Posted September 4, 20204 yr I've Reconstruction 42113 V-22 Osprey The 3 problems with reconstruction were addressed as follows : 1. sticker The stickers were completely redesigned. Based on the scanned copy, it was completely redrawn. Printed and cut with a new design. 2. new color parts I visually checked where the new color parts were used. The parts of the new color were painted and prepared. 3. battery box I thought a lot about whether to look the same or function the same. Using a control+ hub, I thought of a different way because it can only be operated by connecting to a smartphone. It is designed to use 88000 Battery Box to perform the same functions. It is designed to turn on the power with the same red connector as the original one. The result worked as intended. Edited September 4, 20204 yr by Seo-onDaddy
September 4, 20204 yr @Seo-onDaddy I can see the photos now. Very nice reconstruction. I love your design for the battery box access. Can I quote it in the reconstruction mega thread?
September 4, 20204 yr Author 3 hours ago, JintaiZ said: I'm having the same issue. I solved the problem. 3 hours ago, Jurss said: I see photos. You are monster, especially about stickers. Thank you. It's a sticker download link. Use it if you need it. (PSD file. Print out a4 paper.) http://naver.me/GltorWzL 3 hours ago, Ngoc Nguyen said: @Seo-onDaddy I can see the photos now. Very nice reconstruction. I love your design for the battery box access. Can I quote it in the reconstruction mega thread? Thank you for your favorable evaluation. You may quote it to mega thread. It is a link between sticker and 88000 battery box io file. Download it if you need it. sticker sheet image download(PSD file. Print out a4 paper.)http://naver.me/GltorWzL 88000 BatteryBox io filehttp://naver.me/GaLivNa1
September 6, 20204 yr Author On 9/5/2020 at 7:52 PM, MinusAndy said: Can I ask what you painted the dbg with? I painted it with a Lacquer for a model. I made a color with a color combination.
September 6, 20204 yr Ahh so there’s no paint code for it? I’m savagely colourblind and may have to resort to a bit of this.
September 8, 20204 yr Author On 9/7/2020 at 6:06 AM, MinusAndy said: Ahh so there’s no paint code for it? I’m savagely colourblind and may have to resort to a bit of this. Unfortunately, there is no paint code. Orange and DBG colors are a combination of colors, and they also have different gloss, matte and semi-gloss depending on the parts.
September 17, 20204 yr Hi there, did you manage to get the technic hub working, i dont mind using a phone but how do i get access to the button?
September 17, 20204 yr Author 45 minutes ago, Jester945 said: Hi there, did you manage to get the technic hub working, i dont mind using a phone but how do i get access to the button? Hi. It works as well as intended. It is designed to push the button by the link when the connector is turned. The text shows the structure.
