Jim Posted September 25, 2021 Posted September 25, 2021 4 minutes ago, gyenesvi said: Well that sounds really good, in that case, I can also offer you the building instructions of my Unimog alternate above ;) Hehe, thanks for the offer, but I will start with the one Tim made (after my vacation, so it won't be online soon). I'm struggling to find time for things as it is, so I will take it one at a time. Quote
gyenesvi Posted September 25, 2021 Posted September 25, 2021 2 hours ago, Jim said: Hehe, thanks for the offer, but I will start with the one Tim made (after my vacation, so it won't be online soon). I'm struggling to find time for things as it is, so I will take it one at a time. Sure, of course, no rush, I also meant after that, if you have the time and the interest. Quote
Philo Posted October 4, 2021 Posted October 4, 2021 On 9/21/2021 at 3:05 PM, Milan said: Perhaps @Philo may know a thing or two about it. On 9/21/2021 at 6:18 PM, gyenesvi said: Does anybody know if the new parts are also available in Studio? I checked @Philo's page and did not find anything yet. Oh sorry I missed these pings! All Zetros parts are now on LDraw parts tracker (including the shield with Mercedes logo). And I made a parts pack for Studio, available here: https://philohome.com/studio/packs.htm Quote
gyenesvi Posted October 4, 2021 Posted October 4, 2021 21 minutes ago, Philo said: All Zetros parts are now on LDraw parts tracker Yes, I have recently found them, and already used the tires in my alternate, thanks a lot! Quote
keymaker Posted October 4, 2021 Posted October 4, 2021 44 minutes ago, Philo said: And I made a parts pack for Studio, available here: https://philohome.com/studio/packs.htm This site is pure gold! Thank you so much, I really needed it! Quote
Ngoc Nguyen Posted October 5, 2021 Posted October 5, 2021 I want to buy some custom off road rims and tires to make this model look more like the real Zetros. Can anyone recommend some websites or vendors with international shipping? Quote
Igor1 Posted October 5, 2021 Posted October 5, 2021 @Ngoc Nguyen As far as I remember, @rm8 recommended these tires in his Zetros review. Quote
Jundis Posted October 24, 2021 Posted October 24, 2021 19 minutes ago, Ngoc Nguyen said: @TLG: Please take note at 2:23 - 2:29. Quote
1gor Posted October 24, 2021 Posted October 24, 2021 1 minute ago, Jundis said: @TLG: Please take note at 2:23 - 2:29. Small differential is always welcome, but I wonder how reliable will it be (there are no smaller bevel gears than 12 tooth)? Quote
Jundis Posted October 24, 2021 Posted October 24, 2021 2 minutes ago, 1gor said: Small differential is always welcome, but I wonder how reliable will it be (there are no smaller bevel gears than 12 tooth)? My intention was to stress the part: "...provides high ground clearance..." Quote
1gor Posted October 24, 2021 Posted October 24, 2021 32 minutes ago, Jundis said: My intention was to stress the part: "...provides high ground clearance..." Understand; Lego Zetros has "good ground clearance" for a living room...and tires are of more plastified material than I would like... Quote
gyenesvi Posted October 24, 2021 Posted October 24, 2021 6 hours ago, 1gor said: Small differential is always welcome, but I wonder how reliable will it be (there are no smaller bevel gears than 12 tooth)? I keep dreaming of a small (3x3x3) differential :) probably doable with integrated gears like the planetary hub. But then the next problem would be driving it, as the driving gear and axle could be at most half a stud thick.. So the next step should be integrating it with a housing that serves as the axle center, and the female part of the driving CV joint, just as in the planetary hub. That could be the starting point for building thinner axles with more ground clearance.. Would have been nice if TLG focused on this instead of the diff lock that results in an enormous axle.. Quote
1gor Posted October 24, 2021 Posted October 24, 2021 Just now, gyenesvi said: I keep dreaming of a small (3x3x3) differential :) probably doable with integrated gears like the planetary hub. But then the next problem would be driving it, as the driving gear and axle could be at most half a stud thick.. So the next step should be integrating it with a housing that serves as the axle center, and the female part of the driving CV joint, just as in the planetary hub. That could be the starting point for building thinner axles with more ground clearance.. Would have been nice if TLG focused on this instead of the diff lock that results in an enormous axle.. ...and I suppose that we would need new frame for differential housing...idea is cool Quote
