LEGO and Unity recently co-developed a "microgame"; a tutorial on how to use the Unity editor:
It's a pretty cool little intro to gamedev, but it also makes use of some official Unity packages made by LEGO that can import and optimize models.
It currently supports .LDR and .LXF/LXFML (but only version 5.6 or higher, which is newer than what the last version of LDD exports, so currently you have to import LDD models into Studio, then re-export as LDR).
It has quite a lot of optimization features; too many to screenshot and explain here. You can see some of the menus for them in the pics above. There's even some basic support for snapping pieces directly together in Unity.
The brick library contains both "legacy" and "new" parts. These seem to effectively be two brick libraries - the legacy parts are what LDD was using (plus parts it didn't have), with studs and tubes fused to the rest of each brick model. The new parts seem slightly cleaned up, and have studs as separate meshes. The tool is also capable of dynamically adding bevels to all bricks, depending on the LOD setting.
Either way, there's a ton of new parts in here, even Duplo elements:
I'm not really sure what the rules and limitations are when it comes to using these packages - I think LEGO mostly anticipates them being used along with the Microgame, though you can easily add them to a new project and use them on their own. The included terms of service seem more focused on the Microgame aspect.
It's still in beta, so hopefully there's more to come?
Well, the LDD version number is another proof  (if that was needed) LDD is still in use and updated at LEGO but that’s the “pro” version.  If they never updated LDD it’s because it’s difficult to dumb down the pro version and keep both versions up to date.  (And the last LDD updates weren’t up to the “only the best is good enough” motto, even without talking about 4.3.12.)
I’d also note that Studio is based on Unity and that LEGO/BL is looking for an experienced Unity developer (LEGO/BL because advertised on BL, Studio’s forum, and posted on LEGO.com).
So I wouldn’t expect LEGO to give us a LDD-NG anytime soon.  (But I like surprises.)
This unity release is indeed interesting. A couple of observations.
  1. New parts geometry come as FBX files. The Autodesk FBX file format is a popular 3D data interchange format utilized between 3D editors and game engines (like Maya, 3DS Max, and engines like Unity, Unreal Engine)
  2. There are 3084 new parts within the release I downloaded
  3. Parts come with CollisionBox and Connectivity Info in an xml file format which is quite similar to the one used by LDD in the Primitive folder
I include an example of Duplo part 87316 xml file (Duplo Sheep from the picture above). So maybe we can get Duplo parts (including connections) into LDD :sweet:
Duplo parts seem to use connection type 36 (for their big studs).
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<LEGOPrimitive versionMajor="2" versionMinor="0">
  <Annotations>
    <Annotation designname="SHEEP, ASSEMBLED"/>
    <Annotation maingroupid="59"/>
    <Annotation maturitytag="Final"/>
    <Annotation modifiedDate="2019-11-22 13:10:00.000"/>
    <Annotation platformid="1"/>
    <Annotation revision="C"/>
    <Annotation superdesignid="11087316"/>
  </Annotations>
  <Collision>
    <Box sX="0.24493" sY="0.492992" sZ="0.291046" angle="5.63595" ax="0.822019" ay="-0.099613" az="-0.56068" tx="0.185727" ty="1.19394" tz="-1.48624"/>
    <Box sX="0.414112" sY="0.363022" sZ="0.414112" angle="0" ax="0" ay="1" az="0" tx="0" ty="0.383079" tz="0.022162"/>
    <Box sX="0.250179" sY="0.655048" sZ="0.250179" angle="17.87277" ax="1" ay="0" az="0" tx="3.31767" ty="1.1589" tz="-1.45066"/>
    <Box sX="0.920186" sY="0.49" sZ="0.49" angle="0" ax="0" ay="1" az="0" tx="-1.01271" ty="3.17653" tz="-0.769618"/>
    <Box sX="0.38982" sY="0.419253" sZ="0.294924" angle="29.67536" ax="0" ay="0" az="1" tx="-2.02529" ty="3.0319" tz="-0.675739"/>
    <Box sX="0.107982" sY="0.283579" sZ="0.527189" angle="15.96558" ax="-0.945804" ay="-0.321919" az="0.042698" tx="-1.25726" ty="3.95851" tz="0.27026"/>
