1gor Posted August 26, 2021 Posted August 26, 2021 (edited) 1 hour ago, SNIPE said: :((((((((((((((((( I understand, but real one has angled lower part of the blade. Edited August 26, 2021 by 1gor Quote
Bricktrain Posted August 26, 2021 Posted August 26, 2021 8 hours ago, SNIPE said: OK, I actually think the bent beams are a new parts, not just the 4 x 6 45 degree beam, I think it is a 4 x 6 L beam, it cannot be a 3 x 5 because it does not fit. Looking at the image of the box of the set, they look too steep to be 45 degrees, more like 90 degrees. Also, regarding my previous comment, yes the 2 x 1 grill slopes fit with a small gap so idk why lego didn't use them hehe. I suggest you build it and the sides also and then see what you think then. ;-) Quote
Polarlicht Posted August 26, 2021 Posted August 26, 2021 11 hours ago, SNIPE said: OK, I actually think the bent beams are a new parts, not just the 4 x 6 45 degree beam, I think it is a 4 x 6 L beam, it cannot be a 3 x 5 because it does not fit. Looking at the image of the box of the set, they look too steep to be 45 degrees, more like 90 degrees. Also, regarding my previous comment, yes the 2 x 1 grill slopes fit with a small gap so idk why lego didn't use them hehe. No way those are 90° in the set!! Quote
msk6003 Posted August 26, 2021 Posted August 26, 2021 @Sariel says he will upload review in septmber 10th. I can't wait review! I hope rumerd 1 hub 4 motor is fake.... Quote
AVCampos Posted August 26, 2021 Posted August 26, 2021 I'm divided on whether I prefer one motor per function, or one motor multiplexed for several functions: in the former case it's simpler and has less points of failure (anyone remembers the outriggers on 42009?), while in the latter case the gearing is more interesting to build and see work. Quote
Ngoc Nguyen Posted August 26, 2021 Posted August 26, 2021 How does the control for each of the gearbox-driven function work, I wonder? What I can think of is that either - You push a button / slide a slider for a function on the app, and the selector motor will rotate to the corresponding function while the drive motor spins the axle, or - You push a button to change the selector motor, and push another button / slide a slider to control the direction of that function. Quote
AVCampos Posted August 26, 2021 Posted August 26, 2021 I don't know how it's implemented, but personally I'd prefer the 2nd option: the first one adds too much latency to the controls, even for a slow-moving machine like a bulldozer. Quote
thekoRngear Posted August 26, 2021 Posted August 26, 2021 (edited) Nvrmnd Edited August 26, 2021 by thekoRngear Information already provided Quote
Gimmick Posted August 26, 2021 Posted August 26, 2021 (edited) 3 hours ago, AVCampos said: I don't know how it's implemented, but personally I'd prefer the 2nd option: the first one adds too much latency to the controls, even for a slow-moving machine like a bulldozer. I guess it will bascially be the same as in the 42114: You press a button -> the function will be selected and executed -> 4 Funktion -> 8 buttons or 4 levers. And I guess they will add a calibration helper like the clip in the 42114, so in the worst case the selector has to turn 270°. But if you create your own PU profile, you can remove and optimize that for faster selection. But we will see.. Edited August 26, 2021 by Gimmick Quote
M_longer Posted August 26, 2021 Posted August 26, 2021 5 hours ago, msk6003 said: I hope rumerd 1 hub 4 motor is fake.... That's not a rumor :)) 18 hours ago, SNIPE said: I actually think the bent beams are a new parts, not just the 4 x 6 45 degree beam, I think it is a 4 x 6 L beam, it cannot be a 3 x 5 because it does not fit. Nope. There's no magic behind the blade angles: Quote
SNIPE Posted August 26, 2021 Posted August 26, 2021 (edited) 2 minutes ago, M_longer said: Nope. There's no magic behind the blade angles: Oh ok, it just looked like 90 degrees in the photo. Edited August 26, 2021 by SNIPE Quote
