AlAxe2 Posted February 16, 2021 Posted February 16, 2021 I'm working on an expansion of a simple oval layout I'd had for over a decade, and I'm trying to figure out how to scale down the number of feet per section of real-life railroad track to L-Gauge. For example, how many Lego tracks would equate to 1,202 feet of real-life tracks? Quote
garethjellis Posted February 16, 2021 Posted February 16, 2021 It depends what scale or gauge you want to go with, using track gauge only 1 brick width = 8mm, Lego track is 6 bricks wide = 48mm Standard track gauge is 4' 8.5" = 1241mm This gives a scale of 1:26 So.@ 1:26..1202 feet would = 1991 studs, Track is 16 studs long. so you would need 124 track sections. Quote
caiman0637 Posted February 16, 2021 Posted February 16, 2021 http://studs.sariel.pl/ Hope this helps. Quote
Sven J Posted February 16, 2021 Posted February 16, 2021 36 minutes ago, garethjellis said: Lego track is 6 bricks wide = 48mm Standard track gauge is 4' 8.5" = 1241mm This gives a scale of 1:26 Sorry, but this is wrong. Track gauge is defined by the inner distance of the rail heads, which is 38 mm for Lego track (6 studs is the distance between the outer edges of the rail bases!). Prototypical standard gauge is 4' 8.5", as you said, but this is equivalent to 1,435 mm. So Lego track has a scale of approx. 1:38. Quote
garethjellis Posted February 16, 2021 Posted February 16, 2021 43 minutes ago, Tenderlok said: Prototypical standard gauge is 4' 8.5", as you said, but this is equivalent to 1,435 mm. You are correct, this is what happens when you trust the interwebs! https://feetmm.com/height/4-feet-and-8.5-inches-to-mm Quote