    <Box sX="1.88275" sY="0.958764" sZ="0.58956" angle="0" ax="0" ay="1" az="0" tx="1.75959" ty="2.68464" tz="-0.814329"/>
    <Box sX="0.250179" sY="0.655048" sZ="0.250179" angle="21.2886" ax="-1" ay="0" az="0" tx="3.31767" ty="1.14561" tz="-0.191154"/>
    <Box sX="0.425685" sY="0.379218" sZ="0.425685" angle="0" ax="0" ay="1" az="0" tx="0" ty="0.399275" tz="-1.6093"/>
    <Box sX="1.3785" sY="0.213624" sZ="0.58956" angle="3.11413" ax="0" ay="0" az="-1" tx="1.74933" ty="1.52729" tz="-0.814329"/>
    <Box sX="0.107982" sY="0.283579" sZ="0.527" angle="23.53706" ax="0.265172" ay="0.57496" az="0.774019" tx="-1.50903" ty="3.84348" tz="-1.98599"/>
    <Box sX="0.24493" sY="0.492992" sZ="0.291046" angle="8.39376" ax="-0.923935" ay="-0.025877" az="-0.381673" tx="0.17828" ty="1.24443" tz="-0.131524"/>
    <Box sX="0.912232" sY="0.283579" sZ="0.440813" angle="0" ax="0" ay="1" az="0" tx="-0.597613" ty="3.85608" tz="-0.856895"/>
    <Box sX="0.428235" sY="0.374142" sZ="0.428235" angle="0" ax="0" ay="1" az="0" tx="3.18036" ty="0.394199" tz="0.022162"/>
    <Box sX="0.444395" sY="0.373783" sZ="0.444395" angle="0" ax="0" ay="1" az="0" tx="3.18036" ty="0.39384" tz="-1.6093"/>
  </Collision>
  <Connectivity>
    <Custom2DField type="22" width="4" height="4" angle="0" ax="0" ay="1" az="0" tx="-0.8" ty="0" tz="-0.8">
      29:0,29:0,29:0,29:0,29:0,
      29:0,29:0,32:4:1,29:0,29:0,
    </Custom2DField>
    <Custom2DField type="22" width="4" height="4" angle="0" ax="0" ay="1" az="0" tx="2.4" ty="0" tz="-0.8">
    </Custom2DField>
    <Custom2DField type="22" width="4" height="4" angle="0" ax="0" ay="1" az="0" tx="-0.8" ty="0" tz="-2.4">
    </Custom2DField>
    <Custom2DField type="22" width="4" height="4" angle="0" ax="0" ay="1" az="0" tx="2.4" ty="0" tz="-2.4">
    </Custom2DField>
    <Custom2DField type="23" width="4" height="4" angle="0" ax="0" ay="1" az="0" tx="1.65204" ty="4.16" tz="-1.6">
      29:0,29:0,36:4:33,29:0,29:0,
    </Custom2DField>
  </Connectivity>
  <PhysicsAttributes inertiaTensor="2.9137004,0,0,0,4.8618183,0,0,0,5.6452577" centerOfMass="0.668248,2.35493,-0.861872" mass="1" frictionType="0"/>
  <Color faces="0"/>
  <Bounding>
    <AABB minX="-2.70667" minY="0" minZ="-2.64944" maxX="4.04316" maxY="4.70987" maxZ="0.925694"/>
  </Bounding>
  <GeometryBounding>
  </GeometryBounding>
  <GeometryFittingCloud>
    -2.71;2.98;-0.601, -2.7;3.14;-0.612, -2.7;2.81;-0.584, -2.7;3.05;-0.774, -2.68;2.72;-0.582, -2.68;3.19;-0.791, -2.68;2.81;-0.844, -2.68;3.01;-0.49, -2.67;3.15;-0.497, -2.65;2.72;-0.853, -2.65;2.82;-0.433, -2.64;3.14;-0.904, -2.63;3.16;-0.431, -2.63;2.73;-0.422, -2.62;3.32;-0.637, -2.61;3.3;-0.831, -2.61;2.63;-0.848, -2.6;3.11;-0.386, -2.59;2.52;-0.589, -2.58;3.33;-0.504, -2.56;2.87;-1.04, -2.55;2.53;-0.871, -2.53;2.89;-0.275, -2.53;2.54;-0.414, -2.53;2.78;-1.06, -2.49;2.8;-0.251, -2.28;3.69;-0.715, -2.25;3.73;-0.558, -1.93;4.02;-0.606, -1.79;4.03;-2.48, -1.78;4.13;-2.25, -1.77;3.89;-2.56, -1.75;4.07;-2.52, -1.72;4.2;-2.28, -1.72;3.94;-2.63, -1.65;3.78;-2.64, -1.62;4.1;-2.54, -1.6;3.96;-2.63, -1.54;3.83;-2.65, -1.4;4.38;0.58, -1.39;4.27;0.767, -1.39;4.12;0.87, -1.38;3.95;0.887, -1.34;4.3;0.795, -1.33;4.14;0.914, -1.32;4.42;0.588, -1.31;3.96;0.926, -1.25;4.3;0.81, -1.24;4.14;0.904, -1.13;4.59;-0.859, -1.09;4.58;-1.06, -1.04;4.62;-0.889, -0.822;0;-1.55, -0.822;0;-0.0452, -0.784;0;-0.166, -0.763;0;-1.68, -0.762;0;0.0802, -0.645;0;0.193, -0.469;0;-2.09, -0.446;0;-2.24, -0.445;0;0.641, -0.366;0;-2.35, -0.351;0;0.749, -0.21;0;-2.4, -0.201;0;0.802, 0.0514;0;-1.07, 0.175;0;0.69, 2.33;2.65;-2.29, 2.45;2.68;0.679, 2.45;4.61;-0.8;0.48, 2.53;2.72;-2.25, 2.64;3.5;-2.01, 2.66;3.43;0.415, 2.74;3.54;-1.96, 2.83;2.84;-2.16, 2.95;2.87;-2.13, 2.98;0.348;0.78, 2.99;0.344;-2.38, 2.99;0;-2.4, 2.99;0;0.802, 3.04;0;-2.25, 3.06;0;-0.955, 3.06;2.26;0.507, 3.09;2.9;0.403, 3.11;2.28;-2.13, 3.14;2.97;0.375, 3.14;0;-2.38, 3.15;2.43;-2.09, 3.15;0;0.78, 3.17;0.34;0.739, 3.17;0.348;-2.34, 3.24;3.51;0.123, 3.25;3.37;0.195, 3.29;3.42;-1.83, 3.31;3.27;0.187, 3.31;0;-2.32, 