For the second upload I decided to go with the Round Boi CHS2 "Cheburashka) as it was one of the more beloved brainchildren of the Eastern Block train engineering. Being the backbone of Soviet passanger trafficking it has acomodated a large number of fans (i.e. fanatics) and was one of the main pillars of modern russian transport fans. Although it did not acheive the diety status like the later 4th model it prooved to be reliable and relatively simple. With upgrades these machines did run on russian railways till the early 2010s and thus were never subjected to the atrocity that is modern RZD livery. Sadly most of them were either scrapped or disassembled for parts for their younger CHS2T bretheren.
The MOC ( which is still in progress so crtisism is needed) has two versions with different liverys - the darker one represents the earlier version with a clear roof and a very funky antenna. The later mod has additional air tanks and isolators on its roof.
50402272032_206a200ab5_h.jpgz
IRL prototypes:
CHS2 "Cheburashka" aka "Chub"
file.php?id=13693&mode=view
CHS2T aka "brick" aka "shorty" aka "stub"
Excellent digital models, you've managed to capture plenty of details and colours from the real thing. I especially like the windscreens, and the interior detail - is there any in the cabs?
For the screenshots, I would recommend 1. turning on "outlines on bricks" in LDD's preferences menu, and 2. using LDD's built-in screenshot tool (keyboard shortcut ctrl+k) - it usually provides a sharper image, and takes away the background and base grid. Or even better, try Stud.io for beautiful renders - they just take longer to make!
Thanks, I will try to do something with it.
Looking good. Meanwhile, with regard to the prototype, I trust the high-vis orange on the nose of is a recent retrofit for safety. If so, I'd aim for a pre-retrofit version, much more aesthetically pleasing.
Another great model from you , i like very much those models from you , and thank you for LDD file of your moel from some days ago. will you also make a LDD file of this great train too.
I've made a google disk folder for these things
https://drive.google.com/drive/folders/1Rsua7OdfOtwoL1VczEbbX-Goqfiafg6J?usp=sharing
Edited by KvadratGnezdo
Me am back with roof adjustments, more accurate colour schemes and propper renders this time!
The early model with MPS colour scheme and GOST orange warning markings.
The later modified model in 90s-00s RZD livery.
On 10/5/2020 at 5:16 PM, Coal Fired Bricks said:
these look great. Love their nickname.
7 hours ago, Man with a hat said:
Quite impressive, especially the details at the front.
Thanks!
