Milan Posted January 27, 2021 Posted January 27, 2021 DON'T FORGET TO INCLUDE A PICTURE OF THE CHASSIS BEFORE THE BODYWORK HAS BEEN ADDED.A BOTTOM CHASSIS PICTURE DOES NOT COUNT AS CHASSIS PICTURE!! TECHNIC MOTORBIKE CONTEST - ENTRY TOPIC CONTEST INFORMATION More information about the contest can be found in the general discussion topic. WHAT DO I NEED TO ENTER? Please take a careful look at the rules before posting in this topic. Each participant is obliged to create a post in this entry topic. Posts need to follow the rules stated below. Posts not following the rules will be disqualified so please read them carefully. ENTRY POST The entry post in this topic needs to contain: Entry name One or more images (max 4). You can have combined pictures (4 in 1) as long as the picture isn't bigger than 1024x1024. At least one image of the chassis, so take a pic where we can see the chassis before you close the bodywork. Embedded video is not mandatory this time Link to your discussion topic IMPORTANT This topic should be used for entries only, so commenting is prohibited. Please use the general discussion topic for...well, general discussion on the contest, and individual discussion topics to comment on the individual entries.
Thirdwigg Posted January 27, 2021 Posted January 27, 2021 Kickboxer Diesel Features: Steering Front and Rear Suspension Flat 4 Engine Four Speed Sequential Transmission Main Photo Left Side Right Front Chassis Photo Video
2GodBDGlory Posted January 28, 2021 Posted January 28, 2021 1987 Suzuki Nuda Concept Functions: -Dual Swing-arm suspension -2WD, with shaft drive -Hub-centered steering, with a bit of a virtual pivot -6-speed sequential gearbox (pedal operated, no ratchet) -Clutch (lever-operated) -Front disc brake (lever-operated) -Rear disc brake (pedal-operated) -I-4 piston engine Main image Left side Underbody shot Bare Chassis
Seasider Posted January 29, 2021 Posted January 29, 2021 (edited) The Speeder Description: Hardtail Chopper Front suspension Flat 2 cylinder engine Dimensions (approx): 54 studs long, 11 wide (18 at handlebars) & 17 high Video: WIP Thread: Edited January 29, 2021 by Seasider
steph77 Posted January 29, 2021 Posted January 29, 2021 (edited) KATANA SUPERSPORT Main picture: Features: - Suspensions - Direction - 4 speeds gearbox, sequential with shiffter - Breaks - Kickstand Pictures summary: Frame view Topic Edited February 5, 2021 by steph77
HorcikDesigns Posted January 29, 2021 Posted January 29, 2021 (edited) HD.one _____________________________ Main photo: ___________Features:_______________ - easily interchangible power pack modules: -------- fake engine with two speed transmission and pedal shifter -------- or mechanically much easier electric powerpack with detailed batterybox and controller, all of them fake. - tubular wannabe trellis space frame that adds lateral stiffness (the longitudal stiffness is achieved by the power pack and central beam-spine that act as real main load bearing frame - and steering with realistic geometry (caster angle, front trail, steering angle) - working suspension (springs only, no dampers) - almost modular design - frame, body parts, powerpacks - loads of attachment point for additional body parts or accessories - detailed front brakes - fake rear brake pedal ______________ chassis view: WIP and entry thread: Edited January 30, 2021 by HorcikDesigns
MajklSpajkl Posted January 29, 2021 Posted January 29, 2021 (edited) THE RED BLAZE Features: - soft tail - front suspension - V-Twin fake engine - two speed manual/pedal gearbox (L-N-H) Chassis / Internals photo: Video: Discussion topic: Edited January 29, 2021 by MajklSpajkl
