Posted December 28, 20204 yr Sorry, newbie question. Will the red indicator light near the USB micro port on the hub change from red to green when the battery is fully charged? Am struggling to find any info from lego re: charging etc. Our hub keeps turning off and then disconnecting, so thought I would try charging the battery before further troubleshooting. Also is there anyway to tell the percentage charge on the battery? Thanks in advance.
December 28, 20204 yr Yes, the Charging LED changes to green when the battery is fully charged. You can view the battery level from the app, If you are using PC, I recommend to connect with the USB cable, this way the battery is charged while you are creating your program. / Carsten
December 30, 20204 yr On 12/27/2020 at 6:58 PM, T2Mum said: Sorry, newbie question. Will the red indicator light near the USB micro port on the hub change from red to green when the battery is fully charged? Yup. I plugged mine into a USB charging cube (I use it for phones too), took all night before the little light on the battery turned green.
