Post your 42122 mods here.
I have added the steering and 4x4 based on the idea form @Zerobricks. But also added RC stuff (small motor, servo, IR and recharchable battery)
It is not done yet, the rear axle is only a placeholder, iam waiting on parts for that (ball joint and socket like front axle has). Rechareable battery box will go on top of the servo / behind the IR reciever!
The small driving motor sits under the hood and has a small gear reduction from an 8 tooth to a 24 tooth gear. Then it goes through 4 16 tooth gears (red one spins free for steering to go through), to both axles.
The servo sits in the back (also backwards) it steers only the front axle with 4 universal joints going through the chassis from back to front.
Edited by Coolusername
Maybe with some more modification. Because it needs to go in sideways with the flat sides of the L motor on top and bottom so the hood closes and it wont touch the steering gear, which it alrady does with the current M motor. Suspension still works but that gear pushes the motor up a bit when you compress both front axle sides at the same time. Its fine when only one wheel is compressed, since the steering gear is in line with the suspension pivot point (big ball joint). Of course you can make the chassis on beam higher and have more clearance for a bigger motor.
It wouldn't be unusual for such a vehicle to have a lift kit fitted.
It'll be a small gain, but putting the M motor with the studs up would give a little extra clearance at the bottom, assuming the hood still closes.
I think an L motor is better if it fits, just to lose that reduction inside the cabin but also the benefit of moar powah!
Edited by amorti
Do you mean the anti studs downwards with that? Like i said the steering gear touches the motor, or maybe has 1 mm in between. It would still fit, but i don't want that gear hitting those anti studs and lock up. The topside of the motor is smooth, so the gear won't catch on anything. Still not the best solution (iam not great when building with technic, more a system guy myself) but it works...
Some more pics. I tried the L motor but the 3x5L beamns (with grille print) hit it, so i can't use it without even more mods. Gone back tho the M motor. Raised suspension by one "stud" or beam to have about 5mm between motor and steering gear.
Added some parts to the "poor mans" rear axle, still waiting for balljoint and socket from Bricks and Pieces...
Finally the parts order arrived, so i added the ball and socket pieces and the new diffs to get a better ratio for offroading.
Also added a rear diff-lock. To unlock it, i just remove one 20tooth gear off the assembly and put it on the red pin on the roof.
Front facia is now straight due to shock absorber- and L motor attachment reasons...
31 minutes ago, chlego said:
You just redesigned the whole drivetrain/chassis, didn't you?
Yeah, based on Zerobrick's build, but with RC and different bits here and there.
Now if this isn't a mod and improvement, to the original set, then i don't know what :D