msk6003 Posted August 26, 2021 Posted August 26, 2021 2 minutes ago, M_longer said: That's not a rumor :)) Nope. There's no magic behind the blade angles: Not include 3x11 taperd panel like efferman commented in very early? Quote
Timorzelorzworz Posted August 26, 2021 Posted August 26, 2021 450 EUR for 4 motors and one Hub is a bad Joke. Maybe the Hub is new and atomic driven to justify the price. Quote
JaBaCaDaBra Posted August 26, 2021 Posted August 26, 2021 Just now, Timorzelorzworz said: atomic driven Must be a Flux Capacitor Quote
HectorMB Posted August 26, 2021 Posted August 26, 2021 Regardless of they're rumors or not, it the official set comes with 1 hub and 4 motors, I don't complain, I'll just get disappointed about Lego and, obviously, I won't buy it. Unfortunately, despite all the complains, many people will still buy it, giving to TLG the motivation to continue increasing prices. Anyway... Just wait. Quote
Maaboo the Witch Posted August 26, 2021 Author Posted August 26, 2021 10 minutes ago, JaBaCaDaBra said: Must be a Flux Capacitor Great Scott. Quote
M_longer Posted August 26, 2021 Posted August 26, 2021 34 minutes ago, msk6003 said: Not include 3x11 taperd panel like efferman commented in very early? They are behind the blade shaping its sides, lower blade angle is made with these liftarms. Quote
msk6003 Posted August 26, 2021 Posted August 26, 2021 Just now, M_longer said: They are behind the blade shaping its sides, lower blade angle is made with these liftarms. Than this set include only 2 new part, 7 wide trade and thin taperd panel? Quote
M_longer Posted August 26, 2021 Posted August 26, 2021 (edited) 2 minutes ago, msk6003 said: and thin taperd panel? There are no new panels. I have interpreted your post in a wrong way. Standard 5x11 18945 panels :) So only tracks are new. Edited August 26, 2021 by M_longer Quote
jorgeopesi Posted August 26, 2021 Posted August 26, 2021 (edited) 7 wide tracks?, I thought it was new just the color... the old ones were already too wide... another bad new... Please Lego watch closer any tracks because they are almost all narrower than you build, well in fact they had the same problem with the wheels until a few time... Edited August 26, 2021 by jorgeopesi Quote
Jundis Posted August 27, 2021 Posted August 27, 2021 (edited) 7 hours ago, jorgeopesi said: 7 wide tracks?, I thought it was new just the color... the old ones were already too wide... another bad new... Please Lego watch closer any tracks because they are almost all narrower than you build, well in fact they had the same problem with the wheels until a few time... In this case, the width of the tracks fits quite nicely. According to the official spec sheet, the track width varies from 710 ... 915 mm, as the real machine has different track sizes for different working grounds. According to the pics, TLG represents the narrowest blade available, which has a width of 5584 mm. Counting studs on the front LBG lip + 1 stud per side and given the angle of the black part on the blade's sides, overall it's 49 studs. So 1 stud is about 114 mm. Track width should be 6.22 ... 8 studs. Edited August 27, 2021 by Jundis Quote
mpj Posted August 27, 2021 Posted August 27, 2021 There's a promotional video on Instagram (search for dylanchow). New black actuators with DBG connectors are ridiculous, simply ridiculous. Quote
TeamThrifty Posted August 27, 2021 Posted August 27, 2021 16 hours ago, msk6003 said: @Sariel says he will upload review in septmber 10th. I can't wait review! I hope rumerd 1 hub 4 motor is fake.... ..lets hope @Jim does a glass-half-full review to compensate for his glass-half-empty one then!! Seriously though, i always find my personal experience on buying the set to be more in line with jim's perspective than sariels. Others will no doubt have the opposite experience! Quote
TinkerBrick Posted August 27, 2021 Posted August 27, 2021 (edited) https://zusammengebaut.com/lego-technic-42131-cat-d11t-bulldozer-offiziell-per-video-vorgestellt-128573/ Edit: in the article from zusammengebaut.com is a link to a TLG Facebook post with a slightly longer video. Edited August 27, 2021 by TinkerBrick Quote
