msk6003 Posted August 20, 2021 Posted August 20, 2021 I can't confirm but actuactor looks like black color. Quote
keymaker Posted August 20, 2021 Posted August 20, 2021 (edited) THIS IS HUGE! And definitely more interesting for me than 42100. I definitely see 4 large LAs in black color ^^ Edited August 20, 2021 by keymaker Quote
Bricksley Posted August 20, 2021 Posted August 20, 2021 (edited) 36 minutes ago, Ngoc Nguyen said: Looks like the rear blade only has one function. The lower cylinder is a linear actuator, but the upper one is brick built. There seems to be 6 functions: - Raising blade - Tilting blade - Track left - Track right - Ladder - Lifting ripper This is not tilt blade, it's pitch blade. This kind of blade can has 3 moves: 1. Lifting (up/down) all blade. 2. Tilt: 3. Pitch: In 42131 we've got only lift and pitch. Edited August 20, 2021 by Bricksley Quote
Ngoc Nguyen Posted August 20, 2021 Posted August 20, 2021 5 minutes ago, Bricksley said: This kind of blade can has 3 moves How does a real bulldozer achieve 3 kinds of move with only 2 pairs of cylinders? Quote
Technicallism Posted August 20, 2021 Posted August 20, 2021 This only happy thing for this set is I didnt saw much of sticker…. If true, i will get it…. But size of 40cm width x 48cm long is a headache for space planning…. Quote
Bricksley Posted August 20, 2021 Posted August 20, 2021 (edited) 6 minutes ago, Ngoc Nguyen said: How does a real bulldozer achieve 3 kinds of move with only 2 pairs of cylinders? A big simplification without going into the structure (blade geometry) and the operation of the working hydraulics. We skip lifting (2 cylinders). The tilt movement can only be realized with 1 (left or right) cylinder - the blade is connected to the beams, cylinders and trunions in such a way that the movement of one cylinder causes a kind of blade rotation (tilt). By adding a cylinder on the other side, we get the possibility of another move (pitch). Just pure mechanics (geometry + physics). Edited August 20, 2021 by Bricksley Quote
Ngoc Nguyen Posted August 20, 2021 Posted August 20, 2021 8 minutes ago, Bricksley said: . The tilt movement can only be realized with 1 (left or right) cylinder What if this set has both tilt and lift Quote
Jundis Posted August 20, 2021 Posted August 20, 2021 19 minutes ago, Bricksley said: In 42131 we've got only lift and pitch. Hmm are you sure? I mean if the pitch/tilt-cylinders are connected in that manner to allow rotation in 2 axles, they only have to be indipendently actuated to enable tilt (e.g. right retracts, left extend) or am I wrong? Quote
Bricksley Posted August 20, 2021 Posted August 20, 2021 (edited) 47 minutes ago, Ngoc Nguyen said: What if this set has both tilt and lift Can You explain what You mean? Lifting is not dependent for tilt & pitch. I'm know, geometry & movement of blade is not simple as e.g excavator/loader but it works :) 45 minutes ago, Jundis said: Hmm are you sure? I mean if the pitch/tilt-cylinders are connected in that manner to allow rotation in 2 axles, they only have to be indipendently actuated to enable tilt (e.g. right retracts, left extend) or am I wrong? Someone talk about 4 movement (control+), so there will be: lifting blade, pitch blade, lifting ripper, lifting ladder. Of course it was great to see it, but I'm not sure it will be included in set, not MOC ;) Edited August 20, 2021 by Bricksley Quote
Jundis Posted August 20, 2021 Posted August 20, 2021 1 minute ago, Bricksley said: Someone talk about 4 movement (control+) Two hubs. 8 motors ;-) Quote
Bricksley Posted August 20, 2021 Posted August 20, 2021 1 minute ago, Jundis said: Two hubs. 8 motors ;-) Or 1 hub, 4 motors: 1+2 drive & 3 for move + 4 for move change. Early people talking about just 1 HUB not 2. Quote
Jockos Posted August 20, 2021 Posted August 20, 2021 The high number of electronic parts could justify the high price. It would be cheaper with less C+ components. Quote
dabo Posted August 20, 2021 Posted August 20, 2021 If there was a version without C+ then I would consider buying it. I really like the look of it but C+ adds no value to me only cost. Quote
Ngoc Nguyen Posted August 20, 2021 Posted August 20, 2021 5 minutes ago, dabo said: If there was a version without C+ then I would consider buying it I got a deal to buy 42129 with no C+ for 150 EUR. I just emailed all of the vendors on Bricklink that sell that set and propose my terms. Quote
Anio Posted August 20, 2021 Posted August 20, 2021 5 minutes ago, dabo said: If there was a version without C+ then I would consider buying it. I really like the look of it but C+ adds no value to me only cost. 42131 without motors would be dull. A 42131 without motors would turn into an enormous 42028, which makes no sense. Quote
Bricktrain Posted August 20, 2021 Posted August 20, 2021 (edited) It's quite big Edited August 20, 2021 by Bricktrain Quote
TeamThrifty Posted August 20, 2021 Posted August 20, 2021 Its a definite purchase for me (once the 30% off offers arrive...). I'm pleased to say that i remained positive throughout that this would be a great set despite the leaked images.. What an outstanding year for technic!! Those yellow tracks.... the raised ridges on them will be great on carpets but terrible on hard surfaces, unless the material has changed from hard plastic to something more rubbery? (ps Enough of the anti-C+ already! We heard you on the last 4 sets, c+ is here, this is a c+ set. Live with it!!) Quote
Bartybum Posted August 20, 2021 Posted August 20, 2021 Do I spy a track tensioning mechanism??? Quote
Ngoc Nguyen Posted August 20, 2021 Posted August 20, 2021 (edited) 48 minutes ago, Anio said: A 42131 without motors would turn into an enormous 42028, which makes no sense. It makes sense for me cuz I like pretty sets for display. I think this set will sell like hot CATs. Edited August 20, 2021 by Ngoc Nguyen Quote
Seasider Posted August 20, 2021 Posted August 20, 2021 That’s a beast of a model. Not sure if it’s a day 1 purchase. Might wait for any deals Quote
howitzer Posted August 20, 2021 Posted August 20, 2021 9 minutes ago, TeamThrifty said: (ps Enough of the anti-C+ already! We heard you on the last 4 sets, c+ is here, this is a c+ set. Live with it!!) Thank you. --- The set looks great, the functions seem interesting and the new parts make me drool. Still, it's far too expensive for me to buy, at least as new. I have little doubt that there's two hubs and at least 6 or 7 motors, nothing else would justify the pricing. But maybe I can get one secondhand at some point... Quote
User5346 Posted August 20, 2021 Posted August 20, 2021 Ugh, would’ve looked so much better without the black box… Quote
Ngoc Nguyen Posted August 20, 2021 Posted August 20, 2021 The new cardan joint in the Zetros is included. Quote
thekoRngear Posted August 20, 2021 Posted August 20, 2021 8 minutes ago, User5346 said: Ugh, would’ve looked so much better without the black box… It is subjective. This is the first (and till now only) 18+ tagged set package that I liked. The bulldozer looks cool with the black background. Quote
