Those new panels on the front of the bonnet will be a game changer for me when they come out in more colours. They will be fantastic on 3mm hose for making wheelarches and panel edges. The same goes for the new 3x2 beam with the curved beam. Perfect for stringing onto stiff hose and making compound curves.
This set as it is holds no interest for me aside from those parts.
  • Replies 183
  • Views 30.3k
You're very right here. So many new ways to build curved exteriors with these.
If you fast forward to 6:00  he shows if it can fit in the 42098 and the suspension
Just keep in mind, you'll have to cut your hose into 2 stud long bits. You can't put the hose all the way through the panel and out the other side. The center axle hole, turned the other way, prevents it.
12 hours ago, Maaboo35 said:
Low sidewall isn't a bad way to go. The world's biggest tractor tyre has low sidewalls, as seen here.
I was working under the assumption that that the wheels used were known to be the 30x20mm ones. Otherwise, I'm all for "tractor treaded" tires in all forms. :)
here is my  unboxing and speed build with accent to important inside moments
10 hours ago, sirslayer said:
This is my favorite review of this set ..
thank you, I wish I could talk in english free. But only autotraslated subtitiles are possible.
I'm impressed that Lego put full suspension including the two hard springs on a set this size, but the looks of the front end just aren't doing it for me. The hood seems a little too long and the headlights stick out way too much.
I like this set more and more. I think this is the best set of first wawe 2021
Built a modified version thanks to @Sariel's great speed building video
Since I haven't update my part collection with the newly released 2020 sets yet, you can see the compromises now and there and of course, I don't have any 2021 parts:laugh:
While the new 56mm tractor tire is very welcomed, I don't think it matches the car better than the old balloon tires though. The smaller version of the off road tire on 42124 will suite the car best.
Changed the color of C pillar and didn't bother build the roof stuff, also, modified the front fender.
Tried to move the headlight back and build a 3D grill. Sadly that I can't keep the iron 7-hole grill here.
12 hours ago, Thirdwigg said:
@rm8 Thanks for the review. Is that another 8081 Pickup Mod on the shelf?
yes, but done by my brother.
I decided to start on the digital model using sariels speed build.
I don't know if I should continue as it is tedious work but have put my current progress in a spoiler below for download:
I will add my mods when a digital file is complete either of my own work or if someone finishes it before me (it looks like people have but have not shared it yet)
Regards, Snipe
Edited by SNIPE
Fininshed my (digital) version.(with bigger tires)
Had to make some brickbuild solotions but i thinks it looks good!
or with smaller tires.
1 hour ago, JunkstyleGio said:
Or with smaller tires.
I like this one! Can you try with yellow rims? Don't know if they exist...
@JunkstyleGio I prefer with smaller tires
On 11/26/2020 at 10:51 AM, paul_delahaye said:
Trailer for the Claas with these tyres
I have fond machinery that could use 107 and 56 tire - Deutz Far 6046
https://www.deutz-fahr.com/en-eu/products/combine-harvesters/1194-serie-6040
And it could be made in 1:17,5 scale ...
Edited by I_Igor
One "7" was lost on the way...
That (Deutz Fahr 6040) could be interesting for @eric trax since his models are approximately in 1:17 scale
Sorry for to much off-topic...
Edited by I_Igor
5 minutes ago, eric trax said:
Nice :D but bright green colour make me headache...
Then Fendt 5185 harvester is better choice - it has ordinary green colour, or Claas Avero (with lime colour)...
You just read in my mind ;)
I had some different idea with Rubicon tires, so I'm working on this model (since it is small it will be all manual)...and harvester issue how to make both tracks and wheel drive still gives me a headache (and of course bad weather for photos since Fastrac is finished and updates for smallest manual Unimog 219 are finished).
So I hope that very early in January this Rubicon will be available here
Looks good! I like that colour combination. Too bad there are so few technic elements released in bright green. The body shape looks square and nice for replication in LEGO though. :)