gyenesvi Posted October 24, 2021 Posted October 24, 2021 Just now, 1gor said: ...and I suppose that we would need new frame for differential housing...idea is cool I mean the diff and its frame would have to be integrated into one enclosed unit. I think it would be possible to make it 5 studs wide (with mounting points), 3 studs tall and 4 studs in length. The length would be 4 studs because if the actual diff inside is a bit less than 3 studs, then on the front side, the female part of the CV joint could be built in. Quote
gyenesvi Posted November 12, 2021 Posted November 12, 2021 (edited) Yet another Zetros alternate is coming: Jeep Wrangler featuring a 2-speed gearbox coupled with an RWD/AWD lock (high gear is RWD, low gear is AWD), well articulated live axles, and the obvious openables, detachable roof. More images on Bricksafe. Edited November 19, 2021 by gyenesvi Quote
Igor1 Posted November 13, 2021 Posted November 13, 2021 @gyenesvi I really like! What a pity that there is no bottom view. Quote
Jundis Posted November 13, 2021 Posted November 13, 2021 11 hours ago, gyenesvi said: Yet another Zetros alternate Looks are just spot on, great work! I never thought so many brilliant B-models would be done from this rather ugly A-model :D Quote
gyenesvi Posted November 13, 2021 Posted November 13, 2021 5 hours ago, Igor1 said: @gyenesvi I really like! What a pity that there is no bottom view. 4 hours ago, Jundis said: Looks are just spot on, great work! Thanks, I have just added a bottom view to Bricksafe, you can check it out on the link above! I will write up the details of the drivetrain, suspension and the whole design process in a separate thread once I finish it completely, still fiddling with some minor details. Quote
dpi2000 Posted November 14, 2021 Posted November 14, 2021 On 11/13/2021 at 6:57 AM, gyenesvi said: Yet another Zetros alternate is coming Looks are just great ,I like very much.;) 16 hours ago, Jundis said: Looks are just spot on, great work! I never thought so many brilliant B-models would be done from this rather ugly A-model :D I also feel that. Quote
gyenesvi Posted November 14, 2021 Posted November 14, 2021 8 hours ago, dpi2000 said: Looks are just great ,I like very much.;) Thanks, I have to admit that looks was one of the main focus this time (the other was the gearbox). 8 hours ago, dpi2000 said: I also feel that. When a set has 2000+ parts, it's got a higher chance that you can get something interesting out of it :) and I was a bit surprised how good variety of panels and beams this one has, at least well suited for somewhat square models. Quote
Igor1 Posted November 15, 2021 Posted November 15, 2021 (edited) https://rebrickable.com/mocs/MOC-92394/grohl/mercedes-benz-g-wagen-42129-b-model/ Edited November 15, 2021 by Igor1 Quote
grohl Posted November 15, 2021 Posted November 15, 2021 (edited) 42129 Mercedes Benz G-Wagen The model is an alternate of the LEGO Technic 42129 Mercedes Benz Zetros Trial Truck. This G-Wagen is 42cm long, 20.5 cm wide and 20 cm high and is loosely inspired by the Mansory Startrooper Pickup Mercedes G-Class.The model features: permanent All Wheel Drive with 3 open differentials powered by 2 hard coupled L motors 3 possible gearing options for high torque, all around performance or high speed front axle steering with improved turning radius powered by 1 L motor 2-speed RC gearbox using 1M motor live axle suspension with improved travel fake inline 4-cylinder engine opening bonnet with support opening doors with locks opening tailgate and sunroof detailed engine bay, interior, exhaust system, side air vents, iconic G-Klasse grill easy to replace batteries Edited November 15, 2021 by grohl Quote
howitzer Posted November 15, 2021 Posted November 15, 2021 9 minutes ago, grohl said: 42129 Mercedes Benz G-Wagen The model is an alternate of the LEGO Technic 42129 Mercedes Benz Zetros Trial Truck. This G-Wagen is 42cm long, 20.5 cm wide and 20 cm high and is loosely inspired by the Mansory Startrooper Pickup Mercedes G-Class.The model features: permanent All Wheel Drive with 3 open differentials powered by 2 hard coupled L motors 3 possible gearing options for high torque, all around performance or high speed front axle steering with improved turning radius powered by 1 L motor 2-speed RC gearbox using 1M motor live axle suspension with improved travel fake inline 4-cylinder engine opening bonnet with support opening doors with locks opening tailgate and sunroof detailed engine bay, interior, exhaust system, side air vents, iconic G-Klasse grill easy to replace batteries <snip> Once again, I'm tempted to buy a set, not for what it is officially but for the alternate models that can be built from it. Awesome work as always! Quote
