Built for SHIPtember 2020, inspired by the Lepanto from the Gundam The Origin series.
Time it took to build was two and a half weeks and the length is 156 studs.
Mobile Suit Gundam: The Origin
A small escort ship deployed by the Earth Federation space fleet. Smaller than the Salamis-class cruiser, it is equipped with only a single mega particle cannon, but has a large number of missile launchers mounted all over its hull. With forward missile launchers, a VLS (Vertical Launch System) on top of the hull, and missile pods and missile launchers on its sides, it can fight using a wide range of physical projectiles.
Armaments: Mega Particle Gun, Foreword Internal Missile Launcher, 5-tube VLS, Missile Pods, 6-tube Missile Launcher and 2-barrel Machine Gun Turrets.
WIPs:
Afbeelding
Really does look like the source material to be sure.
Still think you should sneak in some Mitgardian green... at least on the inside.
It really doesn't look 150+ studs long, so it must also be quite tall too!  Any idea on how tall it is from bottom missile tube to top of the bridge?  Must be over 40!
Late start didn't seem to phase you- SHIPtember complete!
