*Your entry has earned 10 XP*
Finding no sign of any Imperial above the waves, Shiva left her speeder by the shore and descended below the waves to explore the downed TIE
The closer she got she realised the TIE hadn't survived the landing and was left in pieces, lost to the sea now.
Underneath the waves of Ordo
As she explored the ruined cockpit something caught her eye, the pilot hadn't strayed too far from their craft after all.
It would seem the occupant was a Karkarodon, in his arena Shiva would need her wits about to her to overcome this threat...
Encounter beneath the waves
Spoiler
My 'Wreckage LTC' entry,
A sideways build, using the only TIE like parts I had available but I believe the remnants of the cockpit, wing and strut are obvious here. I'd also wanted to include a Karkarodon in a build for some time.
Heres a little breakdown of the build, I wanted to add depth with the plates below the trans blue and it kinda works!
Build process
The base - a lot of rock in the sea
Build process
Edited by goatman461
I like your choice of bright green for sea-plants. Not sold on the TIE wreckage though. I wouldn't have known what ship it was unless you had stated it. The wreckage looks fine, just not defined enough for me.
On 2/4/2021 at 10:36 PM, dvogon said:
The setup is very creative, although a bit busy. That might be because the wreckage is... way wrecked.
Thanks
i wanted to continue my story with Shiva and the story on Ordo, not having a TIE fighter or necessarily the parts I needed to be creative.
i had hoped that the wing strut, damaged circle shaped cockpit and solar panel would be enough (after we see part of the wing in the last instalment) but I understand it may not be super clear.
I was thinking as the ship hit the water it broke apart but if I was to do similar again then I may look to do less but a little more detailed