3.32;0;0.722, 3.34;0.322;0.68, 3.34;2.79;-1.93, 3.35;0.325;-2.28, 3.4;3.41;-1.78, 3.41;3.44;0.0583, 3.41;3.35;0.0994, 3.42;0;-2.11, 3.46;3.54;-1.63, 3.48;0;0.637, 3.48;0;-2.24, 3.48;0.312;0.603, 3.49;2.77;-1.82, 3.5;3.39;-1.71, 3.51;0;-1.18, 3.51;0.3;-2.19, 3.57;3.82;-0.421, 3.57;3.7;-0.315, 3.58;0;-1.07, 3.58;3.25;-1.62, 3.58;2.78;0.0603, 3.59;0.404;0.502, 3.59;3.33;-1.58, 3.61;2.84;0.0267, 3.62;0;0.523, 3.62;0.149;0.521, 3.62;0;-0.493, 3.62;0.149;-2.12, 3.62;0;-2.12, 3.64;3.7;-0.436, 3.65;0.0116;0.497, 3.65;0.0115;-2.09, 3.66;0.612;-1.99, 3.67;0.0258;-0.443, 3.68;3.51;-0.324, 3.69;0.0496;0.443, 3.69;0.0498;-2.04, 3.7;0.146;0.422, 3.7;0.0975;0.426, 3.7;0.146;-2.02, 3.71;0.101;-2.02, 3.72;3.52;-0.398, 3.74;3.58;-1.26, 3.74;3.44;-0.362, 3.74;3.38;-0.344, 3.76;3.67;-1.11, 3.79;3.63;-0.88, 3.79;0.459;-1.83, 3.79;0.46;0.231, 3.8;3.48;-1.24, 3.81;3.62;-1.08, 3.84;3.56;-0.891, 3.84;3.57;-1.04, 3.84;3.44;-1.17, 3.85;0.46;0.0987, 3.85;0.46;-1.7, 3.87;3.45;-1.08, 3.87;0.46;-1.58, 3.87;0.46;-0.0193, 3.93;3.28;-0.625, 3.94;3.21;-0.566, 3.94;3.11;-0.524, 3.94;3.31;-0.723, 3.98;3.23;-0.935, 3.98;2.99;-0.563, 3.99;3.13;-1.01, 4.01;3.2;-0.742, 4.01;2.97;-0.997, 4.04;3.11;-0.751, 4.04;3;-0.758
  </GeometryFittingCloud>
</LEGOPrimitive>
The tool also comes with an ldraw.xml file which maybe familiar to some here.. snippet of the first couple of lines:
<LDrawMapping versionMajor="1" versionMinor="7" comment="LDD 4.3.11 Brick ver 2670">
    2020-02-02 twentytnewt
    See http://www.eurobricks.com/forum/index.php?showtopic=137193
    Download latest version: http://slswww.free.fr/ldraw.xml
    Please report errors to slswww@free.fr
    - includes v4.40 beta ldr-ldd_conver@gallaghersart.com http://www.eurobricks.com/forum/index.php?showtopic=66548
    - with additions/corrections from shutterfreak http://www.eurobricks.com/forum/index.php?showtopic=120821
    - with additions/corrections from djm
    - with additions/corrections from Mattia Zamboni (2015-09-30) http://forums.ldraw.org/thread-17387-post-17387.html#pid17387
    - with additions/corrections from TotiGonzales
    - with additions from Jarema
    - and a lot of corrections and updates since then
    This file can also be used with the command line tool lxf2ldr and the
    HTML5/JS “application” lxf2ldr.html:
    https://gitlab.com/sylvainls/lxf2ldr
    https://gitlab.com/sylvainls/lxf2ldr.html
Last but not least the info box you get when trying to import a LDD file:
Meanwhile I don't think 5.6 is referring to LDD 5.6 but rather to LXFML file format version 5.6. Currently LDD 4.3.11 uses
<LXFML versionMajor="5" versionMinor="0"> so afaik 5.0. Still changing this to
<LXFML versionMajor="5" versionMinor="6"> I wasn't able to import.
Finally also 2 interesting PDFs are included
Edited by M2m
Eh!  You’re right, it’s familiar.  I’m sure I’ve seen it somewhere.  But where?  :laugh:
(They could have used a more recent version though….)
More seriously, the LXFML format have changed through the years.  I don’t have any knowledge/example prior 2014 but there’s a schema (here and on lugnet I think?) that actually doesn’t describe the format used by LDD 4.  5.6 must be the format “in-house LDD” uses now.
I used the FBX files and the accompanied xml file to convert the Duplo 2x2 brick (3437) into LDD.
https://github.com/sttng/LDD/tree/master/NewParts
You can directly import the fbx file into blender and have to adjust the scaling to 1.00 (it was 0.0010 or something defaulted with my install) and export as .OBJ file. Then you can use polymakers brickstudio to convert this into .g file. I edited the xml file with notepad to match LDD format.
Caveat: Duplo parts connect to each other, but Lego and Duplo parts don't connect :(
The FBX parts have studs and tubes as separate meshes as well as the areas which can be textured or could be differently colored (Called DecorationSurfaces and ColorChangeSurfaces) all in one file. I am pretty confident LEGO internally has an LDD version which uses FBX files directly instead of .g files for the geometry or possibly a Maya Plugin.
