosities:
1. The pistons are moving in the same order as in the real engine.
2. The air filter also bolts the body to the chassis. After turning it the lock in the front is released, and after removing axles in the middle and in the rear, you can remove the whole bodwork.
This is the first model to which I made instructions. It required some patience with stud.io and LDcad. They are available at rebickable:
https://rebrickable.com/mocs/MOC-42230/Porsche96/fiat-125p
Few sample pages:
Some additional photos
Fiat 125p is ready. Time to implement new ideas :)
5 minutes ago, MinusAndy said:
Fantastic! Is this the same as the polski fiat?
Yes, the polski fiat is Fiat 125p. There is also Fiat 125, which looks a little different (square front lights instead of round ones).
I really like how you’ve taken a very mundane vehicle and with really good technic functions and an eye for lines and detail, made this. I think it’s brilliant.
Beautiful model. I especially like the scale and the wheels you used. These wheels are almost the only larger LEGO wheels with near-correct proportions (tyre width vs height). Great to see they can very well be used for medium scale cars!
Very good replication. Once upon a time when I was a kid this was luxury car where I live...
Thanks for all the nice words ?
You are right, they are the only one for a normal, non-supercar vehicle. There are also 94.3x38, but they fit to a much larger scale.
Yes, but I even find those to be a little too wide for their height actually. The only other true option would be the super rare wheels of the Model Team Giant Truck 'Black Cat' (just slightly larger than the ones you used).
  • Rudivdk featured this topic
Amazing!
Have you noticed that it must have been designed originaly based on the american muscle cars from the 60-70s?
Love the "duży Fiat"
Thanks!
No, I haven't, but they are quite similar :D
Wow I love it, it is really as cute in lego than in real. The best is how the proportions perfectly fit the real model, nice job ! Maybe some blue pins on the body could be replaced by grey friction less pins for better color matching ?
Edited by alfredboyer
typo
Congratulation for this beautiful model! I would add some brown axles or pieces to get authentic corrosion spots :laugh:
Thanks!
That's a good idea.
Haha ? It is brand new, straight from the factory, just spent some time on the parking lot... ?
Awesome execution of 125p! I love this one :pir-love:
Great job, well done.
