Hi there, I am samuel thomas gu. I want to learn how to create lego models as detailed as the creator expert and technic models. I want to create a model of the nissan 300zx z32, but I don't know where to start.
Welcome to Eurobricks @samuelgu,
I think it would depend whether you want to build either a technic or model or scale model.
If you want to build a scale model (like creator expert cars), this forum may help:
If you want to build a technic model, than perhaps this forum:
Either way, I would recommend using the free instructions from Lego.com from a similar technic or creator expert car, any car will do, to get an idea of the construction techniques. The car you want to make is quite different from the creator expert cars, but it should help. If you are building a technic model, parts will probably be a limiting factor, so I would suggest heavily modifying a similar technic set to meet your needs. Doing so may not yield the most accurate result, but may make it easier for a first build.
Edited by Stuartn