Also Lego has an internal main brick library (VME tool), which has bricks in highpoly-geometry aimed for Box rendering and advertisement materials and lowpoly-geometry aimed for games, app, etc.
Technically FBX files support multiple LODs (Level of Detail), so I guess these files could have High Quality and Low Quality versions within the same file.
@polymaker would be awesome if brickstudio could read fbx files directly.
Edited by M2m
Do Duplo bricks have connectivity to standard bricks in the Unity software? Maybe the connection type was altered for regular bricks?
I have to check that. In fact i found the unity software quite confusing and couldn't even find the bricks inside unity.
But i checked the xml files for brick 3001 (2x4) and the connections look exactly the same.
3001 - new Unity version:
  <Annotations>
    <Annotation aliases="3001;6210;54534;72841"/>
    <Annotation designname="BRICK 2X4"/>
    <Annotation maingroupid="1"/>
    <Annotation modifiedDate="2018-08-30 13:53:00.000"/>
    <Annotation platformid="2"/>
    <Annotation revision="D"/>
    <Annotation superdesignid="11003001"/>
  </Annotations>
  <Collision>
    <Box sX="1.59" sY="0.79" sZ="0.47" angle="180" ax="0" ay="0.707107" az="-0.707107" tx="1.2" ty="0.48" tz="-0.4"/>
  </Collision>
  <Connectivity>
    <Custom2DField type="22" width="8" height="4" angle="0" ax="0" ay="1" az="0" tx="-0.4" ty="0" tz="-1.2">
      22:1:1,22:2:1,22:2:1,22:2:1,22:2:1,22:2:1,22:2:1,22:2:1,22:1:1,
      22:2:1,15:4:1,23:4:1,15:4:1,23:4:1,15:4:1,23:4:1,15:4:1,22:2:1,
      22:2:1,23:4:1,7:4:2,23:4:1,7:4:2,23:4:1,7:4:2,23:4:1,22:2:1,
    </Custom2DField>
    <Custom2DField type="23" width="8" height="4" angle="0" ax="0" ay="1" az="0" tx="-0.4" ty="0.96" tz="-1.2">
      18:1:1,23:4:1,18:2:1,23:4:1,18:2:1,23:4:1,18:2:1,23:4:1,18:1:1,
      23:4:1,0:4:1,23:4:1,0:4:1,23:4:1,0:4:1,23:4:1,0:4:1,23:4:1,
      18:2:1,23:4:1,18:4:1,23:4:1,18:4:1,23:4:1,18:4:1,23:4:1,18:2:1,
    </Custom2DField>
  </Connectivity>
  <PhysicsAttributes inertiaTensor="0.89742185,0,0,0,2.9365268,0,0,0,2.5241027" centerOfMass="1.18265,0.611081,-0.4" mass="2.19" frictionType="0"/>
  <Color faces="0"/>
  <Decoration faces="VME_11003001_LEG_Front_1"/>
  <Bounding>
    <AABB minX="-0.4" minY="0" minZ="-1.2" maxX="2.8" maxY="1.13801" maxZ="0.4"/>
  </Bounding>
  <GeometryBounding>
  </GeometryBounding>
    -0.4;0;-1.2, -0.4;0;0.4, -0.4;0.96;-1.2, -0.4;0.96;0.4, 0;1.14;-0.8;0.245, 0;1.14;0;0.245, 2.4;1.14;-0.8;0.245, 2.4;1.14;0;0.245, 2.8;0;-1.2, 2.8;0;0.4, 2.8;0.96;-1.2, 2.8;0.96;0.4
</LEGOPrimitive>
3001 - LDD 4.3.11 Version:
<LEGOPrimitive versionMajor="1" versionMinor="0">
  <Annotations>
    <Annotation maingroupid="201"/>
    <Annotation maingroupname="BRICKS"/>
    <Annotation platformid="200"/>
    <Annotation platformname="SYSTEM"/>
    <Annotation version="4"/>
  </Annotations>
  <Collision>
  </Collision>
  <Connectivity>
    </Custom2DField>
    </Custom2DField>
  </Connectivity>
  <PhysicsAttributes inertiaTensor="0.897422,0,0,0,2.93653,0,0,0,2.5241" centerOfMass="1.18265,0.611081,-0.4" mass="2.19000005722" frictionType="0"/>
  <Bounding>
    <AABB minX="-0.4" minY="0" minZ="-1.2" maxX="2.8" maxY="1.138" maxZ="0.4"/>
  </Bounding>
  <GeometryBounding>
  </GeometryBounding>
</LEGOPrimitive>
What could be done, just thinking out of the box: add the Duplo brick twice, but one version has regular brick connection data on its top. Since Duplo bricks are mainly used for quick fillers.
@M2m I had the idea that the library I was using did not support FBX but I checked again and it looks like it is supported.
I don't have any FBX files at hand to try but when importing choose "All files (*.*)" and then select an FBX file to see if it works.
Yeah this indeed works ! So it should be rather easy to convert some of these fbx bricks into LDD .g files with your tool !
