Maaboo the Witch Posted June 19, 2021 Posted June 19, 2021 1 hour ago, allanp said: Do you mean the planetary reduction hub? No, I mean the black element used on the outside of the wheel. Quote
1gor Posted June 19, 2021 Posted June 19, 2021 38 minutes ago, Maaboo35 said: No, I mean the black element used on the outside of the wheel. To me looks like this https://www.bricklink.com/v2/catalog/catalogitem.page?P=4185#T=C&C=11 or this https://www.bricklink.com/v2/catalog/catalogitem.page?P=2958#T=C Quote
Maaboo the Witch Posted June 19, 2021 Posted June 19, 2021 1 hour ago, I_Igor said: No, neither of those match up. It looks like a saw blade crossed with a round 2x2 plate - the underside of the plate faces outward. Quote
1gor Posted June 19, 2021 Posted June 19, 2021 (edited) 46 minutes ago, Maaboo35 said: No, neither of those match up. It looks like a saw blade crossed with a round 2x2 plate - the underside of the plate faces outward. Hm, on published photos (ok they are blurry) it looks like one fo those...but you are right - it is on rear wheel; front looks like https://www.bricklink.com/v2/catalog/catalogitem.page?P=41530&idColor=4#T=C&C=4 (only black) with this https://www.bricklink.com/v2/catalog/catalogitem.page?P=4032#T=C&C=11 ? Or something like that (instead of vent)? https://www.bricklink.com/v2/catalog/catalogitem.page?P=98343pb02&idColor=77#T=C&C=77 EDIT: actually it has 6 spikes...and 2 x 2 studs round space to fit 2 x 2 plate round inside Edited June 19, 2021 by I_Igor Quote
msk6003 Posted June 19, 2021 Posted June 19, 2021 9 hours ago, Maaboo35 said: Has anyone been able to identify the element on the front wheel hub? I'm talking about the Zetros, by the way. On 6/3/2021 at 9:16 PM, msk6003 said: Looks like TLG use 35442 splat gear 6t black for front wheel cover. And I can found some 2x3 panel extender in DBG. And without that and new tire, I can't find any new interstring parts. Quote
Maaboo the Witch Posted June 19, 2021 Posted June 19, 2021 Yeah, that looks like it. Interesting! Quote
1gor Posted June 20, 2021 Posted June 20, 2021 Perhaps someone mentioned already, but here you can see that Zetros has 81 x 35mm tire Quote
992bricks Posted June 20, 2021 Posted June 20, 2021 You can also see that it has This at the edge of the roof of the cab in DBG Quote
1gor Posted June 20, 2021 Posted June 20, 2021 17 minutes ago, 992bricks said: You can also see that it has This at the edge of the roof of the cab in DBG Yes Quote
Zerobricks Posted June 20, 2021 Posted June 20, 2021 47 minutes ago, 992bricks said: You can also see that it has This at the edge of the roof of the cab in DBG If you check the UI of the app you can see a small switch slider suggesting a gearbox or a diff lock. Also the steering motor seems to be directly attached at the front of the front axle. Quote
992bricks Posted June 20, 2021 Posted June 20, 2021 6 minutes ago, Zerobricks said: small switch slider suggesting a gearbox or a diff lock As unlikely as it is, the set really needs both to be worth the price Quote
Zerobricks Posted June 20, 2021 Posted June 20, 2021 20 minutes ago, 992bricks said: As unlikely as it is, the set really needs both to be worth the price With a use of two or three wave selectors you could switch gears and lock the central and rear diff - all at once very easily. Also from the shape of the slider there seem to be only 2 positions, so no more than 2 gears. Quote
JLiu15 Posted June 21, 2021 Posted June 21, 2021 On 6/19/2021 at 9:05 AM, I_Igor said: Hm, on published photos (ok they are blurry) it looks like one fo those...but you are right - it is on rear wheel; front looks like https://www.bricklink.com/v2/catalog/catalogitem.page?P=41530&idColor=4#T=C&C=4 (only black) with this https://www.bricklink.com/v2/catalog/catalogitem.page?P=4032#T=C&C=11 ? Or something like that (instead of vent)? https://www.bricklink.com/v2/catalog/catalogitem.page?P=98343pb02&idColor=77#T=C&C=77 EDIT: actually it has 6 spikes...and 2 x 2 studs round space to fit 2 x 2 plate round inside It looks like this piece to me. Quote
992bricks Posted June 21, 2021 Posted June 21, 2021 (edited) 1 hour ago, JLiu15 said: It looks like this piece to me. I am not sure, but I can see 4 studs, though the image definitely does not give the best angle for working out what it is. Edited June 21, 2021 by 992bricks Quote
syclone Posted June 21, 2021 Posted June 21, 2021 (edited) It looks like this system gear to me, with a round 2x2 plate on top. P.S. as mentioned by msk6003 a few posts earlier it seems! Edited June 21, 2021 by syclone Quote
howitzer Posted June 21, 2021 Posted June 21, 2021 Yeah, what syclone and msk6003 said. It's the black splat gear. Quote
992bricks Posted June 21, 2021 Posted June 21, 2021 (edited) Hmm, I spy this in DBG on the windscreen. Which I think is a new colour. Edited June 21, 2021 by 992bricks Quote
Black_Belt_Titan Posted June 22, 2021 Posted June 22, 2021 My only wish for this set is to introduce this part, along with its mirrored counterpart, in DBG after the cancelled introduction last year in the Osprey Quote
Maaboo the Witch Posted June 23, 2021 Posted June 23, 2021 Has anyone else noticed that the front axle is quite a bit lower than the rear one? It's most visible on the wireframe image, but the side-on view shows it as well. It looks like a dog with worms dragging its bum across the carpet. Quote
Ngoc Nguyen Posted June 23, 2021 Posted June 23, 2021 14 minutes ago, Maaboo35 said: Has anyone else noticed that the front axle is quite a bit lower than the rear one? It's most visible on the wireframe image, but the side-on view shows it as well. It looks like a dog with worms dragging its bum across the carpet. I think they have the same height Quote
Bartybum Posted June 23, 2021 Posted June 23, 2021 (edited) @Maaboo35 look again, it's quite level. Edited June 23, 2021 by Bartybum Quote
Maaboo the Witch Posted June 23, 2021 Posted June 23, 2021 2 hours ago, Bartybum said: look again, it's quite level. You can see the actual body tilting backwards. It's subtle, but once I noticed it I couldn't unsee it. Quote
Bartybum Posted June 23, 2021 Posted June 23, 2021 (edited) 7 hours ago, Maaboo35 said: You can see the actual body tilting backwards. It's subtle, but once I noticed it I couldn't unsee it. Mmmm no you really can’t. The rear skirt is level along its entire length. I get you don’t like the set - I have my problems too - but you’re clearly just looking for things to be upset by. Edited June 23, 2021 by Bartybum Quote
Ngoc Nguyen Posted June 24, 2021 Posted June 24, 2021 Or the model just buckles slightly in the middle, similar to 42070. There are a hub and one or two motors in there. Quote
