deraven Posted December 15, 2020 Posted December 15, 2020 Astounding. The precision with which you've captured all the detail is fantastic. Your photography completes the job and makes it hard to distinguish between the Lego and the actual vehicle at a level that's not often seen. Spectacular build! Quote
Tierce Posted December 15, 2020 Posted December 15, 2020 Wow. This looks so realistic, I almost scrolled past it on Instagram! Very impressive! Quote
KLF Posted December 15, 2020 Posted December 15, 2020 Another great stuff from one of our LUG members! Quote
Edwin Korstanje Posted December 15, 2020 Posted December 15, 2020 SuperB replica with stunning detais Quote
Milan Posted December 16, 2020 Posted December 16, 2020 Frontpaged! Beautiful, realistic, rugged, large scale...I like it. Looking forward to see that short video of it. What scale it is? It seems somewhere around 1:11? Quote
Paliason Posted December 16, 2020 Author Posted December 16, 2020 MangaNOID, I_Igor, Aleh, jam8280, Shiva, Newest_Tech320, romulan, SATSOK, Paperinik77pk, DRAKE207, WvG_853, deraven, Tierce, KLF, Edwin Korstanje: Thank you very much, guys! On 12/14/2020 at 3:33 PM, Aleh said: Looks absolutely mindblowing! But I don't understand what function are motorized except steering? Can it drive? Or the model is manual mostly? BTW this is the most number of differentials I have ever seen :) yes, you get it right: only the steering is motorized. The rest is manual. A hand is also needed to move the vehicle. During the construction, I photographed the current situation a few times. Here are the photos: Suspension, front-rear steering: PF L-Motor, which is used for steering, using 4 Linear actuators: Here you can see the displacement of the wheels (half-stud) of one side relative to the other: Hydraulic oil tank: Pump: Bare chassis with cab: Here's how I assembled the front offset on the front of the cab: And here are just different shots of the different state of the model during construction: Quote
MinusZwei Posted December 20, 2020 Posted December 20, 2020 (edited) Hi, First of all, I have to say, this is a fantastic MOC... I am currently studying your pictures to get some new building techniques :)Speaking of that, I am curious about the design of your rims: I have tried to replicate them using stud.io, but to me, it looks like you are not using any gear to maintain the chain links into place. Am I correct? I have uploaded my stud.io file on BrickSafe. https://bricksafe.com/files/MinusZwei/truck-rims/truck rim.io Would be great if you could take a quick look and let me know what I missed :) Edited December 20, 2020 by MinusZwei Added stud.io file link Quote
Paliason Posted December 21, 2020 Author Posted December 21, 2020 MinusZwei: Thanx! On 12/20/2020 at 2:23 PM, MinusZwei said: Hi, First of all, I have to say, this is a fantastic MOC... I am currently studying your pictures to get some new building techniques :)Speaking of that, I am curious about the design of your rims: I have tried to replicate them using stud.io, but to me, it looks like you are not using any gear to maintain the chain links into place. Am I correct? I have uploaded my stud.io file on BrickSafe. https://bricksafe.com/files/MinusZwei/truck-rims/truck rim.io Would be great if you could take a quick look and let me know what I missed :) Yes, you are correct. My inner part of the disk cannot be correctly modeled in the CAD program Stud.io. The following pictures show the parts I used. Your version would work as well, but instead of two *plate round 4x4* I used only one *plate round 4x4 with 2x2 hole*. I wanted the whole circular part to be inside the disk as much as possible. The little *2x2 inverted dish* is there as a centering element. And there must be only 17 *chain links*. The chain ring is mounted on a 4x4 plate round so, that half the width of the ring protrudes into the free space. The diameter of the encircled chain has a slight tension. Quote
Jubuilder Posted December 23, 2020 Posted December 23, 2020 Very impressive model. I was scrolling through your post first and wondering why you only post pictures of the real truck, then I realized that's all Lego. Amazing and thanks for sharing. Quote
MinusZwei Posted December 23, 2020 Posted December 23, 2020 Gosh! The 17x instead of 18 makes the trick indeed, and then you don't have a risk of the chain to fall down since it is "clipped" on the 4x4 disk. What a great design :) Quote
