In the future I want a chemical plant to be part of my BrickPolis as I have a background in chemistry and am working for a chemical company. This 8-wide industrial train is used to supply the plant of needed raw materials.
It contains a Vossloh G400B tender in NS livery (Dutch Railroad) for moving the wagons around. The Vossloh model is designed by Dennis Tomsen which I reverse engineered from two pictures and adapted to run with PoweredUp. The Box Car behind contains the PU hub. Behind that a simple Tank Wagon for which I found a building instruction but without mentioning of the creator. The Sphere Wagon is my own design and uses the new 4 x 4 round corner dome top bricks.
The part list contains all parts of all 4 elements but separate Bricklink XML and PDF parts list per train element are available in the files section, as well a a sticker sheet. RED parts in the building instructions can be replaced by any color!
Separate building instructions and part lists for free on my Rebrickable:
https://rebrickable.com/mocs/MOC-72829/BrickPolis/industrial-train/
Nice build, thanks!
Very nice Dennis. Both the locomotive and the cars look great.
Is it just me, or do the spheres look a bit like hand grenades?
Now that you've said it, you're right, thanks God IRL grenades aren't that big.
Very good train ! The amount of details in impressive.
Very nice train, with a lot of details and realistic shapes! :thumbup::wub:
Ciao!
Davide
Just a heads up :classic:
The way Berthil builds the NS Vossloh G400B is very different to mine due to the reverse engineering. The final result is the same though.
Great set-up :thumbup:
