Zerobricks Posted January 1, 2021 Posted January 1, 2021 (edited) I got my 42123 a month or so ago and while it's a very awesome set out of the boy I knew I had to give it a proper differential. Here's how I did it in LDD: In order to preserve the original engine position the differential is moved back one stud: A pair of 8 tooth gears transfer the power from wheels to the differential: And while I was at it, I also made the steering work using 8 and 24 tooth gears: I plan to make a detailed HOW:TO video tomorrow, so stay tuned. Meanwhile you can download the LDD here: https://bricksafe.com/files/Zblj/42123-differential-and-working-steering-wheel-mod/42123 Differential and Working Steering Wheel MOD.lxf Edited January 3, 2021 by Zerobricks Quote
Gray Gear Posted January 1, 2021 Posted January 1, 2021 Nice Mods, you are basically doing LEGO's work here Quote
syclone Posted January 1, 2021 Posted January 1, 2021 Your angled gears solutions never cease to amaze me... How well does the 24t mesh at that angle? Or maybe the old crown gear would be better suited that the straight-cut teeth of newer one? Quote
Zerobricks Posted January 1, 2021 Author Posted January 1, 2021 Just now, syclone said: Your angled gears solutions never cease to amaze me... How well does the 24t mesh at that angle? Or maybe the old crown gear would be better suited that the straight-cut teeth of newer one? I originally wanted to use the crown 24Z gear, but AFAIK it's not being produced anymore. Quote
nicjasno Posted January 1, 2021 Posted January 1, 2021 Wait... the senna doesn't include a differential? Quote
mojitoca Posted January 1, 2021 Posted January 1, 2021 3 hours ago, Zerobricks said: I got my 42123 a month or so ago and while it's a very awesome set out of the boy I knew I had to give it a proper differential. Here's how I did it in LDD: In order to preserve the original engine position the differential is moved back one stud: A pair of 8 tooth gears transfer the power from wheels to the differential: And while I was at it, I also made the steering work using 8 and 24 tooth gears: I plan to make a detailed HOW:TO video tomorrow, so stay tuned. Meanwhile you can download the LDD here: https://bricksafe.com/files/Zblj/42123-differential-and-working-steering-wheel-mod/42123 Differential and Working Steering Wheel MOD.lxf Yes, I will check it out, when you're ready ! Quote
Jurss Posted January 2, 2021 Posted January 2, 2021 (edited) @Zerobricks Can we rename this topic to "mods and improvemnts", as we don't have this topic yet? Here is my differential This should be possible also with old type differential and with that larger "half"gear. But this could have been some "cheap" set with new type differential. And it would match so much this car. Edited January 2, 2021 by Jurss Quote
mojitoca Posted January 2, 2021 Posted January 2, 2021 Just now, Jurss said: @mojitoca Can we rename this topic to "mods and improvemnts", as we don't have this topic yet? Here is my differential This should be possible also with old type differential and with that larger "half"gear. But this could have been some "cheap" set with new type differential. And it would match so much this car. Just now, Jurss said: @mojitoca Can we rename this topic to "mods and improvemnts", as we don't have this topic yet? Here is my differential This should be possible also with old type differential and with that larger "half"gear. But this could have been some "cheap" set with new type differential. And it would match so much this car. Yes, good choice, and ok, mods and improvemnts sound great Quote
Bartybum Posted January 2, 2021 Posted January 2, 2021 Well that sucks, turns out the solution really was that easy. Cheers TLG lol Quote
Jurss Posted January 2, 2021 Posted January 2, 2021 I was afraid about that axle sticking out at the other end. But, because of that bend in chassis, it just fits. My version for steering wheel Quote
Jurss Posted January 2, 2021 Posted January 2, 2021 Finished it to check, that mods doesn't conflict somewhere. Yes, different color. Quote
Leewan Posted January 2, 2021 Posted January 2, 2021 I've built mine on Thursday, and did consider doing the same steering wheel mod as you @Jurss. My concern was that it would leave a big gap below the front of the windshield. Also, don't the bush and liftarms thin 1x2 you've added to the rear (behind the diff) push against the liftarms thin 1x6 when you fold the rear (step 75) ? Quote