OK I have identified the following parts which are not in LDD so far but for which there is geometries and xml data in the 'unity pack' - a whopping 1054 parts:
2162.fbx
2291.fbx
2292.fbx
2301.fbx
2302.fbx
2878.fbx
3011.fbx
3664.fbx
4066.fbx
4199.fbx
4543.fbx
4663.fbx
4886.fbx
4890.fbx
4891.fbx
4911.fbx
4912.fbx
6292.fbx
6377.fbx
6378.fbx
6391.fbx
6393.fbx
6446.fbx
6448.fbx
6472.fbx
6474.fbx
6497.fbx
6510.fbx
6521.fbx
6522.fbx
10093.fbx
10110.fbx
10531.fbx
10563.fbx
10566.fbx
10885.fbx
11030.fbx
11145.fbx
11146.fbx
11147.fbx
11169.fbx
11170.fbx
11181.fbx
11197.fbx
11198.fbx
11202.fbx
11236.fbx
11237.fbx
11244.fbx
11248.fbx
11317.fbx
11344.fbx
11371.fbx
11377.fbx
11385.fbx
11391.fbx
11650.fbx
12602.fbx
12789.fbx
13247.fbx
13338.fbx
13339.fbx
13358.fbx
13359.fbx
13366.fbx
13530.fbx
13531.fbx
13534.fbx
13535.fbx
13607.fbx
14094.fbx
14210.fbx
14222.fbx
14294.fbx
14533.fbx
14721.fbx
14770.fbx
15211.fbx
15301.fbx
15314.fbx
15327.fbx
15352.fbx
15449.fbx
15450.fbx
15452.fbx
15453.fbx
15454.fbx
15515.fbx
15516.fbx
15575.fbx
15576.fbx
15577.fbx
15580.fbx
15582.fbx
15612.fbx
15680.fbx
15743.fbx
15793.fbx
15880.fbx
15994.fbx
16016.fbx
16017.fbx
16087.fbx
16195.fbx
16196.fbx
16206.fbx
16265.fbx
16375.fbx
16406.fbx
16598.fbx
16685.fbx
16686.fbx
16709.fbx
16835.fbx
16846.fbx
17303.fbx
17370.fbx
17392.fbx
17557.fbx
17562.fbx
17684.fbx
17865.fbx
18016.fbx
18018.fbx
18340.fbx
18343.fbx
18515.fbx
18523.fbx
18626.fbx
18650.fbx
18652.fbx
18681.fbx
18715.fbx
18720.fbx
18726.fbx
18783.fbx
18806.fbx
18813.fbx
18816.fbx
18817.fbx
18818.fbx
18843.fbx
18849.fbx
18852.fbx
18857.fbx
18866.fbx
18917.fbx
18918.fbx
18921.fbx
18937.fbx
18984.fbx
19000.fbx
19001.fbx
19070.fbx
19084.fbx
19104.fbx
19443.fbx
19451.fbx
19456.fbx
19663.fbx
19804.fbx
19849.fbx
19993.fbx
20189.fbx
20193.fbx
20302.fbx
20311.fbx
20398.fbx
20678.fbx
20695.fbx
20785.fbx
20820.fbx
20841.fbx
20926.fbx
20932.fbx
21545.fbx
21619.fbx
21636.fbx
21830.fbx
21995.fbx
21996.fbx
21998.fbx
22878.fbx
22881.fbx
23146.fbx
23739.fbx
23740.fbx
23807.fbx
23927.fbx
23946.fbx
23961.fbx
23975.fbx
23991.fbx
24108.fbx
24128.fbx
24129.fbx
24179.fbx
24180.fbx
24181.fbx
24183.fbx
24264.fbx
24417.fbx
24434.fbx
24463.fbx
24806.fbx
24807.fbx
24876.fbx
24955.fbx
25026.fbx
25128.fbx
25450.fbx
25452.fbx
25548.fbx
25550.fbx
25551.fbx
25750.fbx
25824.fbx
25866.fbx
25981.fbx
26076.fbx
26090.fbx
26169.fbx
26170.fbx
26249.fbx
26281.fbx
26438.fbx
26451.fbx
26832.fbx
26835.fbx
26836.fbx
27055.fbx
27063.fbx
27157.fbx
27192.fbx
27205.fbx
27352.fbx
27355.fbx
27370.fbx
27382.fbx
27383.fbx
27395.fbx
27396.fbx
27965.fbx
28166.fbx
28291.fbx
28350.fbx
28376.fbx
28467.fbx
28560.fbx
28578.fbx
28592.fbx
28593.fbx
28599.fbx
28649.fbx
28650.fbx
28704.fbx
28732.fbx
29033.fbx
29129.fbx
29139.fbx
29141.fbx
29205.fbx
29219.fbx
29303.fbx
29306.fbx
29307.fbx
29335.fbx
29429.fbx
29575.fbx
30926.fbx
30935.fbx
30936.fbx
30938.fbx
30994.fbx
31023.fbx
31042.fbx
31059.fbx
31070.fbx
31110.fbx
31169.fbx
31191.fbx
31193.fbx
31195.fbx
31202.fbx
31333.fbx
31452.fbx
31453.fbx
31465.fbx
31496.fbx
31498.fbx
31509.fbx
31510.fbx
31511.fbx
31534.fbx
31570.fbx
31576.fbx
31577.fbx
31582.fbx
31584.fbx
31589.fbx
31592.fbx
31593.fbx
31733.fbx
31815.fbx
31895.fbx
31925.fbx
32643.fbx
32791.fbx
32807.fbx
32841.fbx
32977.fbx
33145.fbx
33440.fbx
33449.fbx
33459.fbx
33860.fbx
33861.fbx
34050.fbx
34130.fbx
34277.fbx
34337.fbx
34575.fbx
34578.fbx
34579.fbx
34684.fbx
34685.fbx
34714.fbx
34722.fbx
34729.fbx
