When building a Lego sailboat today, an idea popped into mind. Using rudders as wings on a plane.lego-red-rudder-2-x-12-x-8-with-decoration-12247-55351-27-45336-81.jpg
Of course it would mean using actual rc plane electronics but they do have a symmetrical airfoil. I would love to see someone try and make a plane using these as wings.
Edited by Epic Technic
  • Replies 1.4k
When building a Lego sailboat today, an idea popped into mind. Using rudders as wings on a plane.lego-red-rudder-2-x-12-x-8-with-decoration-12247-55351-27-45336-81.jpgOf course it would mean using actual rc plane electronics but they do have a symmetrical airfoil. I would love to see someone try and make a plane using these as wings.
That part has no where near the surface area that an RC plane would require. Most planes don't have symetrical airfoils for the wings either (the exception being some earobatic aircraft).
Can we please not start the same discussion again?
:wall: Could not agree more..........The issue stems so much further than even physics and mechanics (which I will not elaborate on). Just not gonna happen folks for a myriad of reasons.....
lol! For the record, I'm part of the camp that thinks a 100% Lego RC airplane will never achieve controlled flight.
And I'm with you on it, but you know some people are immune to reason ;)
Does it keep pushing, or does the mtoor at some point in time stop as it's controller realizes that it won't reach it's final position? I would suspect that Lego has either a controller that is intelligent, or a current protector that safeguards the motor. Either way I don't expect this to be a case where you can fry the motor, it is a too easy fault not be to have been taken care of by Lego.
The motor does appear to keep pushing further for a second or two, but then it gives up with a little electronic *squeak*.
I never said it would be a big plane and with the correct angle of attacks it could work.
I literally said that you would have to use actual rc plane parts.
  • 4 weeks later...
I was feeling inspired today so I looked up 'magnus effect glider' (as any normal person would do) and came across this (which I highly recommend building) :
I was truly mind blown.
I was thinking if and how it could be done in LEGO. Any ideas?
I'm going with no. Thing is, I think the Magnus Effect is just too small, even for that thing.
The Magnus effect can be quite significant if you have a long enough path:
So if you are living near a high structure there should be no reason why it can't be done with a contraption made of Lego :devil::tongue:
Edited by Jeroen Ottens
Just to (try) and put this argument to rest, here's a question statement-Lets assume we had a properly sized piece to build a wing, the right motors, etc, etc, a lego plane would never fly just because of the sheer weight.
Maybe somebody should build one of these instead:
Kress Truck:
Someone should seriously build that...
.. lego plane would never fly just because of the sheer weight.
It has nothing to do with weight, heck not even aerodynamics much, it's all about POWARRR! And we'll not see such motors from TLG
Even the much heralded buggy motors are week sauce compared to even the cheapest proper RC motor (380 type
I think Lego could fly at least as well as that basketball... not quite straight down, and with a fairly low terminal velocity. Some of the pieces might even be reusable after "landing" :)
That Kress dumper looks interesting. It would be interesting to see someone provide turn and drive though a pivoting axle like that. Luckily it looks as though the back wheels don't steer.
I know, but my "argument" assumed that powerful enough motors were available...
I have a small question: I'm trying to build a winch like on the Unimog 8110 BUT with classic Lego Technic bricks. I borrowed a wormgear from my son, but now I can't have it meshed with an 8-teeth gear. (I'm not a technic mastermind). Is this possible at all? In Sariels book I saw an example with bevel gears, but I was wondering if I'm doing something wrong here....
You should be able to, like the first picture, left hand side here http://www.technicbricks.com/2014/01/lets-talk-about-gears.html
rotate the old beam with 90° (so it's vertical). I don't think you can fit them otherwise with straight studs-up build.
Edited by Lipko
How small "independent" rear wheel driven suspenssion can be build with "classic" technic parts ? Those up to 1999?
