AVCampos Posted November 30, 2021 Posted November 30, 2021 15 minutes ago, Maaboo35 said: everyone's favourite set 8315? Quote
Maaboo the Witch Posted November 30, 2021 Posted November 30, 2021 2 minutes ago, AVCampos said: 8315? Looks like a masterpiece next to the Craptor. Quote
gyenesvi Posted November 30, 2021 Posted November 30, 2021 40 minutes ago, Thirdwigg said: In addition to other issues mentioned, 42126 is not realistic in the placement of the rear axle pivot point. F-150s have a long driveshaft with a U-Joint far forward, and another U-Joint just forward of the rear axle. I tried to change this is my 4x4 version, which makes the axle movement more correct. That's more like something I was expecting from the real one, thanks. I understand that in lego, using the ball joint simplifies things, but a similar version with longer links and a U-joint more forward could have easily been achieved with the ball-joint technique as well. Not sure what stopped them from it. It would have been nice to get some of those 9L links in the set for example.. Quote
metulskie8 Posted November 30, 2021 Posted November 30, 2021 Hi, I tried to build a front in the style of the blue prototype, what do you think? Quote
AVCampos Posted November 30, 2021 Posted November 30, 2021 The simple fact that you used transparent parts for the headlights already makes it better than the original. Quote
Jundis Posted November 30, 2021 Posted November 30, 2021 12 minutes ago, AVCampos said: The simple fact that you used transparent parts for the headlights already makes it better than the original. Jep. My guess is: The original lego technic model (blue prototype) has been delayed from 2020 to 2021, cause they already had to many cars. Ford then introduced a new series (third generation) with a facelift so TLC had to change the design, resulting in a strange face. Quote
deehtha Posted December 1, 2021 Posted December 1, 2021 13 hours ago, gyenesvi said: - the whole front axle is very loosely attached to the chassis, and is wobbly as hell, although I can see a very simple and obvious option to fix it. It's as if they forgot about it. I checked several times that I did not forget something, and I had no suspicious spare parts left. Anybody seen the same? It is very loose. Feels to me like they made a last minute change to the front axle. While building mine, I felt like it wouldn't take too much effort to slide in a servo or C+ large motor in the space just behind the steering rack. Quote
Ngoc Nguyen Posted December 1, 2021 Author Posted December 1, 2021 I'm going to make a Studio model of this set in the next 2-3 weeks and share it here so that you guys can mod it to your heart's content. Quote
Jurss Posted December 1, 2021 Posted December 1, 2021 14 hours ago, metulskie8 said: I tried to build a front in the style of the blue prototype Much better Quote
Ngoc Nguyen Posted December 1, 2021 Author Posted December 1, 2021 There is indeed a lot of rolling resistance, for some reasons I still can't understand. The resistance felt when the model goes backward is more than that when it goes forward. Quote
Kostq Posted December 1, 2021 Posted December 1, 2021 Maybe the tires rub somewhere by oscillating too much? #wobble Quote
Ngoc Nguyen Posted December 2, 2021 Author Posted December 2, 2021 Here's the Studio model for 42126, with custom spiky tires sponsored by @Void_S https://bricksafe.com/files/nguyengiangoc/42126.io On 10/10/2021 at 5:30 PM, leonema said: does someone have the .io n/or .lxf file for this model? Check the link. Quote
Void_S Posted December 2, 2021 Posted December 2, 2021 7 minutes ago, Ngoc Nguyen said: sponsored by @Void_S For free! Quote
Arie Posted December 2, 2021 Posted December 2, 2021 I build a new chassis for the Raptor to make it RC and 4WD with lockable differentials. More details in the topic: Quote
gyenesvi Posted December 8, 2021 Posted December 8, 2021 Has anyone seen the Studio part for the new 4 stud wide steering wheel in this set? I can’t find it in Studio neither on @Philo‘s home page, I just guess it’s too new yet.. @Timorzelorzworz did you use something else in your alternate build? Quote
Thirdwigg Posted December 9, 2021 Posted December 9, 2021 I used the 5 diameter in my MOD. I still have not seen the 4.2ish steering wheel yet. Quote
gyenesvi Posted December 9, 2021 Posted December 9, 2021 18 hours ago, Thirdwigg said: I used the 5 diameter in my MOD. Thanks, that's my solution too for now. Quote
Timorzelorzworz Posted December 10, 2021 Posted December 10, 2021 On 12/8/2021 at 10:19 PM, gyenesvi said: Has anyone seen the Studio part for the new 4 stud wide steering wheel in this set? I can’t find it in Studio neither on @Philo‘s home page, I just guess it’s too new yet.. @Timorzelorzworz did you use something else in your alternate build? I used the smaller older one, it is a bit cheating but does not matter Quote
thekoRngear Posted February 17, 2022 Posted February 17, 2022 That is one seriously cool MOC. It is packed with functions making the Ford Raptor more worthy to buy IMO. All the functions seem solidly working. Quote
