It's yet an Alpha version, but it's very promising!
Edited by GianCann
Changed topic title, for a better tematics
  • Replies 105
Well also a good job! I will speak to my students next Tuesday, hope they will also learn something from it, I asked them to create something with Powered Up etc. but I don't know what their results are at this point. They also have two of those Control+ hubs so...
Looks really nice, I only miss Spike, WeDo 2.0 and the Duplo train for now but I guess that would be nice for future work. I would not mind to lend a hand in the summer vacation.
5 hours ago, Coder Shah said:
Have you tried the sensors as well?
Yes! It work well.
Remember, however, that this firmware is still on "alpha" stage.
On 6/6/2020 at 7:43 AM, GianCann said:
Yes! It work well.
Hi,
can I reset the firmware on the hub to use the original lego version again? I do not want to break the hub permanently:<
Edited by Gimmick
Yes, sure!
3 minutes ago, GianCann said:
Yes, sure!
Ok, do I need an extra tool for that, or does the PU-App recognize the wrong firmware and overwrites it?
Just now, GianCann said:
You have only to force "bootloader mode" (long press on the Power button) and the PU App re-flash with the LEGO firmware ;)
Ahh, ok nice. If the Hub does not recover, I will blame you of course =)
On 6/5/2020 at 10:54 PM, GianCann said:
I'm only alpha-tester ;)
Hi, what's your experiece how log it takes to get userid/pw for the platform?
On 6/9/2020 at 11:29 AM, Lok24 said:
Ah! I'm not :sadnew:
So I have to wait!
I found the mail in the spam folder ...
The sender was not pybricks, but an employee one of the two fan dudes.
Just fyi, if you are still waiting. ;)
Edited by Gimmick
The sender was not pybricks, but an employee.
I'm pretty sure that they don't have employees because it's not a company ;) Just a project of two fans
Mimimimimi.... fixed :p
Hi all,
just got the chance to test, and at a first sight:
- perfect description of how to start
- everything works as described
I spend perhaps 10 Minutes with
- Installing Crome 85 in Win10/64
- Copy the new firmware to the Powerd Up technic Hub
-  copy and paste the code-example into the browserbased development tool
- Connect hub
- Start program
- WORKS!
Indeed.
I'm just trying to show the battery.voltage(), but don't know what have to import, CPlusHub ?
And how to turn off the hub? (Except removing batteries.....)
Try this:
hub = CPlusHub()
if hub.battery.voltage() < 6500:
    hub.shutdown()
You can also power off the HUB holding the power button for a few seconds
