Frequenzberater Posted March 20, 2021 Posted March 20, 2021 Youre right. Sorry for not expressing myself well. Quote
Ngoc Nguyen Posted March 20, 2021 Author Posted March 20, 2021 (edited) Anyone want a slightly visually unsettling candy? I think we have a 42080 contender. Observations: - It appears to have a 2nd axle lift. - Crane arm has two winches. This part I approve. It's very realistic. - Gear rack holder in either regular blue or dark blue. - Front nose use Corvette wheel arch in orange. - No 2-in-1 mark. Another B model bites the dust... - There's a new label that says pneumatic function. It's similar to the motorized function label on the 42113. Since this set only has the pneumatic label and not the motorized label, a manual pump or manual compressor should be in there somewhere. - Official name is American Tow Truck. - 42080 valves are back. Edited March 20, 2021 by Ngoc Nguyen Quote
suffocation Posted March 20, 2021 Posted March 20, 2021 15 minutes ago, Ngoc Nguyen said: - Gear rack holder in either regular blue or dark blue. This one? I'd love it in dark blue Quote
efferman Posted March 20, 2021 Posted March 20, 2021 1 minute ago, suffocation said: This one? I'd love it in dark blue yes, looks like standard blue Quote
DrJB Posted March 20, 2021 Posted March 20, 2021 Anyone has pictures yet ... or is it all wishes and speculations ? Quote
efferman Posted March 20, 2021 Posted March 20, 2021 1 hour ago, DrJB said: Anyone has pictures yet ... or is it all wishes and speculations ? yes, but it has a confidential stamp, so it is not possible to post it here. Quote
AirDolphin Posted March 20, 2021 Posted March 20, 2021 missed opportunity by LEGO to make it the same scale as 8285 and 42043. its the same scale as 42098. Quote
Timorzelorzworz Posted March 20, 2021 Posted March 20, 2021 1 minute ago, AirDolphin said: missed opportunity by LEGO to make it the same scale as 8285 and 42043. its the same scale as 42098. No, 42098 is 17 studs wide in cabin and a bit wider. This model fits with 15 studs perfectly the mid scale trucks 42112, 42008, 42024 Quote
Akbalder Posted March 20, 2021 Posted March 20, 2021 Did anyone succeed to read what's written on the truck's stickers? Quote
AirDolphin Posted March 20, 2021 Posted March 20, 2021 2 minutes ago, Timorzelorzworz said: No, 42098 is 17 studs wide in cabin and a bit wider. This model fits with 15 studs perfectly the mid scale trucks 42112, 42008, 42024 Generally LEGO determines scale by the wheels it uses as per designer videos, not the size of the set itself. which classifies 8285, 8258, 42043, 42009 all the same scale and 42128, 42098, cement truck the green tow truck in one scale. Quote
1gor Posted March 20, 2021 Posted March 20, 2021 (edited) 10 minutes ago, AirDolphin said: Generally LEGO determines scale by the wheels it uses as per designer videos, not the size of the set itself. which classifies 8285, 8258, 42043, 42009 all the same scale and 42128, 42098, cement truck the green tow truck in one scale. Don't get me wrong but 42009 is mobile crane and they usually have tires with 1370-1420mm (or bigger) diameter and trucks (like represented with sets) 42043, 8285, 8258 have 1000-1100mm tires...but generally you're right wheels (tires) determine scale. ...only classis U.S trucks tend to have a bit bigger tires than European when wreckers, dump trucks etc are equipped; only on highway trucks have smaller low profile tires Edited March 20, 2021 by I_Igor Quote
Timorzelorzworz Posted March 20, 2021 Posted March 20, 2021 4 minutes ago, AirDolphin said: Generally LEGO determines scale by the wheels it uses as per designer videos, not the size of the set itself. which classifies 8285, 8258, 42043, 42009 all the same scale and 42128, 42098, cement truck the green tow truck in one scale. The size of wheel defines the models scale, but not the scale to another model. 42043 and 42009 uses the same wheels, but are not in the same scale. In real live, the wheels of crane are much bigger than of standard truck. This means that with 15 studs wide, the 42009 fits the scale of 42008, 42024, 42112 and the new 42128. Quote
AirDolphin Posted March 20, 2021 Posted March 20, 2021 2 minutes ago, Timorzelorzworz said: The size of wheel defines the models scale, but not the scale to another model. 42043 and 42009 uses the same wheels, but are not in the same scale. In real live, the wheels of crane are much bigger than of standard truck. This means that with 15 studs wide, the 42009 fits the scale of 42008, 42024, 42112 and the new 42128. LEGO is not going by real life, even the new creator Porsche is bigger than the mustang with the same wheels. when in real life Porsche is much smaller than the mustang. 42009, 42043, 8285, 8285 with the same wheel/scale means they are more detailed than 42098 and whatever else is in that wheel size. sets with the same wheel size as 42043 are usually more detailed so expectations are set low for the 42128. it should have been a better version of the 8285. Quote
efferman Posted March 20, 2021 Posted March 20, 2021 this is more or less the front. so it is 15 wide Quote
Ngoc Nguyen Posted March 20, 2021 Author Posted March 20, 2021 The hood doesn't look openable, which probably means no engine. Quote
Void_S Posted March 20, 2021 Posted March 20, 2021 Hmm, headlights at the grill - looks very Peterbilt-ish! Quote
1gor Posted March 20, 2021 Posted March 20, 2021 28 minutes ago, Timorzelorzworz said: The size of wheel defines the models scale, but not the scale to another model. 42043 and 42009 uses the same wheels, but are not in the same scale. In real live, the wheels of crane are much bigger than of standard truck. This means that with 15 studs wide, the 42009 fits the scale of 42008, 42024, 42112 and the new 42128. From @efferman's drawing there is a space for it Quote
Void_S Posted March 20, 2021 Posted March 20, 2021 (edited) 2 minutes ago, I_Igor said: From @efferman's drawing there is a space for it Or, at least, the whole "front" opens, including the bumper (bumper+hood tils forward). It does not appear very authentic but TLG said it is not a copy model. Edited March 20, 2021 by Void_S Quote
1gor Posted March 20, 2021 Posted March 20, 2021 2 minutes ago, Void_S said: Or, at least, the whole "front" opens, including the bumper (bumper+hood tils forward). It does not appear very authentic but TLG said it is not a copy model. Like this Quote
Ngoc Nguyen Posted March 20, 2021 Author Posted March 20, 2021 This seems to be the real life inspiration. Quote
Void_S Posted March 20, 2021 Posted March 20, 2021 2 minutes ago, I_Igor said: Like this Exactly! Quote
Maaboo the Witch Posted March 20, 2021 Posted March 20, 2021 It looks a bit like the Lizard Hulk truck from Farming Simulator. Quote
efferman Posted March 20, 2021 Posted March 20, 2021 10 minutes ago, Ngoc Nguyen said: This seems to be the real life inspiration. but the crane is much to high Quote
Ngoc Nguyen Posted March 20, 2021 Author Posted March 20, 2021 1 minute ago, efferman said: but the crane is much to high My guess is that the length of the cylinder forces the crane to be like that. Quote