Jurss Posted January 2, 2021 Posted January 2, 2021 How I substituted new parts, and something more (sorry for dust) New panel on the side Also there is some 2 different parts for side skirt front Replacment for that panel consists of Rear scoop On rear spoiler I used Rear diffusor I made this way, as I didn't had those parts (yes they are somewhere in sons unsorted parts, but I'm lasy to search) Additionally in fron I didn't used 2 1L liftarms, but that 3L piece I thnik, it looks better. Just now, Leewan said: My concern was that it would leave a big gap below the front of the windshield. No, it doesn't leave a gap, as those parts are under hood in fact. Yes, now those gears are visible, but this is technic. Yes, orginally loo would be much cleaner, but just from the top. That gap could be filled with some halfbeam 12 minutes ago, Leewan said: don't the bush and liftarms thin I don't see/feel any issues. I was worried about engine axle, but it just the right lenght, it doesn't affect steering, and here that bend really helps. Quote
Jurss Posted January 2, 2021 Posted January 2, 2021 @Leewan OK, covered everything by Your request 7L halfbeam added to that hood section and that hole covered with There can be anotherone halfbeam added behind dashboard section, then there won't be almost no gap between dashboard and hood. Quote
Leewan Posted January 2, 2021 Posted January 2, 2021 8 hours ago, Jurss said: @Leewan OK, covered everything by Your request Thanks for your effort. Quote
Zerobricks Posted January 3, 2021 Author Posted January 3, 2021 I uploaded a video of my MOD: Since meanwhile even more mods pipped up, I'd suggest building the whole models in LDD, so we can all colaborate on it. Quote
DayWalker Posted January 4, 2021 Posted January 4, 2021 Here is another rear diff mod (I assume It should be ok with my dummy chassis) with diff part 4525184 DIFFERENTIALE 3M Z 28 (same as Porsche 42056) should fit Quote
Jurss Posted January 4, 2021 Posted January 4, 2021 Yes, it should fit. Good, that there is space between conncetors #2 for some halfbushes, so that axles hold in place firmly. It is recomended to use 8Laxle with stop for camshaft, with the stop at the gear, so that gear really stays in place. Quote
psilostrasza Posted January 13, 2021 Posted January 13, 2021 On 1/2/2021 at 2:09 PM, Jurss said: Finished it to check, that mods doesn't conflict somewhere. Yes, different color. Hello, I made an account to ask this question. I'm new to building model Lego. I was wondering if the parts are painted, if so what method did you use to repaint the parts? Are there any tips and tricks you would recommend for doing so. It seems painting Lego seems a bit taboo since there practically no information available around online. The model hasn't come yet, but I intend to used an airbrush with liquid paint (my brother builds and customizes Gunpla and has good experience with model painting). I'm also keeping an eye out for a redesign of the spoiler for the standard Senna. Quote
SNIPE Posted January 13, 2021 Posted January 13, 2021 (edited) I'm not sure why lego didnt use these two new pieces that came in the mario penguin These could be used for so many things such as body panels, spoilers, and body panels and body panels. Part IDs are 77095 and 77090 Edited January 13, 2021 by SNIPE Quote
Jurss Posted January 13, 2021 Posted January 13, 2021 2 hours ago, psilostrasza said: I was wondering if the parts are painted, No, they are not painted, all ar in original colors, just from other sets, which I had. Quote
davidzoli Posted January 14, 2021 Posted January 14, 2021 Thank you! You just make me want to buy sets, I originally don't Without differential, this set was a big no-no for me. With this mod... I'll get this. Quote
psilostrasza Posted January 18, 2021 Posted January 18, 2021 On 1/13/2021 at 7:32 PM, Jurss said: No, they are not painted, all ar in original colors, just from other sets, which I had. Thank you for your response. It look awesome by the way! Are the grey parts on the bonnet not available in red? In terms of making the custom differential or changing the colour, is it viable to order the parts separately online or must I own another technic set to provide the parts? Quote
