efferman Posted March 21, 2021 Posted March 21, 2021 (edited) Because the leaked Picture shows not everything and i have to speculate, i better start the improvment thread. first point: the doorstep and the rear end of the Front Fender Edited March 21, 2021 by efferman Quote
Void_S Posted March 21, 2021 Posted March 21, 2021 I would also try to close the front holes, between wheelarches and angled 3+7 liftarm. Perhaps, the 2*1 plate with a pin hole and some wedge plate or tile may close it. Will try to check it tomorrow. Quote
efferman Posted March 22, 2021 Author Posted March 22, 2021 11 hours ago, Void_S said: I would also try to close the front holes iam trying it, but not yet satisfied. Quote
Void_S Posted March 22, 2021 Posted March 22, 2021 2 hours ago, efferman said: iam trying it, but not yet satisfied. I mean something like that: Initially I planned to use it as a rear part for 42098-compatible car (with trans-red 1x1 cheese slope) but it may work here as well. I can not say that it looks better than yours but just one more option. Quote
efferman Posted March 22, 2021 Author Posted March 22, 2021 i guess your option is better than my previous version. Maybe this one is better too And yes, it is tiltable Quote
suffocation Posted March 22, 2021 Posted March 22, 2021 1 hour ago, efferman said: Maybe this one is better too Way better Quote
Void_S Posted March 22, 2021 Posted March 22, 2021 Great! Now I would replace the bumper with 3x4 tile-plates, to make it authentic to flat chrome panel. It worked the best for Model Team trucks and may add more places to add more orange lamps Quote
efferman Posted March 22, 2021 Author Posted March 22, 2021 1 hour ago, Void_S said: Now I would replace the bumper with 3x4 tile-plates Thanks guys. I want keep the Technic look. The progress so far Quote
Frodman Posted March 22, 2021 Posted March 22, 2021 The way this is going on makes this set a must have for me ! I'm sure you will find a solution to reduce the hight of the crane efferman ! Quote
efferman Posted March 22, 2021 Author Posted March 22, 2021 23 minutes ago, Frodman said: I'm sure you will find a solution to reduce the hight of the crane efferman ! With pneumatics and no RC the crane is the smallest problem Quote
u118224 Posted March 22, 2021 Posted March 22, 2021 Not a fan of the headlight change to the front of the fenders. Just my .02, everything else looks good. Quote
XTN Posted March 24, 2021 Posted March 24, 2021 Do you know if the wheelbase between the rear axles will be the same as in 42087 or the shorter variant as in 42112? Quote
efferman Posted March 25, 2021 Author Posted March 25, 2021 16 hours ago, XTN said: wheelbase between the rear axles 7 studs i guess Quote
Void_S Posted March 26, 2021 Posted March 26, 2021 (edited) On 3/25/2021 at 12:54 AM, XTN said: Do you know if the wheelbase between the rear axles will be the same as in 42087 or the shorter variant as in 42112? I also counted 7 studs (6 if don't take into consideration the stud holes used by the axles themselves). 42078's "spread" does not fit here. The full wheelbase looks like that: [1st axle /1 stud] - 33 studs - [2nd axle /1 stud] - 6 studs - [3rd axle /1 stud] - 6 studs - [4th axle /1 stud]. But... being a fully correct (the wheel base is a distance between front axle and a center or rear non-steer "trolley"), the wheelbases are: 41 (40 between axles) when the lift axle is lowered. 44.5 (43.5 between axles) when the lift axle is raised. Added: BTW, some tasty recolor: Edited March 26, 2021 by Void_S Quote
efferman Posted March 26, 2021 Author Posted March 26, 2021 3 hours ago, Void_S said: BTW, some tasty recolor: Mack chassis? btw, you bumped me to a long haul Tractor unit. I guess the cab floor should be lowered a stud. Quote
Void_S Posted March 26, 2021 Posted March 26, 2021 9 minutes ago, efferman said: Mack chassis? btw, you bumped me to a long haul Tractor unit. Exactly! I had a 42128 cabin and 42078 chassis, so... Again, comparing with the 42078 set, the floor is really too high here. Possibly TLG put it 1 stud higher because of such big gas tanks. Quote
XTN Posted March 26, 2021 Posted March 26, 2021 (edited) 4 hours ago, Void_S said: I also counted 7 studs (6 if don't take into consideration the stud holes used by the axles themselves). 42078's "spread" does not fit here That's a pity. All the trucks in my garage have 42078's spread (42078 A and B, M-Longer's Granite snow plow, ...). I even modded 42112 to make it fit into the line-up. I hope my OCD is fine with the look just because of the huge amount of rear axles. Edited March 26, 2021 by XTN Quote
Void_S Posted March 26, 2021 Posted March 26, 2021 I have digged into the US Bridge Formula and this diffrence looks OK now for me. The main ides is "a bigger wheelbase can carry a bigger weight", so for 3-axle semitruck it was required to have a bigger inter-axles distance, like on real trucks. While 4-axleled tow truck or cement mixer are capable enought to have a tiny spread due the axles number. Moreover, this formula acts for inter-state hauling, whilie construction or resquie machines have a shorter range of use. But for a visual apperance, it is pity, right... Quote
efferman Posted March 30, 2021 Author Posted March 30, 2021 actually 815 Parts and it could end at roundabout 1000 parts. Quote
efferman Posted March 31, 2021 Author Posted March 31, 2021 Driving ready 1011 Parts. Only Cab interior and a motor fake is missing. Quote
