Posted November 24, 20204 yr Hi, I went and tried to get custom parts but is using a different version of LDD. It did not show the Lego Company folder in Appdata/Roaming/ So what am I supposed to do? I am using LDD version 4.3.11.
November 24, 20204 yr a lot of people are usign this version... because the 4.3.12 is bugged... anyway, you must set the "ghost folders" to be shown, as written into the instructions
November 24, 20204 yr Author 4 hours ago, Rustinidiel said: a lot of people are usign this version... because the 4.3.12 is bugged... anyway, you must set the "ghost folders" to be shown, as written into the instructions Ok, you mean by the Hidden Folder right? Cause I did show it. At least I think.
November 25, 20204 yr 9 hours ago, Newest_Tech320 said: Ok, you mean by the Hidden Folder right? Cause I did show it. At least I think. my english is bad... yes i mean the hidden folders... check if you see them
November 25, 20204 yr Author 7 hours ago, Rustinidiel said: my english is bad... yes i mean the hidden folders... check if you see them Yes, I did so and I still didn't see it. But, I downloaded 4.3.11 from a different website.
November 25, 20204 yr 32 minutes ago, Newest_Tech320 said: Yes, I did so and I still didn't see it. But, I downloaded 4.3.11 from a different website. search inside this forum...there is the official LDD installer 4.3.11 shared by different users... try with it anyway is really strange... the correct path is "C/users/"your user"/appdata/Roaming/Lego Company/LegoDigitalDesigner/
November 25, 20204 yr I think (I’m not a Windows user) that the path depends on Windows’ version. On my Wine, it’s in “C:/users/ME/Application Data.” There’s also a “Local Settings” directory that some applications use (I believe it’s a link to AppData/something on a real Windows). Anyway, it’s MS (pronounced “a mess”), so look for a “Lego Company” folder in your user directory, somewhere. Oh, by the way, the directory doesn’t exist until you start LDD at least once. Edited November 25, 20204 yr by SylvainLS
November 26, 20204 yr You need to enable "show hidden folders" in a default windows install. Otherwise its not shown. On my Win10 the folder is: C:\Users\YOUR USERNAME\AppData\Roaming\LEGO Company\LEGO Digital Designer
November 26, 20204 yr Author On 11/25/2020 at 7:34 AM, Rustinidiel said: search inside this forum...there is the official LDD installer 4.3.11 shared by different users... try with it anyway is really strange... the correct path is "C/users/"your user"/appdata/Roaming/Lego Company/LegoDigitalDesigner/ Thank you