34743.fbx
34744.fbx
34746.fbx
34747.fbx
34754.fbx
34755.fbx
34756.fbx
34758.fbx
34821.fbx
34828.fbx
35033.fbx
35035.fbx
35037.fbx
35039.fbx
35042.fbx
35043.fbx
35051.fbx
35066.fbx
35074.fbx
35106.fbx
35114.fbx
35131.fbx
35132.fbx
35136.fbx
35141.fbx
35155.fbx
35157.fbx
35160.fbx
35161.fbx
35162.fbx
35164.fbx
35165.fbx
35166.fbx
35167.fbx
35168.fbx
35169.fbx
35173.fbx
35180.fbx
35182.fbx
35183.fbx
35193.fbx
35209.fbx
35243.fbx
35244.fbx
35245.fbx
35248.fbx
35250.fbx
35251.fbx
35254.fbx
35257.fbx
35260.fbx
35262.fbx
35264.fbx
35267.fbx
35270.fbx
35274.fbx
35275.fbx
35276.fbx
35277.fbx
35278.fbx
35279.fbx
35282.fbx
35284.fbx
35286.fbx
35287.fbx
35289.fbx
35290.fbx
35293.fbx
35294.fbx
35297.fbx
35298.fbx
35300.fbx
35306.fbx
35309.fbx
35312.fbx
35315.fbx
35318.fbx
35319.fbx
35321.fbx
35323.fbx
35324.fbx
35327.fbx
35328.fbx
35332.fbx
35334.fbx
35335.fbx
35337.fbx
35339.fbx
35344.fbx
35345.fbx
35347.fbx
35371.fbx
35374.fbx
35375.fbx
35378.fbx
35380.fbx
35382.fbx
35383.fbx
35386.fbx
35388.fbx
35389.fbx
35391.fbx
35393.fbx
35395.fbx
35396.fbx
35398.fbx
35401.fbx
35402.fbx
35403.fbx
35404.fbx
35456.fbx
35457.fbx
35458.fbx
35463.fbx
35468.fbx
35473.fbx
35494.fbx
35529.fbx
35536.fbx
35543.fbx
35544.fbx
35545.fbx
35556.fbx
35562.fbx
35565.fbx
35570.fbx
35575.fbx
35578.fbx
35579.fbx
35582.fbx
35586.fbx
35598.fbx
35602.fbx
35608.fbx
35613.fbx
35617.fbx
35620.fbx
35621.fbx
35626.fbx
35630.fbx
35633.fbx
35641.fbx
35678.fbx
35679.fbx
35680.fbx
35692.fbx
35694.fbx
35699.fbx
35701.fbx
35709.fbx
35731.fbx
35743.fbx
35744.fbx
35754.fbx
35760.fbx
35779.fbx
35781.fbx
35784.fbx
35809.fbx
35827.fbx
35837.fbx
35855.fbx
35858.fbx
35902.fbx
36009.fbx
36017.fbx
36019.fbx
36060.fbx
36105.fbx
36291.fbx
36293.fbx
36452.fbx
36540.fbx
36654.fbx
36662.fbx
36672.fbx
36680.fbx
36687.fbx
36762.fbx
36806.fbx
37093.fbx
37178.fbx
37318.fbx
37340.fbx
37407.fbx
37408.fbx
37409.fbx
37441.fbx
37461.fbx
37495.fbx
37496.fbx
37530.fbx
37576.fbx
37679.fbx
37680.fbx
37696.fbx
37771.fbx
37779.fbx
37783.fbx
37811.fbx
37813.fbx
37823.fbx
37829.fbx
37837.fbx
37840.fbx
37846.fbx
37993.fbx
37997.fbx
38029.fbx
38142.fbx
38144.fbx
38147.fbx
38152.fbx
38317.fbx
38336.fbx
38339.fbx
38340.fbx
38480.fbx
38547.fbx
38548.fbx
38551.fbx
38552.fbx
38554.fbx
38648.fbx
38709.fbx
38781.fbx
38800.fbx
38801.fbx
38831.fbx
38842.fbx
38846.fbx
38864.fbx
38867.fbx
38994.fbx
39064.fbx
39124.fbx
39145.fbx
39146.fbx
39199.fbx
39215.fbx
39259.fbx
39260.fbx
39266.fbx
39294.fbx
39313.fbx
39315.fbx
39369.fbx
39376.fbx
39379.fbx
39382.fbx
39566.fbx
39613.fbx
39742.fbx
39796.fbx
39881.fbx
39921.fbx
39924.fbx
39926.fbx
39927.fbx
39991.fbx
39996.fbx
40066.fbx
40144.fbx
40145.fbx
40285.fbx
40527.fbx
40554.fbx
40666.fbx
40910.fbx
40919.fbx
40922.fbx
40923.fbx
40925.fbx
40930.fbx
40931.fbx
40933.fbx
40934.fbx
40936.fbx
40982.fbx
41125.fbx
41140.fbx
41153.fbx
41158.fbx
41159.fbx
41162.fbx
41163.fbx
41179.fbx
41201.fbx
41202.fbx
41324.fbx
41325.fbx
41326.fbx
41327.fbx
41328.fbx
41421.fbx
41612.fbx
41637.fbx
41805.fbx
41813.fbx
41814.fbx
41815.fbx
41816.fbx
41817.fbx
41818.fbx
41835.fbx
41852.fbx
41945.fbx
41969.fbx
41978.fbx
41989.fbx
42025.fbx
42029.fbx
42030.fbx
42205.fbx
42234.fbx
42413.fbx
42697.fbx
42722.fbx
42736.fbx
42799.fbx
42859.fbx
42863.fbx
43087.fbx
43439.fbx
43693.fbx
43859.fbx
43860.fbx
43864.fbx
43872.fbx
43979.fbx
44524.fbx
44665.fbx
44666.fbx
45141.fbx
45367.fbx
45607.fbx
46103.fbx
46289.fbx
46291.fbx
46342.fbx
46360.fbx
46364.fbx