nikolyakov Posted January 30, 2021 Posted January 30, 2021 (edited) Moc Name: Hybrid (2WD) - Front suspension - Rear suspension - Fake flat 4 engine - 2 speed gearbox with; low 2wd and fast rear drive mode Discussion topic, Good luck and thanks to all contestants. IMG_20210123_161833 by nikolyakov, on Flickr IMG_20210123_161738 by nikolyakov, on Flickr IMG_20210123_162408 by nikolyakov, on Flickr IMG_20210123_161902 by nikolyakov, on Flickr Edited February 3, 2021 by nikolyakov Discussion topic edit
Jundis Posted January 30, 2021 Posted January 30, 2021 F.B Mondial HPS 125 Build after the real 125cc motorcycle: HPS 125 Main: Features: - Full front and back suspension - 1 Cylinder fake engine - 4 Speed sequential gearbox via left pedal - Retractable side stand - easily removable upper frame and exhaust Right Side: Left side: Chassis: Discussion Topic:
MP LEGO Technic creations Posted January 30, 2021 Posted January 30, 2021 (edited) The Predator Features: Front and rear independent suspension Steering 2 speed, pedal-operated gearbox with neutral Fake V6 engine Photos: And the internals: Good luck to everyone in this contest! Edited February 2, 2021 by MP LEGO Technic creations
ralphie Posted January 31, 2021 Posted January 31, 2021 Route Clearance Vehicle The zombie outbreak was under control, but the undead still showed up in surprising numbers along supply routes. Something about the sound of diesel engines rattled what was left of their brains. Helicopters couldn’t clear underpasses, or along heavily wooded roads, but an RCV in experienced hands could clear 400 miles a day of just about anything. Features Suspension & steering Turbine engine with alternating fixed and spinning fan layers Planetary reduction Dual miniguns driven by the engine Miniguns engage by lowering them, using rotary clutch selector Side View (guns stowed) Front View (guns deployed) Rear View (guns deployed) Rear View / Frame Build Topic https://www.eurobricks.com/forum/index.php?/forums/topic/182783-tc19-route-clearance-vehicle/
Targi Posted January 31, 2021 Posted January 31, 2021 Tulitsa An as-small-as-it-gets model heavily inspired by an 80s Soviet scooter. Features Steering Suspension: coil spring rear, rubber connector torsion front Chain-driven single-cylinder engine Photos: [All stunts performed by professionals. Do not attempt to drive your Tulitsa in snow.] Due to scale, the bodywork is actually part of the chassis. Hence, on the chassis photo, all of the removable body panels are removed, the rest is half-disassembled: Discussion topic
JRS86 Posted February 1, 2021 Posted February 1, 2021 (edited) Hi! I'm Jon, and I'm new around here. I'd like to toss my hat in the ring; here's my entry, the Fat Chop 1200! <<< click here for my entry topic!!! Here's a list of features that I chose to build towards: Roughly half the size of 42036 B-model Hardtail rear Front suspension Cafe-style headlight, spearhead taillight Jockey shifter Low, wide handlebars with brakes Chain-driven 90° V-engine Wide rear tyre Straight-pipe exhaust Black and red "blood eagle" theme Minor details: gauges, air intake, radiator Minimal off-color pins and axles No illegal connections Must be sturdy and dense Here are a few more shots of my entry. Thanks for looking 😊 __JRS⁸⁶__ Edited February 1, 2021 by JRS86
johnnym Posted February 1, 2021 Posted February 1, 2021 2055 GENESIS Renegade Functionality: Steering Front suspension and hard tail Turboshaft engine (Buford system), impeller on turbo shaft driven by the rear wheel via shaft drive utilizing overdrive (20z => 12z(, 16z => 16z), 36z => 12z) Openable engine hoods Free standing Pictures: Discussion thread:
Jurss Posted February 1, 2021 Posted February 1, 2021 JF explorer 2WD Features: Steering 2 wheel drive Full suspension 2 speed gearbox Differential between front and rear wheel 2 cylinder flat fake engine
