Ngoc Nguyen Posted July 29, 2020 Posted July 29, 2020 8 hours ago, Bartybum said: Any chance of a video showing how slow the modded setup now is? A bit slower than this. 10:24 Quote
lee1980 Posted July 29, 2020 Posted July 29, 2020 14 hours ago, Ngoc Nguyen said: The mod finally works!!!!! I combine this with this The blades spin much more slowly but the motor is no longer stressed. The rotation speeds of the axle coming from the motor when the spinning blades are turned on and off are the same now. The sound is also the same. The motor is finally at peace. Is it a simple case making as per the 2 pictures? are more parts needed to do? Quote
Ngoc Nguyen Posted July 29, 2020 Posted July 29, 2020 54 minutes ago, lee1980 said: Is it a simple case making as per the 2 pictures? are more parts needed to do? Yes it is simple. Overall you need these parts: - 3 20z tan gear - 1 3L liftarm - 2 blue 3L pins I also reinforced the structure inside the rotor a bit, but it has nothing to with the mod. I replaced the 5L axle + 3L connector with a 6L axle + 2L connector, and a connector pinhole with two pins. You don't have to do the second mod. Quote
lee1980 Posted July 29, 2020 Posted July 29, 2020 43 minutes ago, Ngoc Nguyen said: Yes it is simple. Overall you need these parts: - 3 20z tan gear - 1 3L liftarm - 2 blue 3L pins I also reinforced the structure inside the rotor a bit, but it has nothing to with the mod. I replaced the 5L axle + 3L connector with a 6L axle + 2L connector, and a connector pinhole with two pins. You don't have to do the second mod. Thank you, I think I get it will remember this if I decide to build or not at some point. Quote
efferman Posted July 29, 2020 Author Posted July 29, 2020 The wing is rebuilt. do anyone prefer a motorized wing rotate or is rotation by a crank ok? @Ngoc Nguyen, your reduction mod will be included Quote
Ngoc Nguyen Posted July 29, 2020 Posted July 29, 2020 18 minutes ago, efferman said: a motorized wing rotate Where do you plan to put the switch and the bi-direcional gearbox? Quote
efferman Posted July 29, 2020 Author Posted July 29, 2020 9 minutes ago, Ngoc Nguyen said: Where do you plan to put the switch and the bi-direcional gearbox? Dont know yet Quote
Dylan M Posted July 29, 2020 Posted July 29, 2020 I vote for Motorized wing rotate...that's cool ? Quote
pleegwat Posted July 29, 2020 Posted July 29, 2020 If manual, I think you'd still need some locking function to keep the wings in place when handling the model. If that means a worm gear, I'd go for motorized. Otherwise I'd go for moving the superstructure by hand (no gear connection to the turntable at all). Quote
SNIPE Posted July 30, 2020 Posted July 30, 2020 Today I did a quick and simple mod of replacing the white 2L pin joiners and friction axle pins under the wings with just 4L axles, because for some reason, When I turned the motor on, the axles were rotating just fine on both sides until it got to one of the white pin joiners on one side, then it stopped. However the other side worked fine on both sides of the pin joiner. The 42100 linear clutch is still activated when the VTOL is at its max or minimum rotation and even if the blades or spinning or stationary. Quote
R0Sch Posted July 30, 2020 Posted July 30, 2020 (edited) OK, this gearbox mod just seems to be as simple as can be. Just needs 3x z8 gears and taking out one of the dbg 3L beams. Credit goes to Huw who posted it today: https://brickset.com/article/52890/fixing-the-osprey Although this could theoretically happen so maybe not so effective: Edited July 30, 2020 by R0Sch added pic Quote
imvanya Posted July 31, 2020 Posted July 31, 2020 (edited) Maybe, something like this would work: It seems to fit, you get the double gears, and it is kind of braced. Edited July 31, 2020 by imvanya Quote
efferman Posted July 31, 2020 Author Posted July 31, 2020 (edited) my approach edit: Edited July 31, 2020 by efferman Quote
Huw Millington Posted July 31, 2020 Posted July 31, 2020 5 hours ago, imvanya said: Maybe, something like this would work: It seems to fit, you get the double gears, and it is kind of braced. Yes, that was my thinking too, after @R0Sch pointed out the potential problem with my solution which he posted above. I hadn't considered adding the 3l axles top and bottom but that's a great idea because any slack between the liftarms and the gears, which might cause the gears to misalign vertically, can be removed by tightening them slightly. Quote
SNIPE Posted July 31, 2020 Posted July 31, 2020 (edited) So I finally figured out how to make a super compact blade pitch and rotation mechanism *yey*: This has been tested IRL except I didn't have part 47501 so I just used a 1x2 plate and two pins with stud. Here's how it works: (The VTOL axle is hidden here but will still be present) The mini turntables are in the same place as the original model. The ball joint is actually not just tied to the VTOL line, it is its own function axle so you can change the blade pitch in VTOL or normal mode. Here is the LDR file Perhaps someone (Maybe @efferman ?) can figure out a way to attach the blades? The pinholes should really be on the sides not on top so the blades are awkward to mount. Regards, Snipe Edited July 31, 2020 by SNIPE Quote