46366.fbx
46374.fbx
46375.fbx
46376.fbx
46392.fbx
46472.fbx
46475.fbx
46491.fbx
46493.fbx
46494.fbx
46534.fbx
46840.fbx
46841.fbx
46891.fbx
47203.fbx
47204.fbx
47205.fbx
47206.fbx
47207.fbx
47392.fbx
47393.fbx
47394.fbx
48018.fbx
48544.fbx
49283.fbx
49295.fbx
49362.fbx
49364.fbx
49418.fbx
49492.fbx
49511.fbx
49546.fbx
49555.fbx
49576.fbx
49577.fbx
49578.fbx
49579.fbx
49585.fbx
49588.fbx
49600.fbx
49612.fbx
49630.fbx
49642.fbx
49649.fbx
49653.fbx
49654.fbx
49656.fbx
49663.fbx
49699.fbx
49700.fbx
49731.fbx
49949.fbx
49972.fbx
50015.fbx
50407.fbx
50408.fbx
50663.fbx
50665.fbx
51066.fbx
51172.fbx
51262.fbx
51274.fbx
51450.fbx
51465.fbx
51554.fbx
51557.fbx
51558.fbx
51703.fbx
51708.fbx
51943.fbx
51944.fbx
52084.fbx
52394.fbx
52395.fbx
52401.fbx
52494.fbx
52672.fbx
52684.fbx
52686.fbx
52754.fbx
52756.fbx
52929.fbx
53054.fbx
53063.fbx
53075.fbx
53083.fbx
53092.fbx
53117.fbx
53126.fbx
53461.fbx
53540.fbx
53798.fbx
53800.fbx
53801.fbx
53802.fbx
53821.fbx
53834.fbx
53973.fbx
54043.fbx
54092.fbx
54568.fbx
54598.fbx
54599.fbx
54645.fbx
54732.fbx
55532.fbx
55889.fbx
56178.fbx
56298.fbx
57417.fbx
57753.fbx
57763.fbx
57798.fbx
57878.fbx
58498.fbx
58589.fbx
59595.fbx
60111.fbx
60373.fbx
60417.fbx
60436.fbx
60604.fbx
60670.fbx
61310.fbx
61408.fbx
61649.fbx
62367.fbx
62840.fbx
63521.fbx
63871.fbx
64000.fbx
64147.fbx
64149.fbx
64151.fbx
64431.fbx
64454.fbx
64455.fbx
64461.fbx
64462.fbx
64561.fbx
64639.fbx
64675.fbx
64829.fbx
65004.fbx
65014.fbx
65043.fbx
65066.fbx
65068.fbx
65072.fbx
65073.fbx
65080.fbx
65098.fbx
65100.fbx
65101.fbx
65103.fbx
65104.fbx
65105.fbx
65108.fbx
65109.fbx
65110.fbx
65111.fbx
65112.fbx
65113.fbx
65114.fbx
65115.fbx
65116.fbx
65161.fbx
65180.fbx
65183.fbx
65184.fbx
65186.fbx
65188.fbx
65191.fbx
65195.fbx
65196.fbx
65200.fbx
65202.fbx
65203.fbx
65209.fbx
65213.fbx
65217.fbx
65224.fbx
65226.fbx
65266.fbx
65272.fbx
65273.fbx
65353.fbx
65358.fbx
65388.fbx
65417.fbx
65418.fbx
65425.fbx
65428.fbx
65432.fbx
65474.fbx
65489.fbx
65509.fbx
65521.fbx
65571.fbx
65578.fbx
65579.fbx
65580.fbx
65590.fbx
65630.fbx
65700.fbx
65702.fbx
65725.fbx
65727.fbx
65730.fbx
65738.fbx
65746.fbx
65753.fbx
65768.fbx
65942.fbx
66152.fbx
66155.fbx
66199.fbx
66820.fbx
66821.fbx
66880.fbx
67044.fbx
67063.fbx
67338.fbx
67737.fbx
67872.fbx
68778.fbx
68817.fbx
69234.fbx
70772.fbx
71953.fbx
75723.fbx
75903.fbx
76317.fbx
76338.fbx
76371.fbx
76609.fbx
76610.fbx
84748.fbx
84751.fbx
84752.fbx
84753.fbx
85347.fbx
85562.fbx
85564.fbx
85566.fbx
87084.fbx
87310.fbx
87316.fbx
87963.fbx
87964.fbx
87968.fbx
88069.fbx
88204.fbx
88476.fbx
88482.fbx
89200.fbx
89398.fbx
89406.fbx
89438.fbx
89751.fbx
89873.fbx
89879.fbx
90058.fbx
90265.fbx
90482.fbx
91873.fbx
91999.fbx
92002.fbx
92005.fbx
92009.fbx
92011.fbx
92014.fbx
92094.fbx
92198.fbx
92240.fbx
92241.fbx
92242.fbx
92243.fbx
92244.fbx
92245.fbx
92246.fbx
92247.fbx
92248.fbx
92249.fbx
92252.fbx
92453.fbx
92587.fbx
92710.fbx
92711.fbx
92916.fbx
93085.fbx
93086.fbx
93087.fbx
93286.fbx
93353.fbx
94887.fbx
94901.fbx
95156.fbx
95462.fbx
95463.fbx
95484.fbx
98061.fbx
98062.fbx
98073.fbx
98164.fbx
98170.fbx
98171.fbx
98172.fbx
98173.fbx
98200.fbx
98211.fbx
98218.fbx
98219.fbx
98222.fbx
98223.fbx
98224.fbx
98225.fbx
98233.fbx
98238.fbx
98252.fbx
98456.fbx
98464.fbx
98544.fbx
98783.fbx
99133.fbx
99143.fbx
99145.fbx
99146.fbx
99147.fbx
99417.fbx
99543.fbx
99848.fbx
1000202.fbx
1000211.fbx
1000222.fbx
1000230.fbx
1000290.fbx
1002613.fbx
1003846.fbx
1003986.fbx
1004302.fbx