MinusAndy Posted February 1, 2021 Posted February 1, 2021 (edited) Kaneda's Other Bike Features: Balanced Suspension with Single Sided Swing Arms. Hub Centre Steering with Speeder Bike Style Arms. Working Rear Brake Pedal. Two Speed + Neutral Gearbox with Pedal Shifter. Spring Loaded Kickstand. Six Cylinder Radial Fake Engine. Link to video https://flic.kr/p/2kxQuUc Edited February 1, 2021 by MinusAndy
MangaNOID Posted February 1, 2021 Posted February 1, 2021 Nurses speed Used for high density environment medical emergencies this Retro styled scooter has... -(fake) electric motor -carry racks and basket -adjustable and opening seat -‘sprung’ kickstand -chain tensioner -balloon tyres for tough terrain -suspension and steering
Ivorrr Posted February 3, 2021 Posted February 3, 2021 (edited) Custom Fat Boi Features: - Front suspension - V6 Fake engine - 2 speed gearbox with neutral I wish I had Tumbler tires... Edited February 7, 2021 by Ivorrr Replaced the picture of the bottom for 4x image of chassis without bodywork as per guidelines
Rudivdk Posted February 6, 2021 Posted February 6, 2021 SNAKE custom chopper Inspired by Ninjago's numerous snake designs and wacky vehicles. Features: steering front fork full suspension (front and rear) chain driven rear wheel 4-speed gearbox with 4<->1 block sequential stepper shift pedal fake V6 engine retractable stand 'snake mode': rear adjustable ride height, linked to adjustable tail foldable 'neck flaps' (cobra 'hood') Video: More pictures: Discussion and build progress topic: Once again this was a fun contest, good luck to all!
johncarpenter Posted February 7, 2021 Posted February 7, 2021 Electric Scooter Features: Steering Front and rear suspension Electric motor Removable battery pack under the seat Video:
LegoMathijs Posted February 7, 2021 Posted February 7, 2021 Rieju MRT PRO (2020) Features: - Rear suspension - Steering - Retractable side stand Frame: 11_Rieju_MRT_Pro_2020 by Mathijs Bongers, on Flickr 12_Rieju_MRT_Pro_2020 by Mathijs Bongers, on Flickr Final result: 01_Rieju_MRT_Pro_2020 by Mathijs Bongers, on Flickr 02_Rieju_MRT_Pro_2020 by Mathijs Bongers, on Flickr 06_Rieju_MRT_Pro_2020 by Mathijs Bongers, on Flickr 03_Rieju_MRT_Pro_2020 by Mathijs Bongers, on Flickr Discussion topic: https://www.eurobricks.com/forum/index.php?/forums/topic/183212-tc19-rieju-mrt-pro-2020/
Coola1 Posted February 8, 2021 Posted February 8, 2021 Silverback Rider Features: - Steering - Front and rear suspension - Fake V2 engine - Adjustable seat Pics: Discussion topic:
brolansys BLS 21 Posted February 8, 2021 Posted February 8, 2021 [TC19] Recreation of promotional Shell 2544 Motorcycle Features Front suspension (through rubber bands and a yellow foam ball . . . ) Rear suspension (through rubber bands) Steering 2 piston fake engine Adjustable rear swing arm via worm gear (through a Roborider chassis piece) Adjustable front fork via worm gear (normal worm gear box Glow in the dark rear light via Onyx Roborider glow in the dark wheel
Zerobricks Posted February 8, 2021 Posted February 8, 2021 [TC19] Extended motorcycle with a CVT Functions: Linear front suspension Extended swingar rear suspensions upported by small turntables Constant Variable Transmission A working V6 engine Steering Features: Extended rear swingarm Detailed and complete bodywork Aerodynamic details such as winglets, flat bottom and rear diffuser Additional details such as brake discs in front and rear, dual exhaust pipes, large radiator, front fender, etc... Photo of the front view: Photo of the back view: Photo of V6 engine and details: Photo of the chassis when the model was still being built: Video of the model in action with commentary: Link to the topic:
