992bricks Posted June 24, 2021 Posted June 24, 2021 2 hours ago, Ngoc Nguyen said: There are a hub and one or two motors in there. Hopfully more than two motors, I hope for 4 though. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 (edited) 7 hours ago, Bartybum said: Mmmm no you really can’t. The rear skirt is level along its entire length. I get you don’t like the set - I have my problems too - but you’re clearly just looking for things to be upset by. Nope, I've checked the image and there is some slanting going on. Check the top edge of the image and compare it to the rear skirt. Edited June 24, 2021 by Maaboo35 Quote
agrof Posted June 24, 2021 Posted June 24, 2021 44 minutes ago, Maaboo35 said: Nope, I've checked the image and there is some slanting going on. Check the top edge of the image and compare it to the rear skirt. You really want to see something, what is not there, sorry. The edge of image is never a good reference, as the picture of the target can be tilted (by purpose in editing, by mistake while somebody took a picture, whatever). Example: Actually the Zetros is rotated slightly clockwise on the referred screenshot. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 Rotating the image counter-clockwise would make the front axle look even lower. The wireframe image used in the CONTROL+ illustration REALLY accentuates it. Quote
Bartybum Posted June 24, 2021 Posted June 24, 2021 (edited) 31 minutes ago, Maaboo35 said: The wireframe image used in the CONTROL+ illustration REALLY accentuates it. Yeah it's visible in the wireframe image, on the order of two or three studs, but not in the side view. 1 hour ago, Maaboo35 said: Nope, I've checked the image and there is some slanting going on. Check the top edge of the image and compare it to the rear skirt. If anything, I could accept that the skirt is ever so slightly unlevel, but if anything it's slightly tail-up due to sagging weight like Ngoc said. To suggest it looks like a dog dragging its wormy butthole across the carpet is plain stupid. Edited June 24, 2021 by Bartybum Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 1 minute ago, Bartybum said: Yeah it's visible in the wireframe image, on the order of two or three studs Then there you go. Quote
Bartybum Posted June 24, 2021 Posted June 24, 2021 (edited) Just now, Maaboo35 said: Then there you go. You said it was obvious in the side view. You were wrong. In any case I'm done here lol Edited June 24, 2021 by Bartybum Quote
Andman Posted June 24, 2021 Posted June 24, 2021 17 hours ago, Maaboo35 said: You can see the actual body tilting backwards. It's subtle, but once I noticed it I couldn't unsee it. You are falling victim to an illusion. It's level. And even if it isn't because of tiny height differences because of the suspension... It's nothing i would complain about. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 4 minutes ago, Andman said: You are falling victim to an illusion. It's level. And even if it isn't because of tiny height differences because of the suspension... It's nothing i would complain about. It looks like TLG have used shadow to disguise it a little, but I still think the front axle looks lower. Quote
Andman Posted June 24, 2021 Posted June 24, 2021 1 minute ago, Maaboo35 said: It looks like TLG have used shadow to disguise it a little, but I still think the front axle looks lower. Seriously... :-D No offense, but seems you are a little obsessed ;) And even if you are right in the end. Then what? I would care more about how they build the drive train, the suspension, the control interface and the performance. And BTW, first you said the body is tilting backwards. And now you are saying that the front axle is lower, which basically means the body is tilting frontwards. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 Just now, Andman said: And now you are saying that the front axle is lower, which basically means the body is tilting frontwards. Oh, for the love of - seriously. If the front AXLE is situated lower than the rear axle, then it'll push the body UP at the front and cause it to tilt BACKWARD. THAT'S WHAT I'VE BEEN SAYING. Quote
Andman Posted June 24, 2021 Posted June 24, 2021 1 minute ago, Maaboo35 said: Oh, for the love of - seriously. If the front AXLE is situated lower than the rear axle, then it'll push the body UP at the front and cause it to tilt BACKWARD. THAT'S WHAT I'VE BEEN SAYING. Ok, now i know what you mean. Just misunderstood you. But still... There is more to care about then a tiny, tiny, subtle difference in height. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 2 minutes ago, Andman said: Ok, now i know what you mean. Just misunderstood you. But still... There is more to care about then a tiny, tiny, subtle difference in height. Just saying it's there, that's all. It probably is just the suspension, but it is there. Quote
Zerobricks Posted June 24, 2021 Posted June 24, 2021 (edited) Guys... I've seen real trucks bend more. It's made of plastic which bends... heck also the shock absorbers and tyres may compress under the weight. And since the hub is placed in front I would expect the front to be a bit heavier than the rear. Edited June 24, 2021 by Zerobricks Quote
Brickend Posted June 24, 2021 Posted June 24, 2021 It could be something as simple as lens distortion or post-production correction (although I can't see the issue in the side on image) , if it is actually a photograph and not a render. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 7 hours ago, Brickend said: It could be something as simple as lens distortion or post-production correction (although I can't see the issue in the side on image) , if it is actually a photograph and not a render. The review embargo date for this thing is the 16th of July, so we should be seeing good images shortly. Then we'll see if it actually does look like a dog with worms dragging its bum across the carpet... Quote
Rebel_Lego Posted June 24, 2021 Posted June 24, 2021 32 minutes ago, Maaboo35 said: The review embargo date for this thing is the 16th of July, so we should be seeing good images shortly. Then we'll see if it actually does look like a dog with worms dragging its bum across the carpet... Come on, this set isn’t that bad. Yes it’s very expensive, and yes there are better looking MOCs out there, but still it is a decent looking trial truck, with new tractor tires, and remote controlled, so I don’t see why beeing so harsh. Critisism is ok, but this is overdone. Quote
1974 Posted June 24, 2021 Posted June 24, 2021 Using an app as a "remote" is pure dog bum though .. Quote
Maaboo the Witch Posted June 24, 2021 Posted June 24, 2021 47 minutes ago, Rebel_Lego said: Come on, this set isn’t that bad. Yes it’s very expensive, and yes there are better looking MOCs out there, but still it is a decent looking trial truck, with new tractor tires, and remote controlled, so I don’t see why beeing so harsh. Critisism is ok, but this is overdone. I haven't criticized this set that much. I made a comment about the stance looking off. That's really it. 26 minutes ago, 1974 said: Using an app as a "remote" is pure dog bum though .. Sorry '74, but TLG ain't listening... Quote
1974 Posted June 24, 2021 Posted June 24, 2021 '35, TLG will be selling legacy apps for only 99EUR in the years to come Quote
Maaboo the Witch Posted June 25, 2021 Posted June 25, 2021 Shame TLG didn't go with this colour scheme, considering the limited use of yellowish orange hitherto. Quote
1gor Posted June 25, 2021 Posted June 25, 2021 53 minutes ago, Maaboo35 said: Shame TLG didn't go with this colour scheme, considering the limited use of yellowish orange hitherto. In this color it would be worthy successor of 42099 set and IMHO it could be more suitable for some trial trucking Quote
1974 Posted June 26, 2021 Posted June 26, 2021 But that is camouflage = military = BAD! Also, it would be a sticker nightmare. Looks cool though Quote
Maaboo the Witch Posted June 27, 2021 Posted June 27, 2021 A light or dark azure cabin and yellowish orange rear section would look great on this thing. On that note, the actual rear section looks like it's bright green. Could this colour be making a comeback? Quote
Jeroen Ottens Posted June 27, 2021 Posted June 27, 2021 1 hour ago, Maaboo35 said: A light or dark azure cabin and yellowish orange rear section would look great on this thing. On that note, the actual rear section looks like it's bright green. Could this colour be making a comeback? In the LEGO ideas typewriter bright green 3x5 L-beams are used... Quote