1004372.fbx
1004533.fbx
1004915.fbx
1004917.fbx
1004928.fbx
1005015.fbx
1005056.fbx
1005127.fbx
1005179.fbx
1005754.fbx
1005760.fbx
1006030.fbx
1006085.fbx
1006110.fbx
1006317.fbx
1006319.fbx
1006320.fbx
1006334.fbx
1006355.fbx
1006361.fbx
1006362.fbx
1006363.fbx
1007526.fbx
1009784.fbx
1010355.fbx
1010399.fbx
1010404.fbx
1010455.fbx
1010462.fbx
1010468.fbx
1010470.fbx
1010471.fbx
1010475.fbx
1010480.fbx
1010481.fbx
1010482.fbx
1010491.fbx
1010556.fbx
1010674.fbx
1010679.fbx
1011318.fbx
1011322.fbx
Edited by M2m
I'm on macOS and there are 3 zip files in the folder:
/Users/m2m/MyFirstGame/Library/PackageCache/com.unity.lego.modelimporter@3.0.2/Data
  • CommonParts.zip
  • LegacyParts.zip
  • NewParts.zip
NewParts.zip contains all the new stuff.
Not sure where this is on Windows but I'd search for these zip files.
Edited by M2m
Hi,
I installed unity and launched the lego minigame but I cant find the lego bricks to start building.
Also that gear is not a real lego part to my knowledge right?
I think the gear is from a Dacta set of LEGOeducation set.
Tried that yesterday, but the pipe is long (and information is lost in the process, resulting LDraw parts that have no edge lines!):
  • Find the fbx in the right folder (or export part with minigame)
  • open the fbx in Blender
  • Set scale part to 25 (when you open fbx, scale is 0.01)
  • Export to STL ascii mode if you can (for some reason, my Blender crashes on me when I do that!). Otherwise export to obj and use anoter tool to convert obj to stl ascii, eg. meshmixer
  • convert stl to ldraw using stl2dat.
Clearly we need a proper .fbx to .dat converter!!!
I still can't find the parts in order to build in unity I just see small builds and textures, sounds, etc.
Does anyone know how tot find them?
Also I looked at the dacta duplo gears and those are different. this one looks like a 40 tooth gear but bigger and with exra pin holes.
That gear does not exist as a real LEGO part but it was made digitally for The LEGO Movie, it forms the rear wheel of this bike in the film proper. I can't link the exact post but about 2/3 of the way down page 2 of this thread there's a cutaway view of how it's used:
Edited by PicnicBasketSam
There has been an Update to the LEGO Unity Microgame:
LEGO Microgame - Version 1.1.3
This is the LEGO Microgame package. Learn to create your own LEGO game with this example project.
Changelog
## [1.1.3] - 2020-12-01
### Changed
- Update WebGL Publisher to 4.0.3
### Fixed
- Issue with grey skybox
## [1.1.2] - 2020-11-30
### Changed
- Update LEGO Model Importer Package to 3.0.3
- Update LEGO Materials Package to 2.1.0
- Update WebGL Publisher to 4.0.2
## [1.1.1] - 2020-10-28
### Changed
- Update LEGO Model Importer Package to 3.0.2
## [1.1.0] - 2020-10-26
### Changed
- Update LEGO Material Package to 2.0.0
- Update LEGO Model Importer Package to 3.0.1
## [1.0.2] - 2020-09-24
### Changed
- Update IET package to 1.1.0
### Fixed
- [Tutorial] Fixed: T6 - Step 8 - Multiple 'Touch Triggers' are highlighted in the hierarchy
- [Tutorial] Fixed: Tutorials 1,5 can not be completed when run again
## [1.0.1] - 2020-09-14
### Fixed
- Hotfix for walkthrough break in second tutorial
## [1.0.0] - 2020-09-09
### Added
- Beta version of the LEGO Microgame
So far I didn't see new parts being added. But the good news is that LEGO seems to maintain this Unity thing (in difference to LDD :pir-upset: )
Edited by M2m
