mudseason Posted October 22, 2020 Posted October 22, 2020 Hi All, title is already self explanatory. I know that it is possible to connect powered up motors to a buwizz using dedicated adapters. What about controlling a powered up servo with buwizz? Is that possible? I did I quick search but did not find anything so specific. Thanks. Quote
Zerobricks Posted October 22, 2020 Posted October 22, 2020 You can control PU motors as simple motors. But to control them as servos you need to get position feedback from them which neither the converter cable or BuWizz 1.0 or 2.0 support. Quote
Newest_Tech320 Posted October 22, 2020 Posted October 22, 2020 1 hour ago, Zerobricks said: You can control PU motors as simple motors. But to control them as servos you need to get position feedback from them which neither the converter cable or BuWizz 1.0 or 2.0 support. Great Explanation! Quote
Aleh Posted October 22, 2020 Posted October 22, 2020 2 hours ago, mudseason said: dedicated adapters. What are they? Quote
2GodBDGlory Posted October 22, 2020 Posted October 22, 2020 4 hours ago, Aleh said: What are they? I believe that he is talking about the third-party adapters that have been recently released. You can check out this video for details. (Summary: PU extension wires, PF to PU adapters, and PU to PF adapters. They work about as you would expect, but are fairly expensive) Quote
mudseason Posted October 22, 2020 Author Posted October 22, 2020 correct, that's the cable. They're expensive and do not work for servo As I'm just looking for providing more juice to the motors (11-12V) a different approach could be to use an external battery and bypass the hub voltage limiter (if any). Was that already attempted by someone? Quote
kbalage Posted October 22, 2020 Posted October 22, 2020 @mudseason check out Philo's article, you won't be able to go beyond 10.5V with the Technic hub. Quote
mudseason Posted October 22, 2020 Author Posted October 22, 2020 thanks kbalage, seems my best option is: keep the PU motors replace the PU servo with a PF servo buy a pair of adapters feed everything with a buwizz. Quote
Aleh Posted October 22, 2020 Posted October 22, 2020 2 hours ago, 2GodBDGlory said: I believe that he is talking about the third-party adapters that have been recently released Thank you very much! In that case I'll try to avoid mixing PU and PF in one connection. Quote
2GodBDGlory Posted October 23, 2020 Posted October 23, 2020 23 hours ago, mudseason said: thanks kbalage, seems my best option is: keep the PU motors replace the PU servo with a PF servo buy a pair of adapters feed everything with a buwizz. Is there really that much advantage in PU motors over PF ones? It seems like an awful lot of trouble to use the new motors, rather than a classic Buwizz+ PF approach. Quote
FoxOne Posted October 23, 2020 Posted October 23, 2020 I believe embedded servo mode is the main reason. As a bonus, PU XL's are pure joy to mount, compared to cylinder-like PF 's. Quote
dr_spock Posted October 24, 2020 Posted October 24, 2020 For simple dumb motor control, you can wire the PF C1 & C2 to pins 1 & 2 on the PU connector. We'll have to start using PU motors for replacement of burned out PF motors in GBC modules at some point. https://youtu.be/_N65u7n6Ov4 Quote
Zerobricks Posted October 24, 2020 Posted October 24, 2020 14 hours ago, FoxOne said: I believe embedded servo mode is the main reason. As a bonus, PU XL's are pure joy to mount, compared to cylinder-like PF 's. And you can use motors as position sensors too. Quote