SNIPE Posted August 1, 2020 Posted August 1, 2020 Solved it :) The first idea I had was to replace the 47501s with 3164s and attach the blades onto the two studs but this made the blades angle in and out on the wrong axis though it did look kinda cool. I actually, made the blades rotate in yet the 3rd wrong axis last night, which also looked kinda cool because it could also be used to unfold the blades like an umbrella. I'll post the other two designs just for fun soon in this reply. So then I figured out that I could just use some 32138s along with a thin beam and axle pins. One oversight I had was, since the blades are now pinned to the gark bluish gray wheel, I need a way to clamp the wheel together with the red gear while alllowing the axle to slide through it as well as rotate. Quote
Ngoc Nguyen Posted August 1, 2020 Posted August 1, 2020 Gear reduction mod explanation: First replace the 3-side black brace that meshes the black 12z gear with the tan 12z half gear in the yellow axle with a 3L beam and replace the black 12z gear with the tan 20z gear. Move the tan 12z half gear to the right 0,5 unit and add the white connector as a bracer. Then add two 20z gears into the rotors. Quote
suffocation Posted August 1, 2020 Posted August 1, 2020 I'm surprised those three z8 gears are the issue. I used the same exact technique in one of my tow trucks and it still works fine even after a year of relentless manhandling. Quote
Akbalder Posted August 1, 2020 Posted August 1, 2020 The torque of the new motors isn't the same. Could the problem be because the set was designed for the old motor? Quote
efferman Posted August 2, 2020 Author Posted August 2, 2020 what do you think about this colour sheme? or better coast guard? Quote
anyUser Posted August 2, 2020 Posted August 2, 2020 I would do mine like this: - in orange - not (US) coast guard (exept for the coloured 'stripes' on the wing(s) Quote
SNIPE Posted August 2, 2020 Posted August 2, 2020 (edited) Cracked it!. I needed to have a way to mount the gears and housing as well as the dark bluish gray wheel so that they allow an axle to slide in and out through it yet still rotate. Here's a video of it working: https://youtu.be/CIRMnGynUJE The pin with ball joint changes the blade pitch. The rotation is just done with a red frictionless 8 tooth gear which is stepped down to a pair of 12 tooth bevel gears (I will replace this with a 20+12 thin bevel gear pair actually for more torque). Also the wheel hub allows the axle to slide through the axle hole whilst still keeping the wheel clamped to the gear housing. This was the hardest part.One slight problem that needs fixing is the two discs can still slide along the axle because of the friction working against them. Also everything needs to be placed inside of a 7 x 11 technic frame since the spring keeps forcing the beams apart but now that I have a working prototype (the hardest part) the rest is easy. ldcad file coming soon! Regards, Snipe. Edited August 2, 2020 by SNIPE Quote
efferman Posted August 2, 2020 Author Posted August 2, 2020 7 hours ago, SNIPE said: Cracked it!. cool a little late, but coast guard. Quote
Elio Posted August 2, 2020 Posted August 2, 2020 41 minutes ago, efferman said: cool a little late, but coast guard. Looks awesome! Quote
Anio Posted August 3, 2020 Posted August 3, 2020 I bought a copy, built the model and wrote a review of the Osprey : http://www.techlug.fr/review-lego-technic/42113/bell-boeing-v-22-osprey-42113-markus-kossmann-2020 I gotta say, now that I have built it, I am very sceptical about all this shitstorm about 42113. It would make a lot of sense that TLG didn't cancel that model because of the military BS but because TLG found out very late in the process that the product has a very major design flaw in its core. And so took advantage of the situation to cancel the launch of the product. Redesigning and providing customer service for such a product would have been VERY complicated and VERY expensive. Analysing the product to come up with a fix matching Lego building standards, bringing home all sets already shipped, opening boxes, adding extra parts to fix the set, redoing instructions, reprinting them, maybe redoing box design, updating the production lines. And also all costs related to communication about this mess. Not to mention that the product would have been delayed a lot to get fixed and relaunched properly. Full cancel plain and simple was the simplest way to go. @Huw Millington Quote
