seaman Posted July 24, 2020 Posted July 24, 2020 (edited) DSRS "Nemo" People's Republic of Catland deep-sea research submarine "Nemo" A small submarine designed for deep sea research. Designed for the benefit of the National Institute of Hydrography, but may also be used by the Navy. Two multi-blade, low-noise propellers driven by electric motors provide the submarine with excellent maneuverability. The energy source is a small-sized nuclear reactor. Due to their small size, Nemo-class vehicles can be used on board warships such as the Galileo-class cruisers. They are also actively used for the construction and maintenance of Catland's underwater bases, for which they are equipped with powerful manipulators. In accordance with the requirements of the category specifications, the boat is equipped with a torpedo tube for small torpedoes, has three decks, an airlock for hydronauts or for rescuing submarine crews. On the external sling, the boat is capable of carrying a wide range of weapons - heavy torpedoes, mines, reconnaissance probes and seismic research charges. This build for LEGO wargame DA4. If you are interested, I would be grateful if you rate this work on Flickr: DA4 Submarine DSRS "Nemo" Edited July 26, 2020 by seaman Quote
