12 minutes ago, howitzer said:
All treads are useless on smooth surfaces, sets like 60222 have an axle connected to a wheel in the middle so that the treads turn when you push the thing around. I guess the rubber inserts for newer treads could help here but very few sets include those.
42023 and 42031 work okay. So does 42094, to an extent.
Just now, Rudivdk said:
At the top of the arm it definitely is a new l-beam, with curved (reinforced) backside to fit the 3x7x2 and 3x11x2 rounded panels
What the hell?
  • Replies 76
  • Views 19k
Posted Images
that is great news since I've needed such part for some few years...Next year should be interesting (LEGO wise)
Just now, Coolusername said:
Might be one of those 45° angled ones we have for ages.
Ah, true, my bad. For a moment I thought we'd be getting a new member in the thin liftarm family.
2 hours ago, I_Igor said:
but it looks like some new 2 x 3 L shaped liftarm?
Very nice and in black color as well, I'll just get a bunch of those from Bricks&Pieces.
Overall the set looks O.K., but that cabin glass looks like the frosted glass of my bathroom window. The operator will have to work blind I guess :grin:
Could be a semi-autonomous excavator. Or, it could have an array of exterior cameras, with the windshield there for familiar effect.
Oh yeah he will control his excavator  with his smartphone... Sounds familiar?
18 minutes ago, howitzer said:
Am I seeing wrong or is this a 7L liftarm with axleholes in ends?
I think it is this one
No it will have helping stuff for navigation :laugh:
Nice parts pack. Actually I think the initial idea of the designer has been the usage of pneumatics. The dimentions for the upper main arm for example seems more fitting for small 11x1 cylinder. The forward attachment of the small LA looks a workaround solution... Also the main frame surely has enough space for a pump.
6 hours ago, howitzer said:
Is that a 3x5 L-shaped liftarm with axleholes at the ends and at the corner?
Where do you see that?
Nevermind, I somehow failed to notice the curved reinforcement, which means that the part is an old one.
We will be able to correct this misunderstanding.
Pneumatics would be noticably pricier, I suppose.
It looks like the major new piece is the 2x3 curved panel extension in black used on the arm (pictured), which I guess you can consider either a panel or a liftarm
Still I'm really excited for this set. Sure it's not pneumatic as the name implies, but the coverage and parts usage is nice, and it looks like it will have the 3 functions we would expect with slewing, lowering the arm, and extending the bucket.
It would be good to get that wind screen/seat piece in a non-frosted clear but I understand the cost limitations of making a new mold just for the different texture
I guess we can pretend it's clear like we pretend other sets lacking a windscreen even have a windscreen to begin with
Also I hope the #22 panel in yellow has it's companion #21 in the set, but judging from past history I don't expect it to. I might throw this together in studio like I've done for some of the other 2021 sets before it's released, always a fun challenge :)
I'm not sure abour the distance between superstructure and tracks. Image suggests no distance:
But there I found that superstructure will touch track elements especially if boom is extended.
If I increase distance it doesn't look like the photo from catalog:
On second thought: Are there 16-tooth gears in the upper (track) beam or is something smaller used?
Edited by anyUser
I don't think the old style tread mates with anything smaller than 16T gears. 8T has the correct tooth profile but is too small, and all other small gears are beveled so they can't be used with the chains.
Distance between track and beam is different on top compared to ends, which suggests pulley wheels rather than 16T on top.
I think it might just be 8T gears :look: If it were pulley wheels then unless they were some new one with a cross axle hole, the 3L with stop would just fall out. I swear I can see some DBG teeth in the photo.
11 hours ago, SNIPE said:
Here's how I think it was done:
I'm not so sure about that. In the photo you can clearly see that there's no 16T gears on top at the front - you can see straight through to the beams on the other side for both tracks, something you wouldn't be able to do if there was a second 16T gear. Again, I think it's an 8T gear on top, even if it doesn't properly mesh with the tracks.
Edited by Bartybum
