gvo25 Posted February 26, 2021 Posted February 26, 2021 Hello all, Just 2 small questions: 1) can you connect to the same shaft a control+ L-motor and a XL-motor, or do you need reduction gearing? 2) if yes is it usefull to do so, to get extra power on a driveshaft? Thanks Quote
syclone Posted February 26, 2021 Posted February 26, 2021 (edited) The C+/Pup L and XL motors are identical in regards of their speed and torque (data from https://www.philohome.com/motors/motorcomp.htm). The difference is in efficiency, with the XL motor being more efficient. Based on this: 1) Yes you can connect them directly. 2)Yes and No. Yes, you would get more mechanical power, but 2 Xl motors linked together would be more power efficient. Take my answer with a grain of salt, as I am not well-versed in mechanics, electrics/electronics and especially C+ system, my deductions are based on my limited knowledge and data provided by Philo's tests. Edited February 26, 2021 by syclone Quote
Andman Posted February 26, 2021 Posted February 26, 2021 (edited) Personally I would not hard couple them. They have slightly but still different characteristics in terms of speed and torque. It will be hard to match the ratio (1:1.04) with gears. But what you can do is to couple them with differentials. Edited February 26, 2021 by Andman Quote
